MG TF Race Car - MG-Rover.org Forums
 2Likes
post #1 of 73 (permalink) Old 01-11-2015, 17:51 Thread Starter
Car: MGF TROPHY, EVO V, Audi Coupe GT and TF Race Car
MG TF Race Car
So work started on building my TF race car today.
Start of the afternoon complete car.
Interior stripped - dash caused headache with the 4 bolts where the vents are but eventually got it out.
Front end stripped, radiator removed ready to start making the ducting for radiator up through the bonnet.
flyingbanana is offline
post #2 of 73 (permalink) Old 01-11-2015, 18:19
Car: brm,mgf'mg zr1.4,mg zr 160 ,honda goldwing,jawa 125 caferacer
This will be interesting to follow the build ,good going with the choice of car,keep the updates coming
big end floater is offline
post #3 of 73 (permalink) Old 01-11-2015, 23:23
Looking forward to seeing this
JOHNDQ is offline
post #4 of 73 (permalink) Old 02-11-2015, 05:30 Thread Starter
Looking to get one of these to create the gurney flap as per the 200 hpd.
http://www.ebay.co.uk/sch/Vehicle-Pa...p2045573.m1684
post #5 of 73 (permalink) Old 02-11-2015, 17:13 Thread Starter
Mk1 non EPAS steering column procured courtesy of MGFnTF Bitz - great svc.
post #6 of 73 (permalink) Old 02-11-2015, 21:01
Car: Modified death trap
What's the plans for the engine/gearbox?
Good start so far ??
Dieseldestroyer is offline
post #7 of 73 (permalink) Old 02-11-2015, 21:02
Good start so far (and what should of been a thumbs up symbol came out as ??)
Look forward to progress updates
post #8 of 73 (permalink) Old 03-11-2015, 06:21 Thread Starter
MG ZR 160 engine/gearbox, Torsen type B, lightened flywheel, 421 manifold, kmaps remap.
post #9 of 73 (permalink) Old 03-11-2015, 22:31
I'd recommend using tapered bearings and shims on the Torsen diff.. For strength.. And steal cage the other bearings
The Elise Parts EN24 fly wheel is nice
post #10 of 73 (permalink) Old 04-11-2015, 05:59 Thread Starter
The diff bearings are steel caged, but the rest are standard. I do have another box with all steel caged bearings.
post #11 of 73 (permalink) Old 04-11-2015, 13:46
Tapered on the diff are stronger still.
What sort of power are ya aiming / hoping for
post #12 of 73 (permalink) Old 04-11-2015, 14:42 Thread Starter
170 will do for starters.
post #13 of 73 (permalink) Old 04-11-2015, 19:08 Thread Starter
Roll cage ordered. Went to fit the non EPAS steering column only to discover the bottom is narrower than the EPAS one meaning the collapsible joint is to big
post #14 of 73 (permalink) Old 05-11-2015, 04:55
Are you fitting sump baffles too? Good idea if the car is going to be driven hard on the track
post #15 of 73 (permalink) Old 05-11-2015, 08:11 Thread Starter
Not this year, but I will fit the Cup dry sump kit I have to it next year
post #16 of 73 (permalink) Old 06-11-2015, 20:43 Thread Starter
Started work on the ducting for the radiator this evening. Will transfer to aluminium before cutting the hole in the bonnet.
post #17 of 73 (permalink) Old 08-11-2015, 17:51 Thread Starter
Rear part of the radiator duct fabricated this afternoon and hole cut in the bonnet. Next task will be to mount the radiator so i can do front part of the ducting to the bumper.
post #18 of 73 (permalink) Old 11-11-2015, 08:32 Thread Starter
I have revisited this and after researching have concluded that although I had no problems with the engine in the metro, the side loads with the engine in the rear will probably be higher - so sump baffle sourced.
post #19 of 73 (permalink) Old 13-11-2015, 20:47 Thread Starter
Race hardtop arrived yesterday
Started getting the cockpit ready to mount the bucket seat be removing the cross bracing tne OE seat fastens to - but the batteries in my drill ran out before I could finish 😕. I will be mounting the seat on to 25mm CDS tube which will allow me to get the seat really low.
I also removed excess material from the drivers door making the much lighter.
post #20 of 73 (permalink) Old 15-11-2015, 20:41 Thread Starter
Productive afternoon in the workshop today.
Finished removing the drivers side floor bracing to allow me to mount the seat lower. I will weld a stiffener plate into the void created in the centre 'tunnel' to add rigidity to that section. I wish I'd used spotweld drill bits years ago.
Finally got the steering column mounted, as someone mentioned earlier the mk1 non EPAS steering columns mounting is different from EPAS ones. I used 2 nuts to allow me to mount it to the mounting below the standard TF ones.
Got two sections of 25mm box section and sat them on the floor to try the seat position.
Which dash to use?
Carried on work with the radiator ducting. I realised the other night I needed to cut a section out of the front upper section of ally due to the shape of the slam panel. The rwar duct now fits better.
The next task was to actually mount the radiator.
Small bracket made to hold radiator up.
Front section of radiator ducting fabricated, but still needs riveting together.
Bumper refitted
Race Car flyingbanana MGF and MGTF (Sponsored by MGFnTFBITZ) 18 01-11-2015 17:53
MG ZT V8 Race car Tomcat MG ZT V8 and Rover 75 V8 8 01-09-2013 19:52
mg zr race car chameleon MG ZR / Rover 25, 200 & Streetwise 17 19-11-2012 09:24
ZS race car above ^ wayner007 MG / Rover Related Chat - up to 2005 7 23-12-2011 04:34
How do you know what car to race? mattie007 Computer Gaming Forum 6 20-04-2005 01:41
