PG1 selector shaft play - MG-Rover.org Forums
post #1 of 2 (permalink) Old 05-04-2017, 19:13 Thread Starter
Car: mgtf 135 trophy, Rover 800 Coupe 2.0 Turbo, Rover 800 MK1 Vitesse, Rover 620 Ti
Hi guys,
Does anyone know of a fix for the play that I have from the linkage onto the selector shaft on my 620ti please.
I bought a mumby developments nylatron kit along with the poly bush kit for steady bar but have noticed while fitting this kit that I have vertical play on the linkage where the roll pin fits to the shaft which looks to be the cause of most of the play I was feeling Doh! or has anyone got a good linkage UJ that they are prepared to sell.
I dont think there is wear on the shaft as the metal on the linkage appears to be softer and more likely to wear as its a hole rather than a solid bar.
thanks in advance.
rover 64 is offline
post #2 of 2 (permalink) Old 18-04-2017, 21:38
Are you happy to bodge it?
If so I can tell you how I've done mine.
I too found most of the play in the pin rather than the linkage.
What I did was remove the roll pin (after much swearing!)
Use a high tensile nut and bolt instead I think it is M6 or M8. Please check!. I think I had to run a drill through to allow it to fit snugly.
Sadly because of the way the 600 linkage is, you can't crush the tube onto the gearbox rod (as you can with all the others in the 200/400/600/maestro/montego), because the metal linkage is too strong. So what I did was to disc cut a slot through it at 90 degrees to the bolt holes to allow it to deform under pressure. This allows me to use the nut and bolt to clamp the gear linkage tube onto the gearbox rod eliminating slack.
Another option is to cut the linkage off and weld on a new one, but if you already have a good condition linkage then you'll probably not want to do this.
Pg1 selector pengy_666 Wanted 7 27-06-2014 20:10
Gear Selector PG1 StuBlake13 MG ZR / Rover 25, 200 & Streetwise 4 28-10-2009 08:53
PG1 selector rod only skrib Wanted 0 28-11-2008 06:13
PG1 Selector shaft andymitton Wanted 1 18-09-2008 16:01
Rover 200 Gear selector shaft andymitton MG ZR / Rover 25, 200 & Streetwise 1 11-08-2008 15:22
