My other MG Montego Efi with digidash - Page 3 - MG-Rover.org Forums
post #41 of 289 (permalink) Old 18-05-2013, 15:08 Thread Starter
Internals are also different
Fuse box cover in early dash. Because of this the steering column has to be removed but not on later dashes
And different in later
Jeff Turbo is offline
post #42 of 289 (permalink) Old 18-05-2013, 15:12 Thread Starter
Ran out of time today as I had a job come in in Hinckley
I have to remove the heater next as the resistor isn't working, that has to come apart to fix.
I am undecided yet whether to convert the later dash to include the early fuses box cover. It would need a bit of cutting out but it can be done.
all the other parts are easy to replace.
I am also undecided whether to convert the manual mirrors to electric while the dash is out.
post #43 of 289 (permalink) Old 19-05-2013, 04:56 Thread Starter
Left to do
Fix fan resistor DONE
Convert newer dash to older. DONE
Replace nearside electric window motor. DONE
Re-wire drivers electric window loom
Convert manual to electric mirrors? STARTED
Modify and replace front door card fixings
Replace dash, heater etc
Replace centre consol
Wire in radio loom
Replace front seats
Replace rear lap belts from grey to red. NOW GOT
Add wiring and lighting to headlining. DONE
Headlining
Replace servo. REMOVED AND NOW PAINTED
Replace alternator. NEW FOUND
Paint engine
Replace cambelt, tensioner
Engine service
Weld rear sill
Replace all tyres
Replace exhaust
MOT
post #44 of 289 (permalink) Old 19-05-2013, 21:54
Fantastic progress !
Thanks for the pics.
The new center console and red seat belts look brilliant.
ROVER-25X is offline
post #45 of 289 (permalink) Old 29-05-2013, 15:48 Thread Starter
Dash done today and a few other things to tick off the list
Need to shape this into
This
Strip down
post #46 of 289 (permalink) Old 29-05-2013, 15:49 Thread Starter
And done
Just needs a clean and a small tidy up
post #47 of 289 (permalink) Old 29-05-2013, 15:52 Thread Starter
Rusty servo removed
Also sorted the nearside leecy window, new one from my spares. Pardon the expression but it's a bit stiff going up but is quick going down, needs greasing I think
post #48 of 289 (permalink) Old 29-05-2013, 15:55 Thread Starter
Also sorted the interior lamps and cleaned the headlining. 2 new lamp slots
And wiring sorted
post #49 of 289 (permalink) Old 29-05-2013, 15:58 Thread Starter
Headliner cleaned and ready to recieve new material. I made the mistake of wetting it as I didn't know it was made of pulp and covered with paper on the top but it should be ok. Used a rough cloth very gently in the end
post #50 of 289 (permalink) Old 25-08-2013, 05:21
Looked in good condition mate.
post #51 of 289 (permalink) Old 13-09-2013, 05:24 Thread Starter
Not a lot of update here. But I may have to find different storage as the barn its in is being sold
post #52 of 289 (permalink) Old 15-09-2013, 05:28
What a ballache.
post #53 of 289 (permalink) Old 15-09-2013, 10:15 Thread Starter
Originally Posted by ROVER-25X View Post
What a ballache.
Just a tad but I may have found more storage if I need it.
I've removed and stripped the paint off the servo, de-rusted in and that's ready for painting. New alternator found as the one I put on was grumbling, newish that was as well.
I will have time in october to continue this project as my work goes a bit quieter.
I'm hoping to have the heater fixed, servo and alternator back on, headlining recovered, dash back in and drivers side leccy window fixed by the end of october
Will post updates as and when
post #54 of 289 (permalink) Old 16-09-2013, 01:06
COOL, didn't look like it was salvageable, fair play.
post #55 of 289 (permalink) Old 15-10-2013, 14:25 Thread Starter
Finally a bit more done
Alternator removed again as it's no good
Servo still removed
Heater removed
post #56 of 289 (permalink) Old 15-10-2013, 14:29 Thread Starter
Water pipes are in remarkable condition considering its age
Early gasket modified in later cars
[URL=http://s847.photobucket.com/user/jeffturbo1/media/STP63493_zpscd5c1cb3.jpg.html][/URL
Early cars have 2 of these
Resistor can now be removed after I've stripped the heater
Even have to remove the fan
soooooo much easier on modern cars but as the fan motor only works on setting 5 it has to be done
post #57 of 289 (permalink) Old 15-10-2013, 14:34 Thread Starter
Rare thing this, these are only on early cars and were discontinued after 1985 and the carpet is in great condition.
post #58 of 289 (permalink) Old 15-10-2013, 14:39 Thread Starter
Once I've fixed the resistor the heater and dash can be put back in, it will look more like a car then and not a wiring mess
post #59 of 289 (permalink) Old 15-10-2013, 14:46
Car: Maestro T series conversion
Good work Jeff, you've got some nice features of the early models better carpets, fusebox that should be more solid, with some mk2 features too! I've been through the airbox removal and splitting a few times, its easy when you know how! Probably forget how by the time I need to do it again...
countrydude is offline
post #60 of 289 (permalink) Old 15-10-2013, 16:28 Thread Starter
Hi dude.
I've removed the resistor without seperating the whole heater. The coils are ok but the small black leccy unit is corroded so I have to assume that's the problem. I will drillout the rivets and separate the heater at a later date.
Rare MG Montego EFi with digi dash Jeff Turbo Show us your Projects! 114 05-02-2015 21:08
D393 YSX - Montego VP EFi in Moonraker Blue - pics? Anyone?? csd_19 Others 3 14-06-2012 11:02
MG Montego EFI Saqib MG / Rover Related Chat - up to 2005 5 10-09-2010 13:10
Engine badge sticker MG Maestro 1600 EFi Turbo Montego MetroMartin For Sale 0 23-08-2010 21:25
Rover Montego 2.0 EFI Countryman Estate - 7 Seater - MINT Stephen G For Sale 14 15-11-2009 12:07
