Is there any way of manually bypassing the alarm/immobiliser? - MG-Rover.org Forums
post #1 of 49 (permalink) Old 29-03-2005, 20:24 Thread Starter
Car: Please Select
I've just bought a Rover 218 off some dodgy bloke in the paper and in the week I've had it, the immobiliser overrode the starter and the alarm light would flash and not let me start up. The AA had to get me to an electrics place and they said the starter circuit had a knackered wire in it or something, and after they'd done whatever they did, it seemed to start up fine again. No problem, I thought. But then this morning I found myself in exactly the same situation. The electrics place said I could possibly override the immobiliser just to get it started, but I'm at a complete loss as to how to do this. Now I do have a keycode (ie: stand outside car, turn key left and right loads of times and make no difference whatsoever), but so far it hasn't solved anything, and as far as I know, there was never a key fob with it, as it doesn't appear to have central locking. I tinkered with the fuses and managed to get the glow plugs working and the engine turning over, but not that decisive bit where the thing actually kicks into life. Is it just a case of running a wire from somewhere on the starter motor to the + terminal on the battery, or is it something much more complicated/impossible?
15Peter20 is offline
post #2 of 49 (permalink) Old 29-03-2005, 20:53
hi there,dont think it would be wise to let people know how to bypass the alarm/immobiliser on a public forum(u never now whose looking )hope someone can help with your original problem.
muppet is offline
post #3 of 49 (permalink) Old 29-03-2005, 20:57
Car: MG 6 GT
When mine played up, I called the RAC who overrode the alarms for me, so it is possible, but they of course would not tell me how to do it!
I had to drive it straight to MG Rover to get sorted out - luckilly it was just the fob battery so it didnt cost too much.
SFulcher is offline
post #4 of 49 (permalink) Old 29-03-2005, 21:16
Tad
when you have this problem again, you must enter the code several times, it doesnt work everytime! also try doing with the doors locked, then with doors unlocked, try all kinds of situations, it works.
heh sorry SFulcher, but you went all the way and payed rover to have your fob battery changed?! lol
Tad is offline
post #5 of 49 (permalink) Old 30-03-2005, 06:44 Thread Starter
Car: Please Select
If anyone does know a way, could they email me? Cheers.
post #6 of 49 (permalink) Old 30-03-2005, 07:00
Unhappy
i have a similar problem with my zr, i always unlock with the fob, but sometimes i get in and the imobiliser is on and it starts to beep at me,???? sometimes its just a case of taking the key out and trying, but other times i have to get out the car lock it and un lock it a couple of times before it will start any ideas
thanks
mgzr24 is offline
post #7 of 49 (permalink) Old 30-03-2005, 07:32
Car: Silver Stormer ZR turbo.
15Peter20 I doubt you would have a manual key code if there wasn't supposed to be a fob with it.
I would contact Rover and tell them you may be interested in buying a key fob from them (this is just to get them to help you) ,but you need to know if it requires one. They should then be able to tell you from your registration.
If they do say you need one then get one of Ebay for a tenner and then ask Rover to program it for 25-35.
thanks
Yep my girlfriends brother's ZR does this also. You don't need to get out of the car though to lock and unlock it. It will still work from the inside.
ashy is offline
post #8 of 49 (permalink) Old 30-03-2005, 09:10
yes i had a 220 without remote locking but it still came with a fob to turn the immobiliser off automaticaly and also came with a keycode.
ian
muppet is offline
post #9 of 49 (permalink) Old 30-03-2005, 10:00 Thread Starter
Car: Please Select
What about finding the wire to the immobiliser and cutting it? Would that work at all?
post #10 of 49 (permalink) Old 30-03-2005, 11:41
No.
The imobiliser has to send a code to the engine ECU, which is programmed and unique for each imobiliser/ ecu combination, before it will start the car. If you unplug it, you will never start the car.
kiwi216 is offline
post #11 of 49 (permalink) Old 30-03-2005, 12:42 Thread Starter
Car: Please Select
What about trying to override it using the universal remote control for my telly?
If I do manage to get it working again, is there any simple way of completely disabling it for the future, so it never ever happens again ever?
post #12 of 49 (permalink) Old 30-03-2005, 13:46
Why don't you just do it the right way and get yourself a proper key fob instead of faffing about.
You need a fob simple as that. Rover will program it for you and then all your problems should be solved. There is an advantage to having an immobilser.
ashy is offline
post #13 of 49 (permalink) Old 30-03-2005, 13:58
Car: Mazda RX-8
jonspurs is offline
post #14 of 49 (permalink) Old 30-03-2005, 14:43
Rover made the cars difficult to steal for a reason!!!!!!!!!!
If there was an easy way round it, then there would be no point having an imobiliser.
Only thing you can do is fix it properly.
kiwi216 is offline
post #15 of 49 (permalink) Old 29-07-2005, 14:32
I have the same problem i have been told by a Rover dealer i cant get the code as the factory has now shut so how the hell am i suposed to disarm the immoboliser.
Anyone nice enough to help me start my car.
B-R-A-D is offline
post #16 of 49 (permalink) Old 29-07-2005, 16:07
The dealer can get the code using T4.
They plug in the car to the T4 box of tricks and read the code from the immobiliser ECU.
cjmillsnun is offline
post #17 of 49 (permalink) Old 29-07-2005, 17:40
Car: MGF MK2 1.8i,BMW 330i
Hopefully I wont offend anyone but is it just me who thinks it is strange all these new members with poor excuses asking how to override immobilisers
And here is another!!
immobiliser code
Broon is offline
post #18 of 49 (permalink) Old 29-07-2005, 19:29
immobiliser code
The only reason i am a new member is that i found this site when i was trying to find out how to get car manual for my car to my suprise Hayes do not even publish one yet so before i lose my rag with what you are trying to say about all newcomers i will say just this, you yourself was a newcomer at one point so try and be a little simpathetic with us who can't find out information any other way.
B-R-A-D is offline
post #19 of 49 (permalink) Old 29-07-2005, 19:38
No...thats where your big problems would begin!
post #20 of 49 (permalink) Old 29-07-2005, 21:06
immobiliser code
I know where you're coming from, however I personally feel that if enough information is given for genuine people to find help, without compromising the security of people's vehicles, then we are doing the right thing. With the demise of MGR there are going to be owners who would have previously gone to dealers for advice who now find that either their dealer has closed or has changed franchise and doesn't want to know about MGR cars. Who are they going to turn to... In all likelihood us. We should help where we can.
Alarm/Immobiliser sturose 'R8' Rovers (aka Wedges!!) 11 26-12-2008 22:26
No factory alarm/immobiliser JDawson MGF and MGTF (Sponsored by MGFnTFBITZ) 3 15-06-2008 19:19
Bypassing the Immobiliser? Nix MG ZR / Rover 25, 200 & Streetwise 10 13-03-2007 19:56
alarm/immobiliser bypass adamh Metro / Rover 100 2 13-07-2006 21:56
alarm immobiliser hardmonkeys MGF and MGTF (Sponsored by MGFnTFBITZ) 6 07-07-2006 19:13
