crank sensor - MG-Rover.org Forums
post #1 of 7 (permalink) Old 02-06-2008, 21:03 Thread Starter
Car: 620ti/landrover discovery
crank sensor
hi all how are you,must be better than me an my ti! could someone please tell me where the crank sensor is on my 1997 ti as she is still a bit of a pain to start an rev counter drops to zero sometimes when i slow down for junctions etc it didnt show up as a fault so thought i might clean it before i replace it a photo would be very helpful if anyone has one as i am a bloke and struggle to follow directions (ask the missus she will confirm) thanks everyone
ti charlie is offline
post #2 of 7 (permalink) Old 02-06-2008, 21:17
Its in the same gerneral place on this picture of a K-series 16v as the T-series.
Are you sure its this though? In my experience if they fail, its either it works or doesn't. No half way.
MetroMartin is offline
post #3 of 7 (permalink) Old 02-06-2008, 21:57 Thread Starter
no not sure its the problem but not sure what else to do as rev counter drops to o thanks for picture thats great
post #4 of 7 (permalink) Old 03-06-2008, 22:07
MGJohn's Avatar
Here's a view of the Vitesse T16 Gearbox adapter plate showing the location of the crank sensor ~ it's the black object at about 2 O'Clock in relation to the centre line of the crankshaft ~ approximately in the same position as the one on the K ~series as shown in that one's picture;
HTH.
B>>M>>W ....
MGJohn is offline
post #5 of 7 (permalink) Old 04-06-2008, 15:14 Thread Starter
Unhappy
well i clesned the crank sensor and tightened it up as it was very loose but no better
post #6 of 7 (permalink) Old 05-06-2008, 11:36
Could be a weak battery or a duff alternator. Mine went like this and cut out if I went above 3-4k rpm. My alternator had kinda half died. If this is simular it might be worth checking this.
post #7 of 7 (permalink) Old 06-06-2008, 08:10 Thread Starter
Wink
i will get it checked but it doesnt cut out on high revs an battery is off my old diesel cav so its a biggun an i have had battery from new thanks for the tip
Crank Sensor lewisparrott MG ZT / Rover 75 (Sponsored by Rimmer Bros) 4 10-08-2008 21:24
New Crank Sensor or not????? zedler MG ZR / Rover 25, 200 & Streetwise 5 02-04-2008 13:53
Crank Sensor CJJ MGF and MGTF (Sponsored by MGFnTFBITZ) 2 28-02-2007 21:12
Cam sensor/ Crank sensor Barryboy MG ZT / Rover 75 (Sponsored by Rimmer Bros) 1 05-06-2006 11:59
crank sensor Nobel Others 3 11-05-2003 08:32
