My other MG Montego Efi with digidash - Page 5 - MG-Rover.org Forums
post #81 of 289 (permalink) Old 30-10-2013, 05:38 Thread Starter
Originally Posted by E_T_V View Post
If you are trying to do that then I have quite a neat idea that might work
I was going to drill holes in the biscuit width ways and 2 ali strips, place the strips on top of the biscuit and use the clips to hold the ali in place after I've formed it into the shape I need. I was then going to re-cover the headlining to hide the clips. The ali should strengthen it and stop the centre part of the biscuit from sagging
What's your idea dan?
Jeff Turbo is offline
post #82 of 289 (permalink) Old 30-10-2013, 14:29
Glue a strong magnet in there instead. Glue it to the top of the headlinging and it'll stick to the roof but still be removable if you need it to me.
Hard drive magnets are thin and VERY strong so I'd cannibalise a drive for them as a start point.
post #83 of 289 (permalink) Old 30-10-2013, 15:39 Thread Starter
That's an idea but as yet I don't know what gap there is between the roof and biscuit when it's in, next time i'm there I will put it back in and see what the gap is
post #84 of 289 (permalink) Old 30-10-2013, 21:20
The gap isn't a lot as standard which is why there is foam on the top to stop it rubbing on the roof.
post #85 of 289 (permalink) Old 31-10-2013, 08:57 Thread Starter
Thanks Dan, I might be able to get to the car Sunday so will check first then.
Will also be starting to re-wire the front leccy windows with the wiring and control box from a later model. Easy to do but I want to keep the switches in the doors so it could be interesting.
I will hopefully just extend the switch wiring to the doors from the control box using a loom from my donor wiring and remount the box under the dash so it's hidden
Donor wiring is for 4 leecy windows, it's all there somewhere
post #86 of 289 (permalink) Old 04-11-2013, 15:27 Thread Starter
Prezzies arrived today
New waterpump, cambelt and tensioner.
Found 2 new matt black leccy door mirrors in my spares so should have more progress later in the week
post #87 of 289 (permalink) Old 06-11-2013, 15:21 Thread Starter
More done
Manual mirror off
Leccy mirror on
Original mirrors have metal rods to screw into
Newer have plastic
post #88 of 289 (permalink) Old 06-11-2013, 15:23 Thread Starter
Check the surrounds in the right place
Finished and all working, so that's off the list
Also got the trial leccy windows working, just need to cut into existing loom next and extend for a second switch
post #89 of 289 (permalink) Old 06-11-2013, 15:26 Thread Starter
Cambelt/ water pump removal next. Very early head are different to later models
Very early tensioner
The front wheel has to come off and dust cover
Timing marks
post #90 of 289 (permalink) Old 06-11-2013, 15:28 Thread Starter
Mark on the cam doesnt line up so I have put a tipex mark on it as it will go back the same
Water pump
Removed
Unfortunately a bolt snapped
post #91 of 289 (permalink) Old 06-11-2013, 15:42 Thread Starter
Water pump is on its way out and partially siezed
Differences in early and newer tensioners, cam belt also fits a Renault Meganne
post #92 of 289 (permalink) Old 07-11-2013, 06:14 Thread Starter
Located a tensioner in ......Spain, luckily my eldest sons girlfriend is Spanish and will enquire for me.
In the meantime I will be finishing off the leccy window wiring, trying to remove the snapped bolt in the engine and replacing the corplugs as one or two look abit rusty
post #93 of 289 (permalink) Old 07-11-2013, 08:00 Thread Starter
I've found what I'm going to use to strengthen the headlining biscuit and stop it going out of shape.
Found it in Wickes. One or two strips glued on should brace it enough
http://www.wickes.co.uk/pvcu-cloak-p...m/invt/162619/
post #94 of 289 (permalink) Old 07-11-2013, 12:23 Thread Starter
Tensioner was a no go but i've sourced a tensioner that very nearly the same.
all dimensions are the same.
These are from a Ford ohc Pinto engine, capri, cortina, transit etc so should be sufficient
post #95 of 289 (permalink) Old 19-11-2013, 16:43 Thread Starter
Moved storage today into another barn and also moved other cars I have there and some of my spares
First in the queue
Getting ready
Join the queue
Next
post #96 of 289 (permalink) Old 19-11-2013, 16:45 Thread Starter
D reg
C reg
B reg
From the back
post #97 of 289 (permalink) Old 19-11-2013, 16:46 Thread Starter
Now in their new home
And some of my spares
post #98 of 289 (permalink) Old 19-11-2013, 17:31
Car: MG ZS 120 mk2
Its a Monty museum and i must say as a young person who always liked Monty's from when my Dad had one when i was a kid they are fine examples.
galley.r25 is offline
post #99 of 289 (permalink) Old 19-11-2013, 20:59 Thread Starter
Thanks but all are on going projects, I do have 3 others aswell
This white one, another project
Another red one
Rare MG Montego EFi with digi dash
And this one
post #100 of 289 (permalink) Old 19-11-2013, 21:26
Car: MG ZS 120 mk2
Ye I have been keeping an eye of this thread and the other one (you linked) for a fair while now when ever it pops up.
That black one looks in better shape than it most likely did when it left the factory, fair play it looks like art.
Rare MG Montego EFi with digi dash Jeff Turbo Show us your Projects! 114 05-02-2015 21:08
D393 YSX - Montego VP EFi in Moonraker Blue - pics? Anyone?? csd_19 Others 3 14-06-2012 11:02
MG Montego EFI Saqib MG / Rover Related Chat - up to 2005 5 10-09-2010 13:10
Engine badge sticker MG Maestro 1600 EFi Turbo Montego MetroMartin For Sale 0 23-08-2010 21:25
Rover Montego 2.0 EFI Countryman Estate - 7 Seater - MINT Stephen G For Sale 14 15-11-2009 12:07
