620 abs - MG-Rover.org Forums
post #1 of 3 (permalink) Old 01-02-2017, 14:45 Thread Starter
Unhappy 620 abs
Rover 620, 1997. ABS warning light stays on dashboard. Local garage has obtained fault code 23 from the ECU (not a flash code) but does not know what this means. Any ideas would be appreciated.
jaybe is offline
post #2 of 3 (permalink) Old 01-02-2017, 16:21
ABS ECU and engine ECU are not the same. From where you got this reading of fault code 23? If that is from engine ECU by diag software that does not probide info of ABS problem. Code 23 does not mean much to me either from list of ABS codes.
ABS error code needs to be read by number of flashes of ABS light when you use shorting clip on ABS connector in the car.
Roverlike is online now
post #3 of 3 (permalink) Old 01-02-2017, 21:08 Thread Starter
Unhappy 620 abs
Thanks Roverlike.
I'll try for more information from the garage as it seems that they do not fully understand the diagnostics on the car. This happens a lot with older vehicles and it's difficult to find anyone with the necessary knowledge.
Regards, jaybe
jaybe is offline
620 '93 ABS Pump Acid_Drinker Wanted 6 27-07-2010 02:07
620 ABS Problem r44heli Rover 600 10 01-02-2010 23:34
Where are my ABS relays?? (620 TI) tommydp Rover 600 0 05-02-2007 13:34
620 SLI ABS Again skydiveaz Rover 600 1 16-08-2005 16:53
620 Abs Phil-ti Rover 600 3 17-06-2003 13:03
