620ti rev issue - MG-Rover.org Forums
post #1 of 2 (permalink) Old 04-02-2017, 14:17 Thread Starter
Car: TURBO INJECTION
620ti rev issue
Hi guys and girls bit hard to explain but to the turbo out yest and when I hit boost hard and then come off the throttle my revs hold. They won't drop until I blip the Throttle any ideas ad gotta make a journey from Kent to Blackpool as am moving in the next week. I was thinking poss the stepper motor because that don't shut down for few min after I turn car off
rover620_ti is offline
post #2 of 2 (permalink) Old 05-02-2017, 14:50
Air leak on the joint from the throttle body to the inlet manifold. Reasonably common especially if the engine mounts have given trouble previously.
Also try a stepper motor reset as that may help
Turn ignition on - but don't start car
Depress throttle fully and release it 5 times within 5 seconds
(You should now hear a quite chuntering noise from the stepper motor)
Once this has stopped after a couple of seconds start car
Idle may wander about for a few seconds but should then stabilise.
Rover 216 1997 Rev issue please help! xX_o2_Xx MG ZR / Rover 25, 200 & Streetwise 12 27-01-2016 19:57
rev counter issue paynemgzr MG ZS / Rover 45 & 400 2 20-06-2014 13:12
Rev issue j0rdanf1 MG ZR / Rover 25, 200 & Streetwise 2 30-11-2009 19:53
First Proper 620Ti issue.. SteveR Rover 600 6 19-02-2007 21:52
Rover 620ti - MEMS ECU rev limit raise Manos-620ti Rover 600 14 26-10-2006 20:00
