T-series thermal gasket - MG-Rover.org Forums
post #1 of 1 (permalink) Old 11-10-2008, 14:27 Thread Starter
Car: Rover 200 Coupe
I've been gathering interest in another part of the forum about the thermal inlet gasket. I just wanted to tell you T-series boys that it is available for you aswell! It is made of a phenolic plate and it keeps the inlet manifold cooler. This leads to lower intake temps and you know what this means. For every 10 deg drop in intake temp there is 1% extra power. You could expect 2-5% increase.
Hondata make these for the Honda range engines and many others aswell. These are perfect copies made in the same material using proffesional cnc equipment
A well known Rover aftermarket dealer sells these for 60, but I offer them out for 20 p&p. Available is also a throttle body gasket made in the same material. For both: 30 p&p.
Please note: This is not a cheap budget item, it is high quality.
Please ask questions.
Manalishi is offline
K-series head gasket??? Dave turbo Others 12 21-05-2009 16:05
Thermal intake manifold gasket Manalishi Coupe 9 20-10-2008 20:14
random thermal shock crross MGF and MGTF (Sponsored by MGFnTFBITZ) 8 25-01-2008 22:03
Amp goes into thermal overload DAN220SDi In-Car Audio, Entertainment, Sat Nav etc... 38 19-12-2006 19:37
M-Series Head Gasket Sir Mod Others 1 16-03-2004 21:59
