Engine Map Info - MG-Rover.org Forums
post #1 of 1 (permalink) Old 10-09-2012, 10:04 Thread Starter
Car: RIP Metro, RIP 214SEi, RIP 45 Club TD, RIP 45 Club SE TD :(
Engine Map Info
Hi. I'm trying to set up a decent MPG calculator using DashCommand on my iPhone. I've got access to a few bits of engine data through a generic WiFi OBD2 connector, but they are limited to RPM, MPH, MAP, MAF, IAT, ECT and Throttle Angle.
I think I've got an idea how to calculate a rough instantaneous MPG from this lot, but I need some info on the standard Diesel map - my car is a 2004 Rover 45 Mk2, 103PS.
I'd like a rough table of the full map if possible, or if not, just the AFR or fuel amount at various throttle percentages. I'd be happy with some data just at 0%/1% throttle and 100% throttle for a given MAF value.
I'm assuming that, apart from idle, the fuel cuts off at 0% throttle.
If anyone can point me to a guide as to how the fuelling is worked out, that would be great too. I'm currently assuming it's mainly based on MAF and Throttle %.
Jelibeli is offline
Engine re-map pros and cons grandtourer MG ZT / Rover 75 (Sponsored by Rimmer Bros) 22 10-08-2011 11:40
1996 Rover 420 TD Engine Fusebox Map MattyB15 MG ZS / Rover 45 & 400 2 06-12-2010 05:36
Map Sensor Info mbronsell MG ZR / Rover 25, 200 & Streetwise 0 29-05-2010 14:00
help zs engine info needed please supermum4 MG ZS / Rover 45 & 400 5 24-01-2010 10:24
Engine conversion Info dj_rs MG/R Modification & Tuning 7 11-10-2004 12:21
You may not post replies
