MG TF Race Car - Page 4 - MG-Rover.org Forums
 2Likes
post #61 of 73 (permalink) Old 08-04-2016, 21:44 Thread Starter
Car: MGF TROPHY, EVO V, Audi Coupe GT and TF Race Car
This afternoon I fitted the sump baffle, refitted the O/S hub/drive shaft and fitted the exhaust manifold.
And discovered a problem with my using the Metro engine mounts. The engine now sits 10mm lower and further back, causing this problem.
To fix this I'm going to shave the tube to clear the flexi and weld in a fillet of steel to fill the hole.
fvdb likes this.
flyingbanana is offline
post #62 of 73 (permalink) Old 30-04-2016, 18:32 Thread Starter
So been a few weeks.
Welding fest today.
Subframe modified.
I've reinforced the tube with 10mm o/d 2mm thick tubing to add strength back, although the tube works under tension rather than compression.
Exhaust hangers welded onto the resonator to help keep the flexi clear.
Subrame mount repaired.
Gearbox steady brackets welded onto subframe.
Had to modify the engine mount arm again as the radius arm was fouling on it.
And finally welded in replacemet nut/plate after the bolt sheared when I removed it - sometime ago...
I am awaiting delivery of an m12-1/8th npt adapter so I can fit the oil temp sender and then the subframe/engine should be ready to go back in.
post #63 of 73 (permalink) Old 02-05-2016, 19:16 Thread Starter
A few more little jobs done today, including removing O/S rear brake line and repairing it after it failed whilst trying to removed the OE flexi in prep for fitting the HEL lines with 1/8th npt fitting.
post #64 of 73 (permalink) Old 08-05-2016, 06:26 Thread Starter
Bit of Blue Peter time yesterday with cardboard, scissors, masking tape and side air scoops making extended intakes.
Will try them today.
post #65 of 73 (permalink) Old 08-05-2016, 16:58 Thread Starter
So tried the intakes on the car.
Won't be using this one.
Think I'll be using the trimmed one.
Oh and I've got the engine ready to go back in - it would be in now but I'm waiting on another full length clutch line to runthrough the inside of the car fm HEL, I asked for the wrong size banjo .
post #66 of 73 (permalink) Old 10-05-2016, 12:56 Thread Starter
Productive dinner time - engine back in
post #67 of 73 (permalink) Old 17-05-2016, 12:22 Thread Starter
Did a bit of work on relocating the air box to the boot this afternoon.
I am also relocating the header tank and FPR to the boot as well.
post #68 of 73 (permalink) Old 17-05-2016, 12:23 Thread Starter
Wheels have arrived - think they'll do the job
post #69 of 73 (permalink) Old 03-06-2016, 21:56 Thread Starter
Well after 3 weeks of not being able to get any work done I've fitted the stainless under floor pipes, fitted the oil cooler and more or less plumbed it in.
post #70 of 73 (permalink) Old 04-06-2016, 18:14 Thread Starter
Well I can now open the door from the inside
and I've finally decided where to mount the switch panel
other than that not a very productive day.
post #71 of 73 (permalink) Old 05-06-2016, 14:46
Busy and productive weekend then.
I like the relocation idea of the airbox and header tank.
What size ends does that 90' silicon elbow have as i'm after one to go on my
52mm TB to get a custom intake setup going ?
ROVER-25X is offline
post #72 of 73 (permalink) Old 05-06-2016, 16:07 Thread Starter
Throttle body is 70mm and the airbox is 64mm.
post #73 of 73 (permalink) Old 05-06-2016, 18:34
Nice one pal, keep cracking while the weather is good, I know its garaged
but you know what I mean, engine is in so not long to go until its under its
own power.
Race Car flyingbanana MGF and MGTF (Sponsored by MGFnTFBITZ) 18 01-11-2015 17:53
MG ZT V8 Race car Tomcat MG ZT V8 and Rover 75 V8 8 01-09-2013 19:52
mg zr race car chameleon MG ZR / Rover 25, 200 & Streetwise 17 19-11-2012 09:24
ZS race car above ^ wayner007 MG / Rover Related Chat - up to 2005 7 23-12-2011 04:34
How do you know what car to race? mattie007 Computer Gaming Forum 6 20-04-2005 01:41
