What does the SRS light mean? - MG-Rover.org Forums
post #1 of 19 (permalink) Old 23-08-2004, 20:59 Thread Starter
Hi guys, I am new on this site and i just need a question answered for me, I keep getting the SRS light in red come on in my Rover 214 what does this mean it has happened a few times and then suddenly it goes off the next time i drive it, which is a bit strange?
If someone could let me know I'd be really grateful!
Thank you!
claire4 is offline
post #2 of 19 (permalink) Old 23-08-2004, 21:01
It means the SRS ECU has detected a fault and has shut the system down for safety reasons.
It's usually down to seatbelt pretensioner and rotary coupler connection faults, the system is that sensitive to bad connections.
post #3 of 19 (permalink) Old 23-08-2004, 21:04 Thread Starter
Okay which means what then? do i need to go and get it sorted? or will it be alright?
Thanks for replying by the way!
claire4 is offline
post #4 of 19 (permalink) Old 23-08-2004, 21:06
You can ignore it - you're not breaking any laws....yet!
A bad connection just needs unclipping and cleaning then lubricating with WD40 and outting back together. All should be well then.
post #5 of 19 (permalink) Old 23-08-2004, 21:13
As Major says, probably the connection where the wire under the front seats plugs into the seat belt clip.
john_w is offline
post #6 of 19 (permalink) Old 23-08-2004, 21:16
Claire - I reckon you could fix this yourself.
No need to disconnect the battery to do the connector cleanup.
post #7 of 19 (permalink) Old 24-08-2004, 00:00
Car: 218VVC Coupe'
Bear in mind that while that little red light is on, your airbags will not fire and nor will your seatbelt pretensioners if you crash. So don't go drag racing with it.
Ingram knows better than I do about the safety aspects of disconnecting the SRS leads, but I can tell you that WD40 will only last for a time... cut an emery board to the right size and GENTLY scrub the contacts. Many electrical problems are caused by oxidation, and this removes it.
Orion is offline
post #8 of 19 (permalink) Old 24-08-2004, 07:19
SRS system contacts are gold plated, in an effort to get 100% connection reliability - but it doesn't seem to work!
post #9 of 19 (permalink) Old 24-08-2004, 12:11
Yeah, have a go yourself.... technically your are breaking the law (as your vehicle will not pass an MOT), but it's nothing to really worry about...
cosb6 is offline
post #10 of 19 (permalink) Old 24-08-2004, 12:40
Car: Rover Tomcat Turbo
Send a message via MSN to Marko
Do you mean the SRS light on the dash or the red srs on the steering wheel though?
Marko is offline
post #11 of 19 (permalink) Old 24-08-2004, 12:45
I thought you had to disconnect the battery for 10 mins or more before doing any work on the SRS system.
Grand Master is offline
post #12 of 19 (permalink) Old 24-08-2004, 12:55
Which law is that then ? and SRS doesn't come into the MOT !
DaveH
Respot is offline
post #13 of 19 (permalink) Old 24-08-2004, 13:41
hmmmm I think I'm thinking of the ABS... ooops..
cosb6 is offline
post #14 of 19 (permalink) Old 24-08-2004, 18:00
Yep, had this problem with my 45. It was caused by books/maps etc sliding under the seats and catching the cables. Just wiggling the cables, pushing the connectors together & keeping the under seat area free of junk solves the problem.
Not had it light up now for several weeks, whereas it was regularly lighting up in an upredictable fashion.
Rover_ron is offline
post #15 of 19 (permalink) Old 24-08-2004, 18:31
Personally, I don't think there are many 25's and 45's out there NOT suffering some form of SRS light activation at some time in their lives.
post #16 of 19 (permalink) Old 24-08-2004, 18:53
Car: Rover 200 Coupe
Send a message via MSN to roy_newell Send a message via Yahoo to roy_newell
since claire has not actually stipulated it comes on when driving I feel its my duty to say this JUST IN CASE.
The srs light should come on when you start the car for about 3-4 seconds then go out, just in case you didn't know that and thats all you're referring to as everyone has jumped straight in on the solution but if its only due to the normal wake up self test procedure then its pointless getting you to do stuff to your car.
If however you are referring to it coming on when driving then the above advice by everyone is more than helpful
roy_newell is offline
post #17 of 19 (permalink) Old 24-08-2004, 23:22
Car: 218VVC Coupe'
The general concensus about SRS components used to be, "how can you test something when that test is destructive to the component in question?"
Of course the light on the dash means that the system isn't working so is obvious without any further testing.
It's a dead cert that when 100% of cars have SRS systems, (and I have no doubt that will be legislated for by our ever-caring government who just want to protect people and who have no interest at all in protecting Ford, Vauxhall etc. who just so happen to contribute heavily to them in kickbacks), then it will be part of the MOT in a full-on way.
After all, we all need protecting from ourselves. And won't somone think of the children? PLEASE? Please won't someone think of the chi-hi-hi-hilduh-uh-uh-n!?!?!?!?!
Orion is offline
post #18 of 19 (permalink) Old 24-08-2004, 23:24
You hit the nail right on the head there Chris.
Now please go and contribute to the gloom and doom thread in the general MGR forum, give AE summat to write about next week?
post #19 of 19 (permalink) Old 24-08-2004, 23:34
Car: 218VVC Coupe'
I'm just a cynic. My director (who I report directly to) describes me as "the angriest person I have ever met". I just don't trust their motivations - big business and government don't do anything out of altruism after all.
Tell you what - I'll give AE something to write about - my ass. It's fuel-injected because I crammed a pump up there. I'll pull the trigger while they light a cigarette and write a review about how the new 5-series is "visionary". First person to flinch gets to drive home in a TATA pickup.
Orion is offline
srs light GCG1967 MG ZR / Rover 25, 200 & Streetwise 4 30-01-2012 18:01
SRS light adavida Rover 800 1 24-06-2008 22:17
srs light teresatomcat Coupe 10 23-09-2007 10:36
SRS Light on - Help please Simon_peters MGF and MGTF (Sponsored by MGFnTFBITZ) 5 25-06-2007 10:39
Srs Light crazy-ant MG ZR / Rover 25, 200 & Streetwise 1 18-02-2007 14:46
