Rover 216 Coupe Intermitant Starting Problems - MG-Rover.org Forums
post #1 of 11 (permalink) Old 27-11-2005, 15:31 Thread Starter
Car: Rover 200 Coupe
Ive had my coupe for about 4 years now and still love it, but sadly shes giving me problems which I just cant solve. At first I would have the problem of it not restarting if I stalled it, but if I left it for 10 seconds or so it would restart and and no other symtoms. If I had stalled it however and immediately tried to restart I could sit there all day and it would not start unless I did nothing as mentioned before. Now it is totally random it might start it might not, I might pop down the shops and when I come back out it wont start. If I leave it and come back later it normally starts or call the RAC and by the time they arrive it will be fine.
Please Help
1993 Rover 216 Coupe (67,000 miles)
Have changed Rotor Arm, Distributor Cap, plugs and fuel filter where do I go next
neilus123 is offline
post #2 of 11 (permalink) Old 27-11-2005, 15:32
Send a message via MSN to ash7990
probably a sensor, not sure what one though.
ash7990 is offline
post #3 of 11 (permalink) Old 28-11-2005, 14:56
New to the forums, new to rovers, I have a 98, 218 vvc 1.8 rover coupe with EXACTLY the same problem. At random it would be a bugger to start, almost draining the battery to get it to go.
You get in, key in ignition and click it round once, immobiliser off, electrics on, dash lights and systems engage and lights blink off as should. It’s at this point you think… will it, wont it…. So you turn the key and … ********! The starter motor turns good and strong but it just wont fire, now and then it just gives you a little teasing of hope and no… try again, the same for about 10 seconds. But the other day it just wouldn’t start at all.
Its almost as if there is no fuel in it, (yes there is before you ask *chuckels*) I read another post somewhere about waiting a few seconds for the fuel pressure to build up but, that does not see to have any effect. Once started though she purs like a kitten and drives nice and smooth.
A week before its NO starting I took it to the gates of hell (rover dealer) and had them run a health check on the 'puter and sensors. All was functional no problems.
So its down the garage been there for 3 days now and I am *****ing my pants at the prospect of the bill. I noticed that this thread did not get much interest but for the love of god… *gets down on his knees* Gurus. Dr Dave help a poor and orphaned child before I have to sell my body to pay the bill!
Smoocher is offline
post #4 of 11 (permalink) Old 28-11-2005, 15:33
I'd probably say ignition rather than fuel (leads, dizzy, coil?), I have a similar problem, it doesn't like starting, maybe even a dodgy battery or earth?
This weather puts alot of strain on our engines, mainly the battery!
mikehIOW is offline
post #5 of 11 (permalink) Old 28-11-2005, 16:47
Car: Rover 75CDT connSE
Send a message via Yahoo to shakenNstirred Send a message via Skype™ to shakenNstirred
is it the honda engine
if it is it could be this fault
when you turn the ignition on after it wont start do you hear the little click as the engine check light goes out.
i had the same problem, i rang green flag twice and both times it started straight away when they were at the car.
if you dont hear the click its the brown boxed relay behind the centre console
its a common fault, the relay gets dry joints on the soldered pins.
you just need to run a soldering iron over them and it will be fine.
shakenNstirred is offline
post #6 of 11 (permalink) Old 28-11-2005, 18:07
Car: MG ZS 180 Mk2 Ignition Blue hatch
I would agree with the above, main relay, I have just resoldered mine. The relay is very easy to get to and comes apart no problem. If you use a magnifying glass and look at the circuit board you will see some dry joints where the solder has cracked. You only need to resolder these.
If this doesn't cure it then try replacing the ignition module in the distributor. No need to remove the distributor but some of the screws are very small and have screwlock on them.
shufti is offline
post #7 of 11 (permalink) Old 28-11-2005, 18:18
Thanks for the speedy replies, I took my car from the garage, they had it 3 days and all they had done was change the leads and order a new battery... *grubles* couldnt find a problem becuse it started up for them.
As for a click..mm... I will try that out thank you very much. Talking of noises on start up, when you power up there is a sound like an electric window motor 'wurr' for a second... then you start the car. What the noise?
Smoocher is offline
post #8 of 11 (permalink) Old 28-11-2005, 18:25
thats the fuel pump
post #9 of 11 (permalink) Old 28-11-2005, 18:26
Smoocher that's the fuel pump running.
The replies above refer to the first poster neilus123 assuming it's a Honda engine which your's isn't. You have a Rover lump. Don't know if the relay is the same in a rover vvc.
shufti is offline
post #10 of 11 (permalink) Old 28-11-2005, 18:28
Beat me to it shakens
shufti is offline
post #11 of 11 (permalink) Old 25-03-2006, 11:43
Intermittent starting - 216 coupe (honda)
I've had exactly the same problem, but it turned out to be a loose sensor wire in the engine bay (the lambda cable) i think. But i pushed all the other sensor cables in tightly and checked them anyway.
That was a year ago and i've had no problems at all and its ran like a dream since
its worth checking the cables as mine didnt seem loose or disconnected but playing around with them sorted the prob.
Joe1000 is offline
rover 216 starting problems andyc1234 MG ZR / Rover 25, 200 & Streetwise 1 26-04-2007 20:14
Rover Coupe 1.8vvc starting problems paul.keen 'R8' Rovers (aka Wedges!!) 4 30-03-2006 17:56
Rover 216 Coupe 1998 Starting Problem Stevjones77 'R8' Rovers (aka Wedges!!) 7 11-07-2005 14:46
problems starting the engine of 216 coupe xulio 'R8' Rovers (aka Wedges!!) 1 16-02-2005 11:11
Rover 216 GSI Starting Problems dn6aa Others 1 08-09-2004 15:38
