Rover 800 Faulty Remote Controls / Immobiliser Problem and EKA Code! (VIDEO) - Page 2 - MG-Rover.org Forums
post #21 of 24 (permalink) Old 18-11-2016, 19:03 Thread Starter
Car: 1992 Merlin Mountain Bike. Vauxhall Combo Turbo Diesel. Astra Turbo Diesel. Rover 825 V6 Coupe.
Hi I guess that is just the type of thing I am looking for, as I do indeed have a KV6.
I was hoping to sort my problems next week, so your timing is impeccable. Anyhelp is appreciated.
I would be happy with any service/attempt you can try and provide me with. So let me know how and if I should send my car bits to you or if you need the car, or if it is something I can fit myself.
Happy to buy your parts and service, thanks.
Rover V6 Coupe is offline
post #22 of 24 (permalink) Old 15-02-2017, 11:19 Thread Starter
Talking
After speaking to a local owner/collector of 800's the other week, they told me their x-part service center could supply me a new remote so I went ahead and booked the car in.
Just picked up the new remote key this morning & it took no time at all for them to program it in to the car (and they even passed on the codes for the key so that if the car ever needs additional remotes in the future they can be added as extras).
New key is the aftermarket combined key and fob type, but perfectly happy having this type. Key blank was cut to suit my car, unfortunately although it was a perfect copy it works in ignition only (and not doors & boot!).
Had the option simply to remove the blank and carry remote part along with an original key, or carry both an old key and the new key, but decided I wanted to make it work. (even though in most cases I won't need a key for doors/boot now, (on it's own) in emergency the new key would not be able to enter the EKA as it is now!)
Being somewhat of an expert key cutter myself I soon worked out the key was not going in far enough to either the door or the boot which was stopping it from then turning, so I simply extended the channels in the key (only outer channel needs it, but I extended all to match) so that now it works everywhere .
result!Well Happy.
It's nice to have a working remote again.
post #23 of 24 (permalink) Old 15-02-2017, 15:09
Good job done
Roverlike is online now
post #24 of 24 (permalink) Old 15-02-2017, 15:13 Thread Starter
used it a few times today already.
Keep expecting the lights to flash as it's been a while without a remote. Must be getting too used to these Vauxhalls we have!
bypass immobiliser when EKA code doesn't work pauldbeattie MG ZR / Rover 25, 200 & Streetwise 10 05-06-2013 20:12
rover 220sd immobiliser problems. eka code? SeanZR MG ZR / Rover 25, 200 & Streetwise 11 03-04-2013 16:08
Removing the battery and immobiliser/EKA code MattyC Rover 600 15 04-12-2011 15:53
Rover 800 immobiliser problem (P reg 06-1996) Rough_cut_gem Rover 800 4 05-10-2005 12:44
