Cabriolet Hydraulic Roof Pump Refill - [ROVER-CX8 Project] - MG-Rover.org Forums
post #1 of 11 (permalink) Old 28-05-2016, 19:12 Thread Starter
When I got my Cabby I noticed the roof was very lethargic and
required a push to get it moving but recently it had become
useless at raising itself up again, needed two people last week,
I have owned FORD Escort Cabriolets in the past and they
suffered from a similar problem but it was down to a failed pump
cog, this doesn't seem to be the case on the Rover variants as
the pump is mounted vertical compared to the horizontal position
of the Ford units which must make them work harder.
After a quick investigation I found the fluid level was very low and after asking around on here decided to refill the unit with generic
clutch and brake fluid.
To remove the brass grub bolt you will require a 13mm socket or
spanner, be sure not to loose the rubber o-ring seal when you
remove it.
To fill up the fluid I re-used a rig I made to fill my 75 clutch
reservoir, came in handy for this.
I only ended up putting in about 40ml of fluid to get it back to
the Max mark, I then cleaned up the aperture and refitted the
grub bolt.
I had to make a couple of passes of operating do get what I
guess was air in the system, the horrid noises it was making
then silenced and I now have fully functioning and smooth
roof operation, link to a quick video of the second roof raising
is below, I hope this guide helps anyone who may encounter
a similar problem.
ROVER-25X is offline
post #2 of 11 (permalink) Old 28-05-2016, 19:15
I cannot see the video?
post #3 of 11 (permalink) Old 28-05-2016, 19:43 Thread Starter
Have you got AdBlock running ?
Adobe Flash need an update ?
Just search for it on YouTube, easy to find.
post #4 of 11 (permalink) Old 28-05-2016, 19:45
Your other videos I can see without problems, just this one I cannot.
post #5 of 11 (permalink) Old 28-05-2016, 21:06 Thread Starter
Weird, its public and had an outstanding 11 views, that gold play button will be mine in no time lol.
Heres the direct link:
EDIT: It seems this new forum layout automatically makes vid links into play windows.
post #6 of 11 (permalink) Old 28-05-2016, 21:09
Both video's are working for me
Chris T is online now
post #7 of 11 (permalink) Old 28-05-2016, 21:18 Thread Starter
I'm sorry for wasting you life.
Come on Roverlike put some coal in your steam powered dial up server lol.
post #8 of 11 (permalink) Old 29-05-2016, 06:11
Your direct link is not even visible for me.... ???
However I tried other browser and in Chrome I can see it, in Firefox I cannot...
post #9 of 11 (permalink) Old 29-05-2016, 17:09 Thread Starter
I removed the direct link as it just became a popup youtube video window.
post #10 of 11 (permalink) Old 29-05-2016, 17:42
I didn't say I watch it!
post #11 of 11 (permalink) Old 27-11-2016, 04:36
Car: Rover 200 Cabriolet
Leaking sump bowl on 97 cabby power hood pump.
I found the plastic sump or bowl underneath the hood pump on my 97 cabby was leaking due to a split in its side wall. I raided the kitchen cupboard and found an opened food tin that fitted perfectly over the sump bowl. It just covers the height of the bowl and acts as another external sump so the oil leaking out just goes straight into the tin can. I added a bit more oil to bring the level up, and now have no loss of fluid. This perfect fix might help another cabby owner with a similar problem. Cost - zero! I love zero cost fixes. I use Dexron 3.
Alex.
Alex Binnie is online now
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Alex Binnie
Cabriolet roof pump and rams bobbybrown Wanted 0 01-07-2013 15:20
216 cabriolet hydraulic roof pipe maverickuk1 Wanted 0 26-06-2009 18:47
Hydraulic roof pump ling marcus 'R8' Rovers (aka Wedges!!) 2 06-05-2008 14:06
Rover 114 Cabriolet - Leaking cabriolet roof - help! jcc Metro / Rover 100 3 18-01-2007 12:16
Suspension, hydraulic fluid refill in Sweden? Joltman MGF and MGTF (Sponsored by MGFnTFBITZ) 6 21-09-2005 22:59
