Spray paint help - why does it rub off on my hands when I touch it? - MG-Rover.org Forums
post #1 of 15 (permalink) Old 22-04-2006, 17:54 Thread Starter
Sprayed my interior bits and bobs a while back, but when I touch them the paint rubs off on my hand, and it also chips/scratches very easily. Why is this? Crap paint? Or have I just not painted it right!? I was informed that metallic paint doesn't require lacquer, is this correct?
Going to redo them, anyone have any tips as to how I can avoid the paint rubbing off/chipping this time?
ThumpJunkie is offline
post #2 of 15 (permalink) Old 22-04-2006, 17:56
Car: Peugeot 206 GTi
Send a message via MSN to troy.mclure
Metallic and pearlescent paints DO require lacquer. I suspect the weather has caused the paint to breadown which is why its rubbing off
troy.mclure is offline
post #3 of 15 (permalink) Old 22-04-2006, 17:57
Car: MGZT pbt derv
Quick answer, don't touch the painted bits!!!!
Skelo
Dave is offline
post #4 of 15 (permalink) Old 22-04-2006, 18:04
Car: Silver Stormer ZR turbo.
Did you use plastic primer?
You should always laquer metallic and pearlescent paints or they don't become their true colour, not only that the laquer will seal and and give the paint a hard protective surface.
ashy is offline
post #5 of 15 (permalink) Old 22-04-2006, 18:10 Thread Starter
The weather in my interior...???
post #6 of 15 (permalink) Old 22-04-2006, 18:13
Talking
Oh yeah! Lol!! Thats what I get for replying while Im watching the football!
Anyway, like whats been said, the paint has degraded becasue of the lack of lacquer which acts as a protector.
post #7 of 15 (permalink) Old 22-04-2006, 18:14 Thread Starter
Yeah I did mate.
How do I apply the lacquer? It didn't go on well the last time, so I re-stripped the parts and did them again. It says on the tin that you've to sand it down before applying it, but wouldn't that defeat the purpose?
post #8 of 15 (permalink) Old 22-04-2006, 18:28
When it says sand down it means just to matt it.
TBH it's not necessary if you do it while the paint is still not set. I wait about half an hour before putting the laquer on and never had problems yet.
With laquer you need to apply it in sweeps. Press the trigger about 8-10 inches away and do a sweep from left to right or right to left and back the opposite way. Let of the trigger in between sweeps, this prevents overlap causing it to run.
Give it a wet coat and leave it for a few mins then hit it with a hairdryer on a low heat setting for another few minutes. This will give the laquer a mirror finish. Let it cool and then do another coat, but straight after applying the coat hit it with the hairdryer on a low setting again.
Let it cool and then same again.
After about 3-4 coats and the hairdryer you should have a mirror finish.
Then let it dry properly and you should be sorted.
Done it this way loads of times without problem. HTH.
ashy is offline
post #9 of 15 (permalink) Old 22-04-2006, 18:32 Thread Starter
Nice one Ashmeister
So it's best to apply the lacquer whilst the paint is still tacky?
post #10 of 15 (permalink) Old 22-04-2006, 18:36
Not actually tacky, but as long as the paint hasn't set hard should be fine.
If you use the hairdryer to cure the paint coats then I'd say after half an hour you will be able to start applying the laquer.
Oh, one other tip: Put the can in warm to hot water before spraying and in between coats of laquer. This will make it spray much better and prevent spotting.
ashy is offline
post #11 of 15 (permalink) Old 22-04-2006, 18:49 Thread Starter
I don't have access to an electrical point in my garage...
post #12 of 15 (permalink) Old 22-04-2006, 18:53
Car: Classic Rover
Can you run an extension cable from anywhere?
Samuel is offline
post #13 of 15 (permalink) Old 22-04-2006, 18:56
Car: Rover Coupe Turbo
Send a message via MSN to < KEVIN >
just hack into the nearest lampost u'll be fine, but were rubber boots though just incase you get a small shock.
or long extension lead
< KEVIN > is offline
post #14 of 15 (permalink) Old 22-04-2006, 19:05
Go out and buy a 15 metre extension you tightwad...lol.
ashy is offline
post #15 of 15 (permalink) Old 22-04-2006, 19:18 Thread Starter
15metres? I think not... it's a council garage 200 yards away!
Touch up spray paint danicholls26 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 14-09-2007 07:28
Black Pearl touch up pen/spray ampthetex Wanted 1 27-02-2007 10:43
Touch up spray paint advice anyone? danicholls26 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 5 03-12-2006 17:16
Burberry Touch For Men Eau de Toilette Spray 50ml markmarkmark Non Car Items 1 26-05-2005 20:48
just done my first ever paint spray... mac04 MG/R Modification & Tuning 38 25-07-2004 15:54
