Clutch slave cylinder burst seal without warning. - MG-Rover.org Forums
post #1 of 9 (permalink) Old 13-04-2012, 17:06 Thread Starter
Car: Rover 620Ti, 12 psi boost.
Was driving the Ti today, everything was good, nice sunshine, driving
nicely and as I was approaching the lights I decided to downshift to third
gear, clutch down, gear crunched as I attempted to select it. I thought I
hadn't timed my left foot incorrectly, as I decided to step down again,
clutch pedal was down, oh dear. I bend down and brought it up using my
left hand, as the car was still in motion, step on the pedal, down it went
and remained there.
The traffic lights had changed red and I had to stop. Lights changed green
and I managed to select first gear with a tiny crunch, no clutch, pedal on the floor, engine was still running
and there was a kwickfit a few yards to my left and I rolled in there with my
hazard lights on and the car kangarood to a halt as no clutch and engine
stalled as I applied the brakes. My first
fear was that may be the clutch arm on the gearbox had snapped as this has
happened to a few Ti but I observed the arm and it was ok and the
slave was weeping hydraulic fluid. I went and asked the kwikfit guys for
some dot 4 brake fluid and they gave me some for free. The fluid just leaked straight out of the burst slave cylinder seal. I have no breakdown cover as I trust my cars so I had to go home with no clutch. The kwickfit guys were insisting it was the clutch disk , I told them no, it is the slave. However, they told me a nice trick which is to select second gear with engine off then start with starter motor. I did that, car kangarood a bit off course, a little pressure on the accelerator and I went on second gear . Sods law I had to pass a few traffic lights and one was red, I stopped, engine of course stalled. I started her on first gear this time, it started, then rev matched and managed to select second then third without clutch and withougt crunching, adrenaline brought the expertise I guess. I managed to guide her home. I have already removed the slave and will be collecting one for only 31 from unipart. http://www.unipartautomotive.co.uk/Hydraulics/Clutch-Hydraulics/Rover-600-Series-620-2.0-1997/Parts.aspx?SubGroup=HY~Hydraulics~CLUH-HY~Clutch+Hydraulics
Their website says 36 but I phoned the shop and they told me it will cost
me only 30. I get it tomorrow. Here is the Ti' knackered clutch slave,
took me only 15 minutes to remove.
Here is the clutch slave with burst seals.
This took me by surprise, it burst without warning, I check the fluids
weekly and the clutch fluid was ok. The morale of the story is to learn to
shift without using the clutch it may come useful one day. I am rather impressed that I managed to go up to third gear without crunching with no clutch even though it is a misery to have the clutch hyrdraulics go on you. Starting from a standstill at the lights I just switched off the engine, selected first, then used the starter motor. Car kangarooed but started, people thought I was a learner
Anybody who needs or might need a clutch slave cylinder for the Ti, get it from Unipart as they are selling it for only 30, I was surprised and asked on the phone if that price is for real and they said yes.
denis747 is offline
post #2 of 9 (permalink) Old 13-04-2012, 17:11
Well done Denis!!
post #3 of 9 (permalink) Old 13-04-2012, 17:18 Thread Starter
Originally Posted by roverlike View Post
Well done Denis!!
Thanks, good to learn from these experiences
denis747 is offline
post #4 of 9 (permalink) Old 13-04-2012, 17:28
Car: Rover 600
You could have always got home in reverse all the way!
rov618i is offline
post #5 of 9 (permalink) Old 13-04-2012, 17:32 Thread Starter
I was happy to get home and stall it, using the brakes, on my driveway I stalled as it is a tight curve to get into my drive and that speed is too slow for second gear, luckily the drive slopes downwards and i just rolled it to position.
denis747 is offline
post #6 of 9 (permalink) Old 14-04-2012, 11:20
Car: 618i '96
Well done, doubt if I would attempted it. Did you give the Kwikfit guys a tip ?
devon is offline
post #7 of 9 (permalink) Old 14-04-2012, 11:43 Thread Starter
Thanks Gordon , I am planning to go give them something small, to thank them, after I have fixed it. It is good the rains have stopped.
denis747 is offline
post #8 of 9 (permalink) Old 14-04-2012, 13:30
Car: 618i '96
Talking
I was thinking more of .. OrganisedConfusion or my tyre place cheerful chappie always says .. Hello Bud.. - posted before Grant Nat started. (and no I haven't bet on them)
devon is offline
post #9 of 9 (permalink) Old 14-04-2012, 15:31 Thread Starter
Fixed
Yes I went to them, to say thanks for the brake fluid they helped me with yesterday and they asked what it was as, obviously, they saw the car coming in and reversing into the parking space. I told them it was just the slave cylinder and they asked how much that cost me. I said only 31.50 and that I fixed it myself.
Such a difficult system to bleed, the Ti clutch. I was pumping using my hands for ages and no resistance on the pedal whatsoever. I almost got scared that the master cylinder was bad, but it wasn't, just needed faster pumping. I then increased the frequency of my pumping strokes and after about 30 strokes the pedal started becoming firm. I noticed the gears are much more easy to select now especially second gear which used to be notchy when the old slave cylinder was there. I used a one man bleed system, very firm clutch pedal.
denis747 is offline
How to:Change the Clutch Slave cylinder seal zipimini MGF and MGTF (Sponsored by MGFnTFBITZ) 28 11-11-2016 14:19
Can I change the clutch slave seal from under car? Benfinlayson MGF and MGTF (Sponsored by MGFnTFBITZ) 5 26-08-2011 04:40
Clutch slave cylinder seal kit gotenks1321 MGF and MGTF (Sponsored by MGFnTFBITZ) 6 20-02-2011 22:49
Clutch Slave Cylinder gary-t MG ZS / Rover 45 & 400 2 08-12-2010 19:30
clutch-slave cylinder,master cylinder cost kumala MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 28-01-2010 16:48
