Rover 620 SLI 1996 - MG-Rover.org Forums
post #1 of 3 (permalink) Old 13-01-2006, 20:07 Thread Starter
Car: Rover 600
Post Rover 620 SLI 1996
After I broke the catch on the door housing (the catch that allows the alarm to set when you lock the car) before I had a chance to replace it, the battery went flat. Since replacing the battery when I start the car the SRS warning light stays on, and the radio just has `wait` showing rather than asking me to type in a security code. Does anyone have any suggestions what i might do. Thanks
GaryS is offline
post #2 of 3 (permalink) Old 13-01-2006, 22:30
Car: Rover 600
Someone may want tocorrect me on this but try disconnecting the battery negative lead and remove the battery back up fuse for 30 mins then re-connect. this may or amy not turn off the SRS light but should ask for the radio code to be entered allowing the radio to work again. If the SRS light doesn't go out then try doing a search.
JoeyD is offline
post #3 of 3 (permalink) Old 14-01-2006, 15:06 Thread Starter
Car: Rover 600
Rover 620 SRS Problem
had to go to the Rover Dealer today. They ran some tests and reset the SRS and the radio. A Solution but cost me nearly 40 quid.
Thanks for the advice though
GaryS is offline
Rover 216 Sli 1996 GEORGINA MG ZR / Rover 25, 200 & Streetwise 3 19-07-2011 21:45
Some bits required Rover 216 SLi 1996 gonzomagic Wanted 0 11-06-2007 09:16
HELP!! what to look out for on a 1996 Rover 216 Sli rossyl MG ZR / Rover 25, 200 & Streetwise 1 22-12-2005 21:35
1996 Rover 416 SLI Tourer For Sale montyturbo For Sale 4 10-03-2003 16:57
rover 416 sli 1996 n reg basic questions petergray MG ZS / Rover 45 & 400 1 01-09-2002 12:26
