Go Back   MG-Rover.org Forums > Model Specific Forums > Metro / Rover 100
Old 18-11-2009, 21:59   #1
BONE
Car: Rover 100
BONE is up and running. Hey we all have to start somewhere.
14/15" alloys
could anyone give me a list of places where i can get my hands on some compomotive mo motorsport wheels for my metro. and will the alloys sit straight on or will i need to have sum arch work done. thanks
BONE is offline   Reply With Quote
Old 18-11-2009, 22:14   #2
John
Car: MG ZTT CDTI - Stripped R100 VVC
John is a name known to allJohn is a name known to allJohn is a name known to allJohn is a name known to allJohn is a name known to allJohn is a name known to all
Send a message via MSN to John
you need to roll the arches for 15's and shave the back axel.
I got mine second hand so not sure where you can get them from new.
John is offline   Reply With Quote
Old 19-11-2009, 09:02   #3
Steve.pearse
Car: 1994 Metro GTI 16v
Steve.pearse is up and running. Hey we all have to start somewhere.
You can get them directly from Compomotive at http://www.comp.co.uk/ On direct orders they will discount 10% (Did for me but still not cheap) I'm running their MO1460 wheel (14" 6J) with 195/45/14 Falken tyres, keeps the gearing the same. These just clear the arches at the back at standard ride height, at the front they will just scuff the arch liners when cornering fast on bumps. Anything wider and you'll need to do work particularly at the back
Compomotive will machine the wheels to your requirements, for the MK3 Metro and R100: PCD 95.25, bore 56.7, ET 30.
Good looking wheels so complement them with locking nuts. I've used the "McGard" ones.
Note Suspension is too high in pic.
Steve.pearse is offline   Reply With Quote
Old 19-11-2009, 19:39   #4
John
these are my front's with the ap 4 pots. If your going comps why settle for 14's? when you can have 4 pots?
Old 20-11-2009, 08:32   #5
Steve.pearse
Should have said ET (offset) 38mm. Sorry for error. John, what tyre are you running there?
Old 20-11-2009, 20:13   #6
Bills_metro
Car: Rover 100
Bills_metro is a splendid one to beholdBills_metro is a splendid one to beholdBills_metro is a splendid one to beholdBills_metro is a splendid one to beholdBills_metro is a splendid one to beholdBills_metro is a splendid one to behold
Do I read this correctly?
Am I right in thinking that you mean you advocate grinding the rear trailing arm, and reduce it's structural integrity, to fit some wheels that look "nice"?
Bills_metro is offline   Reply With Quote
Old 20-11-2009, 21:21   #7
Procta
Car: pug 306/metro gta
Procta is up and running. Hey we all have to start somewhere.
i love the comps on metros but i think its more of a **** on putting 15"s on a metro, id have just put 14"s on less hassle.
Procta is offline   Reply With Quote
Old 21-11-2009, 22:19   #8
John
shocking as it sounds but yes, however i didnt do it because they look nice, i would have prefured steelies, but the ap brakes will only fit under those 15's. My car is for racing nothing else my Ztt takes care of my day to day needs the car doesnt look nice it looks like a shed. Looks were not taken into consideration on building my r100
The trailing arm is only grinded by about 5mm and the point in which you grind is excess 'fat' so to speak. If there was another way around this the option would have been taken
Sorry you need to run on 195/45/15's you cant run anything more than a 45 profile tyre. Oh and they are Toyo T1R's i ran them on my Mgf and they were very good.
Old 23-11-2009, 18:59   #9
Bills_metro
Car: Rover 100
Ah yes of course
<snip>
Ah yes of course, I didn't realise you had the design drawings, and knowledge to interpret them, to be able to decide that the 5mm was "excess fat". They must be awfully thick to be able to lose 5mm. I guess all those years ago the designers grossly over-engineered them, at the expense of extra cost and extra weight for every vehicle that left the factory and for every spare that was made.
So do tell, just how thick is the material in a trailing arm: you will of course have cut one open to check. And where do you get the X-ray specs from that allow you to see inside the ones on your car, so you know the condition inside there, know that they are not rusty after God knows how many years on the road?
And what kind of results did you get from your own tests, after modification, of torsional strength, just how little (or much) did the trailing arm flex, compared to original design figures?
As for there not being any other way round, maybe another option would have been to fit things that did NOT compromise the safety margins that were (NOT over-)engineered in there? And isn't the race track a situation where components are pushed towards their design limits anyway, where the stresses are increased compared to normal road use and so erode away the margins?
I am so glad to hear that it isn't used on the roads, if only all the vehicles that have been attacked with brute force "because there was no other way" weren't on the roads. Maybe then there would be fewer "accidents" due to failures - which may not even be catastrophic failures of a broken component that can be seen when it's upside down in the ditch?
Or maybe we all ought to realise that "accidents" have, in the main, causes that could be avoided?
Old 25-11-2009, 17:38   #10
John
Your right of course as a buyer for a engineering firm i dont know how to read a drawing. And of course your completly right the back axle and trailing arm wasnt sandblasted, chemically impregnated, and then powder coated. The precise point in which was shaved is excess fat but of course a man who doesnt bring in a lot of his castings in from china/india. Of course i wouldnt also know how the engineering process works with castings i wouldnt also know about the safty tolerances on all casting parts in my sector or the automotive sector. Its only the sector i havnt been studying to move from engineering to automotive sector.
but your right we also didnt have a fia approved roll cage designed for the car that wasnt sent away again to be strengthed in key places. (however i will give you that this roll cage isnt quite fitted yet. But the car has only been on a quick shake down at croft, i am quite confident the 15 minutes or 3 laps it didnt wont have affected the overall ridgedity of the shell
Like previously mentioned the shell isnt a road car, although legally it can be used on the road. It doesnt see light of day its horrible to drive the car is so stiff it rattles your very core.
Please dont take me for some small child with his first car i have been building race cars for quite some time now. Although this is my first personal race car, i still know a few tricks.
However i do agree with you on one point. Accidents genrally can be avoided with a bit more thought. Most of the time its the driver running out of talent rather than the cars ability
Wanted 14 or 15" alloys for Rover 200 (bubble) 96rover214si Wanted 1 01-09-2007 17:18
14" alloys/steels 185/60/14 vidriver Wanted 10 07-03-2007 12:50
14" or 15" wheels for Metro/Rover 100! Chavtastic Wanted 3 20-01-2006 13:12
4 x 15" Rover Alloys and 4 x 14" Rover wheel trims stranter Wanted 1 23-11-2005 12:29
alloy wheels 14" / 15"? MatthewReardon Others 4 17-07-2005 08:04
Powered by vBulletin® Version 3.8.0 Beta 2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site designed, operated, funded and not least owned by Online Enthusiasts Ltd. Steve Childs and or Online Enthusiasts Ltd are in no way endorsed by or affiliated with MG-Rover Group Limited. This site is run by MG-Rover enthusiasts for MG-Rover enthusiasts. Any content of the forums should in no way be taken as official statement or views of either MG Rover Group Ltd, Online Enthusiasts Ltd, their suppliers, their employees or their advertisers, unless otherwise indicated. Please do not take any content from this site without prior written permission from Steve Childs. Any reference to speed or driving styles either actual or inferred on the pages within this website should not be taken as encouragement to drive irresponsibly either within the speed limit or in excess of. Please drive responsibly.
Terms and conditions of use
