Rover 600 - FAQ's information - MG-Rover.org Forums
post #1 of 72 (permalink) Old 17-11-2006, 21:55 Thread Starter
Hi all, as i also own a 600, i thought it would be a good idea to list together the common issues with the 600 range, for owners by owners sort of thing.
If people can list a usual problem with an answer it would be excellent, as i can compile a list and then put a structured closed sticky at the top of the page for people to see.
Or if someone has a how to guide, i can put these up as well, anything counts! good if your technically minded
Please feel free to post them up, (useful information only please). If anyone has any info or questions etc.. contact me anytime.
Regards
Stu C
Stu C is offline
post #2 of 72 (permalink) Old 18-11-2006, 01:33
Car: Rover 600
sounds like a good idea
jasonc46 is offline
post #3 of 72 (permalink) Old 18-11-2006, 15:53
Car: Volvo S60 R, Rover 25 1.8Auto, VW Passat TDi Estate (Until I get rid of it)
Send a message via MSN to santa20
Only major problems I've had with my Ti is a broken gearbox and broken turbo.
The Gearbox is a common issue isnt it?
santa20 is offline
post #4 of 72 (permalink) Old 18-11-2006, 17:34 Thread Starter
Sure is had mine rebuilt at 100k miles, as well as the Clutch master and slave cylender replaced!
Stu C is offline
post #5 of 72 (permalink) Old 20-11-2006, 13:01
Common problems:
Window mechanisms - they bend and break. Keep the window rubbers well lubricated with rubber lubricant to stop it happening.
Aerials don't extend/retract fully - Clean the aerial mast with solvent - NO LUBRICANT to be used on them. Masts are cheaply replacable - Rover/Xparts or E-bay.
post #6 of 72 (permalink) Old 22-11-2006, 19:46
Car: nissan skyline
brakes!!!
the worst design ever!! it took me a week to change them. however i should have got all the parts first and gone straight to a garage to press the new bearings rather than try with a 2lb hammer and a cloth!! lol.
if a "how to" is required i can do one? i have plenty of pikkies!!
oh i did the rears too if your interested? ( easy peasy by comparison though!! lol )
i did this unintensionally but its recommended NOT to change all 4 brake discs and pads at the same time . this is for bedding in purposes. they will be quite useless for 100's of miles, particularly performance or "fast road" style set ups.
RED-ROVER-Ti is offline
post #7 of 72 (permalink) Old 22-11-2006, 19:50
Car: nissan skyline
i have a few pikkies of reconing the gearbox too!! they aren't very good as such but with plenty of literature could be useful?
i have since all this, bought a £200 camera which is sooo much better for that stuff.
post #8 of 72 (permalink) Old 22-11-2006, 19:53
Car: nissan skyline
sorry to post whore but....
the interior light switches on all 4 doors are prone to fail. very common on eBay so sourcing them is a doddle
also the rocker cover gaskets fail often too. usually in the right hand corner.
post #9 of 72 (permalink) Old 22-11-2006, 22:01 Thread Starter
Please do, if you make one up, post it up, and i will put together some sort of sticky thread with them in
And no your not a post whore lol, and information is grately received. What i will do is like in the diesel section, ill compile loads of information, tidy up the thread and have a main FAQ at the top for everyone.
Also a problem, not sure if its common, when we first had ours, if you turned the key to far in the barrell it sometimes stuck the alternator knocking out the electrics....
And the handbrake is a problem as well, with the caliper and the spring for the handbrake tightness, i.e. usually goes very crap, and fails to hold the car on anything steeper then a pebble
Stu C is offline
post #10 of 72 (permalink) Old 23-11-2006, 20:03
Car: nissan skyline
okey dokey mate! i will try and write it up over the weekend.
i shall post it in this thread, is that ok?
post #11 of 72 (permalink) Old 23-11-2006, 21:05 Thread Starter
Err, if you make it a new thread, i can put all the "how to"'s in one section, and sticky it
Stu C is offline
post #12 of 72 (permalink) Old 26-11-2006, 16:57
Car: nissan skyline
new thread made!! its in this section..... Rover 600 - How to - Brake guide
post #13 of 72 (permalink) Old 26-11-2006, 20:12 Thread Starter
Great thank you
Stu C is offline
post #14 of 72 (permalink) Old 27-11-2006, 17:53
Car: nissan skyline
no probs! if it helps just one person out its worth it.
can you sticky this too? Rover 600 - Make your own vacuum bleed kit
it saved my life when i fitted the new clutch! we had no idea what to do until we found out about this!
now i can replace the entire brake fluid system in about 20 minutes without even taking the wheels off!!!
post #15 of 72 (permalink) Old 27-11-2006, 18:12 Thread Starter
Yeah done and done I assume its for the turbo models only then with the vaccuum, and flow etc...
Stu C is offline
post #16 of 72 (permalink) Old 27-11-2006, 18:24
Car: nissan skyline
as far as i know, but if a nasp car had a vent to connect to that sucked also i suppose it could work?
maybe someone could find out?
post #17 of 72 (permalink) Old 27-11-2006, 22:54
All petrol engines will produce a vacuum on idle.
Diesel engines won't though.
post #18 of 72 (permalink) Old 27-11-2006, 23:47
Car: Punto/saxo,others.
Send a message via MSN to mickh
had a problem with sticking valves ,thats about it.took the risk and did the 'italian tune up'..bang on now.
mickh is offline
post #19 of 72 (permalink) Old 03-12-2006, 12:48
Car: 620 di 1997
Window sliding out of runners
Windows sliding out of runners:
Simply spray the rubber runners with Simonz back to black spray many times. (No need to replace window mech/motor/etc)
hfz_3 is offline
post #20 of 72 (permalink) Old 13-12-2006, 19:51
Car: Rover 600
Hi there..I found a cat converter replacement on ebay. will give 8+ HP they say.Can you give me an advice about this? My Rover 600, 97 model, 1.8 lt. has more than 100k miles on meter. My problem is, it has a less trottle response. I change my spark plugs with twin cathode split fire brand from U.S.new leads,new distributor cap,I use semi synthetic oil,new air filter,new petrol filter,It is better than before but has a power like a 1.4 engine.Is there anything I can Do to improve my car performance? thank you.
roverkoto is offline
Gear Oil FAQ's oilman MG/R Modification & Tuning 2 09-09-2008 12:18
Coupe FAQ's Stu Coupe 22 06-02-2008 20:49
Oil Recommendations.. Couldn't find in FAQ's SteveR Rover 600 7 19-02-2007 22:09
Rover SD1 information rwproverv8 Others 3 08-03-2006 20:18
any information on a n reg rover 416i simp Others 1 15-08-2005 19:45
