MG Montego Turbo - MG-Rover.org Forums
post #1 of 39 (permalink) Old 27-06-2012, 13:27 Thread Starter
MG Montego Turbo
As i've had a lot of positive comments about my MG Montego EFi I thought I would show you one of my other projects.
This was bought partially stripped and to teach my youngest 'how to' put one together
As bought in Feb 2011
Jeff Turbo is offline
post #2 of 39 (permalink) Old 27-06-2012, 13:31 Thread Starter
It's place in my barn
Engine mostly stripped, various door trim gone as had complete interior
post #3 of 39 (permalink) Old 27-06-2012, 13:38 Thread Starter
I bought a donor MG Montego Turbo for parts as it was mostly complete and stripped it bare
We also made a list of what was needed
Complete replacement wiring loom
Under bonnet
Carb
Plenum
Carb brackets
Heat Shield
Boost Pipes
Spark Plugs
Manifold to oil seperator pipe
Oil seperator to filler cap pipe
Radiator and holder rubbers
Cooling Fan
Expansion Tank
Air filter housing and holder, pipe to slam panel
ECU pipe to carb
All water pipes
Carb cooling fan and pipes
Battery
Plug leads
Bonnet cable and lock
Complete wiring including fusebox
Front strut grey top caps
Rear
Petrol Tank and pipes
Fuel pump
All bolts to hold tank etc
Fuel filler pipe
Rear inner light clusters
Boot lock trim
Rear exhaust box
Interior
Seats
Dash and all brackets nuts/bolts/screws
Gear knob
MG Steering wheel and centre
Indicator stalks
All interior grey trim
All interior light switches on pillars
Speakers
Both rear pillar trim
All interior lights
Body
All door handles
Complete central locking
All screws and rubbers
Offside front and rear outer door top trims
post #4 of 39 (permalink) Old 27-06-2012, 13:42 Thread Starter
The old wiring loom had burnt out so that was the first thing replaced. Trim was scattered all over the barn. Door handles replaced, but these will now be replaced again with red ones, Boot finished off
post #5 of 39 (permalink) Old 27-06-2012, 13:45 Thread Starter
Rear lights on, rear seats in, rear carpet in, fuse box bolted in
post #6 of 39 (permalink) Old 27-06-2012, 13:48 Thread Starter
Nearside rear door near complete, Interior lights in, new rear seat belts in, drivers outer door trim on, passenger outer door trim on.
post #7 of 39 (permalink) Old 27-06-2012, 13:52 Thread Starter
New radiator and intercooler on, air filter on, all coolant hoses on, expansion tank and carb cooling fan on.
post #8 of 39 (permalink) Old 27-06-2012, 13:54 Thread Starter
Carb on, spark plugs in,battery wires tidied up, non cracked dash waiting to go on
post #9 of 39 (permalink) Old 27-06-2012, 14:02 Thread Starter
There's still plenty to do but it's slowly getting there. It's a bit of a jigsaw puzzle and my stash of nuts, bolts, screws etc is gradually going down.
Hoping to put the petrol tank and all piping on next complete with replacement exhaust.
The only real modification will be an electric sunroof that my sons wants, luckily enough I have 3 spare.
The car has cost very little so far to do.
The car was 240 including delivery, the donor was 60 and it was delivered by a friend at no cost, I got back 30 for the scrapped Montego shell so it's only 270 so far and I have a stash load of Turbo parts left over including and engine, gearbox, turbo etc
post #10 of 39 (permalink) Old 30-06-2012, 14:00
Loving it mate, my kind of project, the donor looked like it had been sat for a while but like you say it was full of bits to use, do you have a list of what you need as we may be able to sort you out, E_T_V may be able to help you out too.
Keep the updates coming fella, I love em'.
ROVER-25X is offline
post #11 of 39 (permalink) Old 01-07-2012, 03:58 Thread Starter
Thanks mate
I have everything I need from either the donor car or my stash of spares so it won't cost anymore than the 270 spent on it.
I've just picked up another boot full of new spares from a friend who was emptying out his garage so the space I got from emptying my stash for this car and my digidash has now been filled.
post #12 of 39 (permalink) Old 04-07-2012, 02:10
Fantastic, you know the old saying, "If its free, give it to me"
post #13 of 39 (permalink) Old 25-09-2012, 18:06 Thread Starter
Found some time to work on the day yesterday but it was 2 steps forward 3 steps back. Nothing went right
Hadn't noticed before but the front panel had the centre part cut off so the front bumber had to come off. ALL the bolts were siezed solid but eventually won through. Straight through exhaust was removed including the LOUD rear box, the front downpipe was also removed as it was not at it's best but in doing so 2 studs snapped on the turbo exhaust elbow so that had to come off. When trying to connect the throttle car I noticed that it had been cut, no idea why so I had to replace that. Lost one of the boost pipes and couldn't find my fuel pipe that i had bought to replace the petrol tanks fuel pipes so that didn't go on. Re-wired the fuelpump as the wiring again had been cut and attached a replacement fuel pump.
post #14 of 39 (permalink) Old 25-09-2012, 18:11 Thread Starter
Left to do
Replace 2 studs on the turbo flange and re-connect
Fit complete exhaust from my spares
Find my lost petrol pipe and attach the petrol tank, pipe to fuel filler pipe and attach fuel filler pipe.
Attached all HT leads
Find my lost boost pipe
Attach replacement bonnet
Attach replacement front panel
Re-attach front lights etc, grill
Re-connect carb
Put petrol in it
Connect battery and see what happens with fingers crossed
IF its goes etc, put the dash in,
Connect both front door electrics, connect a few wires, check to see if all works.
Do headlining
Put front carpet and front seats in
Hopefully should be done then and ready for its MOT
post #15 of 39 (permalink) Old 25-09-2012, 18:21
Car: MGZT pbt derv
Looks fantastic mate, look forward to seeing it finished
How do you fancy coming down to a regional East Anglia meet sometime, show off the other Monty you have
Dave
Dave is offline
post #16 of 39 (permalink) Old 25-09-2012, 19:05 Thread Starter
Dave
Thanks, and which one? i've got 5.
post #17 of 39 (permalink) Old 25-09-2012, 19:41
Bring them all lol !
On the bottom of the rear door car I spotted a vent and some kind of a blank next to the right of it, would that be for a standard fit interior light ?
post #18 of 39 (permalink) Old 25-09-2012, 20:05
Thats the ashtray.
post #19 of 39 (permalink) Old 25-09-2012, 21:39
Cool, bit low isn't it ?
post #20 of 39 (permalink) Old 25-09-2012, 22:04
MGJohn's Avatar
As a matter of interest, this is what Monty Turbo D155 JME looked like in previous ownership with a personal plate on it :~
The dash in it was removed from my 1990 Montego EFi which was not cracked or split.
That was about ten years ago. Be nice if it ever returns to that sort of condition.
EDIT to add ...
Or, am I confusing it with another car? ...
Maybe one of those others. I had five at one time. Can't keep 'em all on the go. Now have just the one.
B>>M>>W ....
MGJohn is offline
Another MG Montego Turbo! Jumturbo Others 3 19-01-2011 21:00
Dutch MG Montego Turbo Jeff Turbo Others 2 14-10-2010 21:34
mg montego turbo help!!!!! stormboy1uk Others 2 08-08-2010 17:59
mg montego turbo autofitservices Others 16 30-07-2010 17:07
MG Montego Turbo LoudnProud MG / Rover Related Chat - up to 2005 7 20-01-2004 08:08
