vvc hydraulic mech housing - MG-Rover.org Forums
post #1 of 4 (permalink) Old 19-06-2016, 12:30 Thread Starter
Car: Rover 200 BRM
Send a message via AIM to Kruger1
Is it possible to remove the upper part of the vvc hydraulic mech by taking out the 3 bolts then lifting it up enough to add some gasket maker, then re bolting it back down. or does the timing need to be set and it done the right way? i have small leaks between the base plate and upper housing front and back.
Kruger1 is offline
post #2 of 4 (permalink) Old 04-09-2016, 15:08
Car: MG ZR T16 Turbo
Did you find an answer to this question? Have the same leak myself
t16tony is offline
post #3 of 4 (permalink) Old 24-09-2016, 13:36
Mmmm....Rover..
technozen's Avatar
The HCU housing can be removed after unscrewing the 3 retaining bolts.
Remove the oil temperature sensor first and expect quite a bit of oil to escape when the top section is removed.
The HCU base plate is sealed with a shaped black seal on either side, if you are not renewing them and just adding
sealant use it sparingly as you don't want to block any oilways.
technozen is offline
post #4 of 4 (permalink) Old 24-09-2016, 16:05
There is 2 seals for the unit unfortunately the lower one isn't available without buying the housing. If you remove the housing tho you have to set the plunger and vvc hubs into service position
JOHNDQ is online now
VVC Mech MG FT carlosibar MGF and MGTF (Sponsored by MGFnTFBITZ) 3 02-12-2015 16:08
Clutch Pedal Housing and hydraulic line ... Hsing-ee Rover 600 14 29-12-2013 11:47
vvc mech Giorgio80 Wanted 1 18-06-2013 18:52
VVC Mech bazz1955 MGF and MGTF (Sponsored by MGFnTFBITZ) 12 21-10-2007 23:17
VVC Mech Darklore3003 Wanted 4 06-07-2006 12:06
