Horn doesnt work after steering wheel swap - MG-Rover.org Forums
post #1 of 10 (permalink) Old 17-11-2016, 16:03 Thread Starter
Car: Rover 200 (89-95)
Hello, I have changed my old NON AIRBAG steering wheel(its the one with big rounded horn button in the middle) for newer one with airbag(both R8s) and now the horn doesnt work.Whats the difference,why the horn doesnt work ? Have anyone some experience with that ?
cheers
Kamil F is offline
post #2 of 10 (permalink) Old 17-11-2016, 16:17
If you installed steering wheel with airbag I suppose you needed to change rotary coupler as well? Now you have more wires from steering wheel then before.
How you connected new wires to existing loom in the steering column?
post #3 of 10 (permalink) Old 17-11-2016, 16:28 Thread Starter
the new wheel is airbag type but it has no airbag,its empty...so i supposed the rotary coupler its not neccesarry..but i saw some connectors on it..maybe this is the problem..i have changed everything from donnor car (plastics,indicators), except r.coupler. it was very dark and i was hurry
So you think the coupler is needed ?? I can put one connector IN,but my car has no airbag yellow wiring loom so i dont have OUT connector if you understand me ? Im little bit confused,sorry
Kamil F is offline
post #4 of 10 (permalink) Old 17-11-2016, 16:30
Ok, lets forget about rotary coupler. How you connected horn buttons?
post #5 of 10 (permalink) Old 17-11-2016, 16:41 Thread Starter
OK, probably I didnt connect it.I thought it was working the same way like the old horn..So how to connect it..
Kamil F is offline
post #6 of 10 (permalink) Old 17-11-2016, 16:58
You need to find how old horn was connected, and then you will need to modify new wires to the old system. My problem is that I do not know how old was connected, as I did not have one to play with.
post #7 of 10 (permalink) Old 17-11-2016, 17:03 Thread Starter
ok I will find it out..
btw i found this:
Well i fitted a air bag wheel to a non airbag 216,you will need the column shroud the complet airbag and the yellow wiring loom, then a small bit of wiring for the horn buttons to work because the non airbag horns work on a scraper contact on a copper ring at the base of the wheel while the airbag wheel uses the yellow clock spring component behind the wheel to connect the horn buttons to the main wiring.
Sounds complicated but straight forward and the rover airbag will fit an MG wheel as long as they look the same shape.
its straight forward..hmm,I wonder i will try it tommorow
Thanks Roverlike !!
Kamil F is offline
post #8 of 10 (permalink) Old 17-11-2016, 18:36
Yellow clock spring component is rotary coupler I was talking about.
post #9 of 10 (permalink) Old 18-11-2016, 17:45 Thread Starter
Solved.I have added rotary coupler and yellow wiring loom..it was plug and play,thanks Roverlike
Kamil F is offline
post #10 of 10 (permalink) Old 18-11-2016, 18:15
Glad you made it
my horn doesnt work dan200* MG ZR / Rover 25, 200 & Streetwise 7 23-05-2014 17:54
Horn dont work after steering wheel change RyanZR MG ZR / Rover 25, 200 & Streetwise 10 25-10-2011 11:30
MG TF driveing wheel fitted and now horn does not work anymore!! Miky060 MG ZR / Rover 25, 200 & Streetwise 13 21-07-2011 20:13
Steering wheel mounted control doesnt work... RJ303 In-Car Audio, Entertainment, Sat Nav etc... 3 01-07-2010 21:13
Rover 220 Turbo Coupe - Horn works doesnt work, no intermittent wipers RichMann Coupe 6 04-11-2006 11:07
