Go Back   MG-Rover.org Forums > Model Specific Forums > MGF and MGTF (Sponsored by MG Rover Parts Ltd)
Old 03-02-2006, 18:08   #1
Tony26
Car: MGF
Tony26 is up and running. Hey we all have to start somewhere.
Home Brewer Heater Resistor Pack (pics)
First little job on the wifes mgf was to get 1 and 2 working on the heater fan.
As you can see both coils are burnt out.
After a trip to Maplin, I made up some coils of resitor wire to the correct ohms, and soldered them in.
Not as pretty as a new one but works perfectly fine. All for about £5
Tony26 is offline   Reply With Quote
Old 03-02-2006, 18:11   #2
jupilerman
Car: Please Select
jupilerman is up and running. Hey we all have to start somewhere.
What impedance are we talking about?
jupilerman is offline   Reply With Quote
Old 03-02-2006, 18:13   #3
Tony26
Car: MGF
1= 2.1ohms 2= 1.5ohms 3= 1ohms
Old 03-02-2006, 18:25   #4
Pete T
Car: MGF VVC 2000MY
Pete T is up and running. Hey we all have to start somewhere.
Send a message via MSN to Pete T
Great tip Tony!! - I'll try and remember that one!!
Think I've still got some Eureka Wire somewhere.....
Pete T is offline   Reply With Quote
Old 03-02-2006, 18:26   #5
DAVIDT6DCM
Car: MGTF160
DAVIDT6DCM has a spectacular aura aboutDAVIDT6DCM has a spectacular aura about
Did the same with my F's and Rover 400 Resistor pack (same both cars)as both had gone same as Tony's, the original coils 1 and 1.5 ohms are very very thin and delicate i replaced with a little bit stronger resisitor wire also, it's great to have poss 1 and 2 working on both cars again as poss 3 a little too much sometimes, Dave
DAVIDT6DCM is offline   Reply With Quote
Old 03-02-2006, 22:41   #6
Benfinlayson
Benfinlayson's Avatar
Car: MGF
Benfinlayson is a glorious beacon of lightBenfinlayson is a glorious beacon of lightBenfinlayson is a glorious beacon of lightBenfinlayson is a glorious beacon of lightBenfinlayson is a glorious beacon of light
Question
I have exactly the same problem with my resistor pack. Any chance you could let me know the spec of the wire and the lengths required for each bit. I am ok with a soldering iron so might give it a go. Did you use special solder? Will it melt normal solder as it gets pretty hot!
Ben
Benfinlayson is offline   Reply With Quote
Old 04-02-2006, 08:43   #7
Tony26
Car: MGF
This is the wire I bought from maplin, I used this for fan speed two which is 1.5 ohms, just wound the wire round a screw driver, then tested using a multimeter. For fan speed 1 the wire is slightly finer, sorry I didn't measure the length of wire used was just trial and error. You can use normal solder because the coils are cooled by the fan in the heater box.
Old 24-10-2006, 10:16   #8
Dave400
Car: Ford Focus
Dave400 is up and running. Hey we all have to start somewhere.
Send a message via MSN to Dave400
Just for anyone wanting to find this...
http://www.maplin.co.uk/Module.aspx?...NTaN&doy=24m10
Based on the figures quoted by Maplin, 4.2ohms is 1 metre of wire therefore...
50cm = 2.1ohm
35cm = 1.5ohm
23cm = 1ohm
Also availble from http://www.wires.co.uk/acatalog/cn_bare.html
Dave400 is offline   Reply With Quote
Old 24-10-2006, 10:58   #9
KrisFX
Car: MGF Trophy 160 SE
KrisFX has much to be proud ofKrisFX has much to be proud ofKrisFX has much to be proud ofKrisFX has much to be proud ofKrisFX has much to be proud ofKrisFX has much to be proud ofKrisFX has much to be proud ofKrisFX has much to be proud of
Send a message via MSN to KrisFX
Hows about adding this little gem of a tip to your one-stop shop website Mr V?
Think it could prove handy for quite a few people.
KrisFX is offline   Reply With Quote
Old 24-10-2006, 11:12   #10
Petevick
regained interest
Petevick's Avatar
Car: MG TF 160 in Trophy Yellow
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
its been on for a while, altho I will try and make it easier to find via the search.
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 24-10-2006, 11:18   #11
KrisFX
Ooops, now I feel silly!
Old 24-10-2006, 12:15   #12
D.R.
Car: MG
D.R. will become famous soon enough
Great pics Tony26
Seemed to be common problem, had to replace one in a Landy £14 and in another Rover £24. If only I had spotted the DIY fix before hand
Another thread kicked off by Dr Dave uses individual resistors instead of wire:
http://forums.mg-rover.org/showthread.php?t=55979
Technozen placed a good diagram of wiring position in post 54
They are also using different ohms 1.5, 0.68 and 0.2
Q. How does your fan speed run in comparison to the original?
Also, can you use something like fire cement to keep the wires evenly spaced and prevent the coils making contact?
D.R. is offline   Reply With Quote
Old 24-10-2006, 12:45   #13
Herbie
Werder Supporter
Herbie's Avatar
Car: MGF 1.8i & MGTF 1:18
Herbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these parts
Send a message via MSN to Herbie Send a message via Skype™ to Herbie
Great !
I feel a little project coming on (1 not working) but it's the hell to reach that pack. Any hints for a LHD car, 'cos I almost broke my fingers trying to reach the area ?
Stephan Hebert
MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ
Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling
Herbie is offline   Reply With Quote
Old 24-10-2006, 12:58   #14
Petevick
regained interest
Petevick's Avatar
Originally Posted by Herbie View Post
....Any hints for a LHD car.....
print the pictures in reverse Herbie
Old 24-10-2006, 13:09   #15
Herbie
Werder Supporter
Herbie's Avatar
Are you sure Pete ?
I don't know, the heater mechanics and so on....... help meee
Not soooo important if only 1 doesn't work, but on the other hand I always want it perfect.....
Stephan Hebert
Old 24-10-2006, 14:54   #16
Rob Bell
Car: MGF and MG ZT-T (also Mk3 Triumph Spitfire and Mk1 Austin Mini)
Rob Bell will become famous soon enoughRob Bell will become famous soon enough
Originally Posted by D.R. View Post
Great pics Tony26
Thanks for that link. Did anyone see this posting?
Thanks to this thread I had a look at my remaining resistor, the 0.25R (position III), and did a few measurements and I can see why these resistors don't last forever - they have quite tough time.
The blower must be a pretty powerful motor - about 250W (1/3 HP) at full power, so slowing it down means rather a lot of watts need to be lost, more than 60W on position III - most of it in the 0.68 ohm. By my reckoning the resistor which dissipates the most depends on the fan setting;
Position I 1.5 Ohm 28W
Position II 0.68 Ohm 46W
Position III 0.27 Ohm 47W
I could see the impact on the 0.25R because with the resistor pack out of the ducting the coil glows orange-red almost immediately, which is less of a surprise when you think of the coils as electric fire elements. I know it gets some airflow inside the ducting but I bet it doesn't make that much difference.
I suppose the 1.5 Ohm and 0.68 Ohm fail first because they have the thinnest wire and the heat makes them brittle, then the vibration simply breaks them.
The resistor pack is pretty wasteful way of controlling the fan speed but it the method used in all cars I know of.
It would be good to come up with something more elegant, but it is probably not worth the hassle.
No one has adequately answered this particular conundrum - namely the resistors being used are only 1/5th of the rating required to dissipate the energy required!
Carl had another solution using MOSFETS - might have to find out a little more about this...
Rob Bell is offline   Reply With Quote
Old 24-10-2006, 15:10   #17
Chris T
Moderator
Chris T's Avatar
Car: MG TF 135 Platinum Silver
Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1
I think if I ever need to renew the resistor pack I would be tempted to get hold of some proper power resistors that can be bolted down somewhere.
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is online now   Reply With Quote
Old 24-10-2006, 15:13   #18
mercodus
I am AWAKE
Car: Rover 45
mercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these partsmercodus is becoming God like round these parts
there's a thread in 'How Do I' which covers this, if you dare venture out
mercodus is online now   Reply With Quote
Old 24-03-2009, 16:59   #19
partyboy
Car: MG ZR
partyboy is up and running. Hey we all have to start somewhere.
heater
mmm interesting thread this,ive the same problem, tho ive no fan working and no cig lighter or interior light of clock light working, are all these linked,or is the resistor pack the likely culprit for my heater and the other problems something else?
partyboy is offline   Reply With Quote
Old 24-03-2009, 17:07   #20
MGFmad
The futures orange
MGFmad's Avatar
Car: MGF VVC 75th ANNIVERSARY & TF LE500
MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.MGFmad has a reputation beyond repute. Respect.
Send a message via MSN to MGFmad
No they are not linked, I wonder if you have a wiring problem at the back of the centre console.
Resistor pack may still be faulty as a stand alone fault - you can access it from the passenger footwell - just a couple of screws and its out so you can check if the resistors are burnt out. If you need new resistors PM Technozen he will supply new correctly rated ones at a great price.
On the other faults, check the wiring at the back of the console - it may have been rubbing on something sharp or the plug connectors could be loose - has anyone been fiddling about in there recently?
TF LE500 No 27 of 500 & 75th Anniversary No 452 of 2000
MGF & TF Facebook Group
MGFmad is offline   Reply With Quote
heater resistor pack paulineb MG ZS / Rover 45 & 400 10 06-11-2008 01:11
heater resistor pack paulineb Wanted 3 30-10-2008 20:20
resistor pack (Heater) bhogalb MG ZR / Rover 25, 200 & Streetwise 13 19-03-2007 23:25
Heater resistor pack Dave For Sale 1 15-02-2007 21:34
Heater resistor pack andrewuk Others 8 09-03-2005 15:07
Powered by vBulletin® Version 3.8.0 Beta 2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site designed, operated, funded and not least owned by Online Enthusiasts Ltd. Steve Childs and or Online Enthusiasts Ltd are in no way endorsed by or affiliated with MG-Rover Group Limited. This site is run by MG-Rover enthusiasts for MG-Rover enthusiasts. Any content of the forums should in no way be taken as official statement or views of either MG Rover Group Ltd, Online Enthusiasts Ltd, their suppliers, their employees or their advertisers, unless otherwise indicated. Please do not take any content from this site without prior written permission from Steve Childs. Any reference to speed or driving styles either actual or inferred on the pages within this website should not be taken as encouragement to drive irresponsibly either within the speed limit or in excess of. Please drive responsibly.
Terms and conditions of use
