Late 600 Valeo remote fob button replacements. - MG-Rover.org Forums
post #1 of 7 (permalink) Old 23-05-2016, 11:59 Thread Starter
I finally managed to acquire a late 1999 V plate BRG Ti and am in the process of sorting a few jobs. One thing I need is new buttons for both remote fobs, they still work if you use your finger tip in the hole, but I really want some decent replacements. I've seen some on e-bay but they don't look great, has anyone experience of them or know of the best source for them.
Also, I once owned a nearly new 618is with a factory fitted bodykit, with side skirts and a boot spoiler which I believe was an SMC kit. Would quite like to get hold of a boot spoiler like that one, does any one have one they don't want, or know where I can lay my hands on one?
SD1 3500 is offline
post #2 of 7 (permalink) Old 24-05-2016, 20:39
I got some decent second hand fobs from ebay so they do pop up every know and again
Andy ti is offline
post #3 of 7 (permalink) Old 29-05-2016, 09:09 Thread Starter
Thanks Mate, I'll keep looking. I was at a Rover breakers in Morecambe yesterday collecting some bits and clean forgot to ask if they had any old fobs with decent buttons.
SD1 3500 is offline
post #4 of 7 (permalink) Old 19-06-2016, 15:42 Thread Starter
I managed to get some new buttons from Ebay, they look fine and only took minutes to fit. Only trouble now is one of the fobs will no longer operate the locking on the car. Both red and green leds light, it just seems to have lost sync with car for some reason. I followed the same procedure for each, as in after splitting the cases discharged residual voltage by pressing both buttons several times,so at a loss as to what's gone wrong.
I'm positive I've used both fobs previously and that they both worked, albeit without outer button covers. Can anyone offer any suggestions, as to whats gone wrong and what I can do to get it to work again?
SD1 3500 is offline
post #5 of 7 (permalink) Old 19-06-2016, 15:52
What I could suggest is to inspect fob elements on printed circuit board to see if you have any cold joint or crack in soldering.
Otherwise this could become a problem because if fobs somehow lost sync that far in case of R600 I never found that anybody offered solution how to resync them again and make them work again. R600 have different RF fob system then the other Rovers.
Roverlike is online now
post #6 of 7 (permalink) Old 16-07-2016, 13:41 Thread Starter
I have just found a card attached in rear of service book with Valeo, the part no.YWX100450 and a pair of different barcodes and numbers printed on it. I assume these are the barcodes for the remote fobs that I would need to resync my spare fob, if so I assume it has to be done by someone who has dealer level diagnostics, such as testbook or similar?
SD1 3500 is offline
post #7 of 7 (permalink) Old 16-07-2016, 20:47
Yes, that could be a barcodes of your remote needed for programming them to your system. You need some dealer who still have Testbook software available for programming on Rover 600 cars.
Mk2 3-button remote fob - replacement rubber button cover? patpending MG ZS / Rover 45 & 400 26 27-01-2014 19:37
620 ti remote locking fault-valeo type fob richy59driver Rover 600 7 18-12-2012 22:37
Rover 600 Valeo key fob sasbifan Rover 600 6 29-12-2010 22:53
Valeo 2 button fob, button replacement? Ray_S Rover 600 9 24-08-2009 20:10
Valeo 2 button fob for spares and repairs Ray_S Wanted 0 27-04-2009 21:51
