Project Angel :) - Page 2 - MG-Rover.org Forums
post #21 of 33 (permalink) Old 26-01-2015, 17:29 Thread Starter
Update time
Managed to get abit done over the weekend got the cylinder block as clean as i can ready for the new BGA headgasket
got brand new headgasket and new head bolts and put headgasket and shim ready for cylinder head to go back on
had the cylinder head skim'd and got all the valves put back in and put it back on the car
also managed to get drivers side brake pipe done and put everything back to gether and got it all under coated (no pics ) and got 1st coat of black on it all
also got my spare alloy rad out of the garage to replace the f'd old one
wolle18 is offline
post #22 of 33 (permalink) Old 28-03-2015, 19:15 Thread Starter
Update
Its been about 2months since i last updated this o well i got the cams back in injectors put back on with FAI inlet gasket and BGA exhaust gasket for exhaust manifold
also replaced oil filter with a brand new oe mg rover filter before filling up with brand new oil and also managed to get a gates timing belt kit cheap was nearly half the price it should of been so happy days
I also managed to find a 52mm tb that i didn't even realize i had in the garage i have that many spare little bits i can't remember what i have lol but i thought it would be worth fitting with this being a vvc and obviously got brand new coolant in her before starting the beast for the 1st time in months, wish i could say she started 1st time agen but it took me some time to get her started but now she is running like a dream and starting first time every time
wolle18 is offline
post #23 of 33 (permalink) Old 28-03-2015, 19:29 Thread Starter
update 2
Got battery tray refitted with brand new bolts as the old ones were rusty as fff so i dicided i will replace most of the bolts just to no that they are good for along time to come and will be easier to remove if i ever need to take them out
refitted ecu with brand new bolts as well
Replaced fuel filter with a brand new man filter thats the make of it haha but one i removed didn't look that old but best just to replace as i don't have any service history of the car
new one in place
The alternator was making some strange noises when i had the car running so i replaced that with one that is nearly brand new that i had in my box of spare parts haha
side by side
new one fitted
wolle18 is offline
post #24 of 33 (permalink) Old 28-03-2015, 19:49 Thread Starter
update 3 lol
So like my other car i got hold of some xsara bonnet struts and 4x bmw strut nipples and got the bonnet struts fitted as the original bonnet support is lets put it nicely is ok unless its windy lol
so out with the old
xsara bonnet struts with nipples
all fitted up
if anyone wants to no how to fit them then just ask its pretty simple and cheaper than the bonnet strut kits you can buy and i like being cheap haha.
But any way on with the update after awhile of searching ebay for headlights i bought a pair of zr headlights with all there fixing points for £16including postage what a bargain as i wanted to replace the chrome rover 25 ones so got those fitted
also had to paint some engine bay bits as they really needed a good rub down and coat of primer and paint so go that done to tidy up the engine bay for future plans i have for it
also have some purple anodized washers and some stainless cap headbolts to dress the engine bay up
wolle18 is offline
post #25 of 33 (permalink) Old 28-03-2015, 19:52 Thread Starter
For all those that expect to see pink here you go !
stay tuned more to come in the fallowing weeks
wolle18 is offline
post #26 of 33 (permalink) Old 01-04-2015, 18:11 Thread Starter
Update
Finally got round to the time to do the front brakes took the calipers off got them rubb'd down and primerd and painted up gloss black as i wasn't a fan of the red and red wont go with my plans for the car any way haha
also got the caliper carriers out to rub down and primer and paint but the drivers side have to seized sliders so lucky i have to spare ones with decent rubbers so had to get out the burner and a pair of grills to turn them loose when the burner had worked its magic of heating it up and worked a treat
not the best rub down job but o well i may eventually upgrade the brakes but this will do for now
got both sides fitted up and bled
and finally got some steelies on her not sure what they are off just something i have kicking around so that i can move her round the driver and she has finally moved from when i first got her
wolle18 is offline
post #27 of 33 (permalink) Old 02-04-2015, 18:12 Thread Starter
Tiny update haven't got much done today but got rad brackets back, fitted the rear cam belt cover that i have made (which isn't great) but it does the job its suppose to as i don't want to run it with out a cover on .
Also fitted spark plug cover back with cap head stainless bolts and purple washers and also changed 5 of the cam/rocker cover bolts
also has pink front cam sprockets and i am working on a case for them
wolle18 is offline
post #28 of 33 (permalink) Old 18-04-2015, 19:08 Thread Starter
Update
I got my self a nice new mutli coloured alloy oil cap which takes a sec to fit haha
Also decided to stick the 1st decal on the car which i was going to do when the car is finished but decided just to do it now so it doesn't get damaged . As you can see from the old tax disc the car was taken off the road a while ago by the previous owner but will see the road again in summer i think
I also got out my left over stainless steel sheet i had and crafted up an exhaust manifold cover while i wasn't doing much disafternoon
next on the to do list for this car i think is to patch up the holes in the side of the roof which i found today but will get them cut out and some metal plates welded in if i can
wolle18 is offline
post #29 of 33 (permalink) Old 19-04-2015, 17:39 Thread Starter
Picked up a complete rear disc brake beam pretty cheap so got it out of the shed and striped down so i can get it washed and give it a good rub down ready to be painted at some point
wolle18 is offline
post #30 of 33 (permalink) Old 19-04-2015, 17:42 Thread Starter
Heres a vid of how she sounds
[IMG][/IMG]
wolle18 is offline
post #31 of 33 (permalink) Old 29-09-2015, 21:52 Thread Starter
So it's been ages since i have updated this not really had the car out of the garage that much to do anything with her but am trying to crack on now before the weather gets to bad but any way got this polished spark plug cover off adam along time ago now but now its fitted and looks awesome
still got a few more bits to add to the engine bay but that is all in good time
wolle18 is offline
post #32 of 33 (permalink) Old 29-09-2015, 22:01 Thread Starter
so here is the damage that she had on the passenger side when i bought her which i wasn't to botherd about really as it's nothing serious so got hold of a very cheap door and replaced the damaged one as i just can't be botherd to try sort the old door out so thats in the scrap pile lol
to be honest only took me like 10mins to replace the door since there are no wings fitted so i just have the quarter panel to sort but it hasn't got that much damage so hopefully most of it will just push out and then i will fill the light dints up and jobs a good one
wolle18 is offline
post #33 of 33 (permalink) Old 29-09-2015, 22:15 Thread Starter
Up to date update
so today i finally finished stripping out the interior i have already sold the door cards and seats awhile back to make some space so heres some pics
so here she is with a half stripp'd interior
and here it is now looking bare
also decided to remove the old windscreen as i oready have its replacement under my bed ready to go in one day haha but some how this windscreen got cracked but no big deal didn't take me long to remove it with my big hammer
maybe not the best way to remove it, well i no its not but it made it easier to through it in the bin this way haha i have also removed half the old edge bead with out damaging the paint but don't have pics of this at the moment
wolle18 is offline
My Angel Mr Edd MG ZT / Rover 75 (Sponsored by Rimmer Bros) 56 17-09-2011 15:50
Angel before and after aj200vi MG ZR / Rover 25, 200 & Streetwise 54 03-12-2007 14:44
angel? Antrock101 MG ZR / Rover 25, 200 & Streetwise 0 05-03-2007 08:40
Current project:- Project 414i Dr Dave Show us your Projects! 44 15-01-2007 19:50
Press Release: Project Kimber / BMW and Project Kimber / Nanjing Ian MG / Rover Related Chat - up to 2005 32 02-04-2006 14:25
