Rwd 600? - MG-Rover.org Forums
post #1 of 7 (permalink) Old 04-01-2017, 18:16 Thread Starter
Car: Rover 600 2.0 Si, Rover 75 2.0 V6 Connoisseur SE
Question Rwd 600?
Before I go and buy a Vauxhall Calibra, has anyone converted a Rover 600 to RWD?
Kinversand is offline
post #2 of 7 (permalink) Old 04-01-2017, 18:18
You can buy Rover 75 V8 or ZT V8, and you will get RWD....
post #3 of 7 (permalink) Old 04-01-2017, 18:23 Thread Starter
Rwd
I already have a 75, and a BMW 3 Series - I was asking if anyone had converted a Rover 600.
post #4 of 7 (permalink) Old 04-01-2017, 18:58
Not that I know of.
I guess it'd be quite a job as you'll need to do a lot of fabrication to accommodate the gearbox, prop shaft and rear axle.
What donor where you thinking of using?
post #5 of 7 (permalink) Old 04-01-2017, 19:19 Thread Starter
Talking Rover 600 RWD
Hi, many thanks for you reply.
I must confess that I haven't yet given it a huge amount of thought - hence the Vauxhall Calibra comment: They can be converted easily, as certain models were 4WD, but I'd rather convert a Rover 600 as they aren't as old or anything like as prone to rot as an old Vauxhall/Opel!
It's the choice of rear axle and getting the drive outboard to the rear wheels that is the difficult thing more than mods to the tunnel, as once the exhaust pipe is moved, there's plenty of tunnel in which to put a propshaft. The question of space for a gearbox isn't a huge issue as I only need room for an electric motor as I'm planning a conversion to electric power: All the style and comfort of a Rover 600, with no dependency on oil.
Thoughts observations and advice welcome.
Cheers,
Dave.
post #6 of 7 (permalink) Old 04-01-2017, 20:14
If you are going for an electric power plant I'd keep the drive at the same end as the power plant.
post #7 of 7 (permalink) Old 04-01-2017, 20:44 Thread Starter
600 rwd
The thinking is that with the diff driving the rear wheels, the motor itself can be put in the tunnel thereby improving weight distribution and leaving the engine bay clear of transmission components, leaving more room for batteries, the inverter and other components.
R8 214 rwd v8... SnapdragonGT 'R8' Rovers (aka Wedges!!) 3 18-09-2011 08:55
RWD L-series Disgusted Diesel Forum! 13 17-07-2010 21:40
Rwd?? M-chaps MG ZS / Rover 45 & 400 15 15-06-2010 19:15
620Ti RWD coozer Rover 600 1 26-05-2006 22:22
Rwd Zr elise MG ZR / Rover 25, 200 & Streetwise 1 21-01-2006 12:53
