rover 25 diesel overheating on motorway - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Ask The Gurus! - Help and Advice Forums > Diesel Forum!
Old 23-04-2012, 07:31   #1
BillyJohnLee
Car: 25 diesel
picked up my new 25 diesel yesterday, but as soon as i got on the motorway the temp rose, put heaters on full and they were cold, and it overheated. the rad felt cold, but the water was boiling
i let it cool, filled it up and carried on. repeat twice.
then we got onto single carigeway stuck behind a lorry and it cooled a bit, it was still to hot, but drivable at 50mph/2krpm
anyone got any ideas? thermostat? water pump? Headgasket?
BillyJohnLee is offline   Reply With Quote
Old 23-04-2012, 10:29   #2
Popeye 89
that grinds my gears
Car: BMW 330d E46
Send a message via MSN to Popeye 89
possible head gasket or cracked head fella, was it from a dealer?
Popeye 89 is offline   Reply With Quote
Old 23-04-2012, 10:38   #3
Rik420SDi
Rik420SDi's Avatar
Car: Megane Coupe 1500 DCi
Worth checking to see if it's circulating water - pop the coolent return off the header tank (engine cool, obv.) and see if water is flowing, give the throttle a blip and the flow rate will increase. Absence of flow or increase of flow on revving would indicate coolent pump problems.
Any steam or coolent-smell from header tank or exhaust? Coolent hoses getting pressurised very hard soon after starting?
Water pump piggybacks off the PAS pump by the way, not cambelt driven on the diesel engines. If you do need a pump there are excellent pattern-parts on ebay for £20 - top quality too.
Rover 216 Cabriolet driver with a smile on his face
Stroke support and information - http://www.stroke.org
When the NHS rehab ends - http://www.arni.uk.com
Rik420SDi is offline   Reply With Quote
Old 23-04-2012, 10:44   #4
Enright
Car: Mk2 ZS TD & Lotus Elan
Could be sheared water-pump drive after the Winter weather.
The water pump is driven off the back of the PAS pump. If insufficient anti-freeze is used and there's a big freeze, when you try to start the car it can shear the locating dogs off one or both of the spindles.
You end up with localised boiling and no circulation, which WILL result in head-gasket failure if not sorted.
To test for it, find the hose that goes into the centre of the water pump (it's about half way down the engine under the intercooler pipes).
Pop the pipe off and see if you can spin the water-pump's impeller. If you can, then you may need a replacement water-pump or a PAS pump. Unfortunately here's no way of finding out which one has been broken until you get one or the other off, as they join end to end.
If the pump's impeller is solid (as it should be) then my next port of call would be thermostat, but it's an absolute swine to get to - the front cross-member has to come off.
Good luck.
BCingU,
En. ;-)
Enright is offline   Reply With Quote
Old 23-04-2012, 11:27   #5
BillyJohnLee
Car: 25 diesel
Cheers guys. Iv checked the water pump and that seems fine. Stat was next.
The top hose was boiling but bottom stone cold. This would point to thermostat wouldnt it?
Im hoping it isnt the headgasket. But icam prepared for that.
Good job it is tidy and it was cheap.
Old 23-04-2012, 11:44   #6
BillyJohnLee
Car: 25 diesel
Is there an easy way to check if it is head gasket?
Old 23-04-2012, 11:47   #7
Enright
Yep, sounds like a stuck stat to me.
Nice cheap fix - result!
BCingU,
En. ;-)
Old 23-04-2012, 13:06   #8
Popeye 89
Car: BMW 330d E46
surely a stuck thermostat wouldnt stop heaters getting hot?
only reason i said head/head gasket is because ive been and seen one with exactly these symptoms.
by all means, check for the cheaper things first though
Old 23-04-2012, 13:11   #9
pervavore
Car: Rover 220 '98 SD / Rover 25 idt '00 / Rover 45 idt '00
I would change the water pump and thermostat. How have you checked the water pump?
pervavore is offline   Reply With Quote
Old 23-04-2012, 13:43   #10
BillyJohnLee
Car: 25 diesel
Popeye, yeah deep down i think it is the head gasket, but im hoping its not and checking other stuff, im always the optimist
i took the cover off the water pump, it all looked fine and it wouldnt move, so i turned the engine over and it span.
Old 23-04-2012, 14:05   #11
Enright
If a thermostat isn't immediately available, can't you just leave it out of the system for a few days to see how it goes?
Obviously I wouldn't suggest doing this long term, but for fault-finding it might help.
BCingU,
En. ;-)
Old 23-04-2012, 14:16   #12
pervavore
But if form the heater warm air isn't coming out than the thermostat isn't faulty.
Old 23-04-2012, 15:40   #13
Chrisund123
Car: 45 2.0 Diesel
Water circulates through the heater when the 'stat is closed, so I doubt it's a closed 'stat.
My money is on a sheared water pump, quite common if the water has been allowed to freeze.
Is there any problems with the power steering? as the coolant pump "piggy backs" of off the power steering pump. I reckon the drive from the PAS pump to the water pump has broken somehow. How did you check the water pump?
Chrisund123 is offline   Reply With Quote
Old 23-04-2012, 15:56   #14
BillyJohnLee
Car: 25 diesel
my thinking was that if the water was boiling the stat would be open and the radiator and bottom hose would be hot?
Old 23-04-2012, 17:32   #15
Rik420SDi
Rik420SDi's Avatar
Heater cold all the time could also be a knackered gate valve or blocked heater matrix. I had both on my 200, infact the heat output was always poor even when the system was flushed twice in the space of a fortnight to get rid of the muddy and murky nature...
Old 25-04-2012, 09:33   #16
BillyJohnLee
Car: 25 diesel
Cheers guys. Its defo the headgasket (pressure in coolant tank after reving from cold)
Any tips for doing it? It wont be the first iv done but the first diesel.
Can i use drill bits to lock off the pump? How likely is it i will need headstuds?
Old 25-04-2012, 10:21   #17
Rik420SDi
Rik420SDi's Avatar
There have been some reports of heads cracking, just so's you are aware - would be adviseable to get the head pressure tested. Other than that it's a pretty straightforward procedure by all accounts. Also a good time to replace the belts and tensioners etc - I can vouch for THIS KIT, the cheapest I have seen anywhere and good quality. I got one for my 45
There are others better qualified than me to advise - but yeah you can use drillbits, it's 6.5 for the crankshaft and 9mm (I think) for the fuel pump. I've no idea on the head bolts, but personally (for the cost involved) I'd be tempted to get newuns.
Old 28-04-2012, 13:57   #18
BillyJohnLee
Car: 25 diesel
Cheers for all your help guys.
this is the outcome so far..the Problem.
Back of the engine between 2 and 3? i assume that is where it went?
Old 30-04-2012, 18:14   #19
Bunny_Brain
Car: 2 Rover 25 Diesels and a 218 SLD Turbo
Looks pretty bad does that. You can see the path to the water jacket as well. You can reuse the head studs but I would suspect the head will be recessed where the fire rings have failed so a skim may be worth while.
Bunny_Brain is offline   Reply With Quote
Old 30-04-2012, 18:22   #20
zr-td-nutters
zr-td-nutters's Avatar
Car: zr tdi 180
i would say 2,3 and 4 by the looks of it but this is good news if the hg is clearly failed normally means the head is not cracked but i would at least skim it also i would check things like if the turbo has been buggered around with and make sure the rad is clear as hg failing like this is very very rare and only times i have ever seen it is when i tuned a derv a little to much with the std turbo.
zr-td-nutters is offline   Reply With Quote
rover 45 2ltr turbo diesel overheating fixed williamcadger MG ZS / Rover 45 & 400 4 11-10-2010 11:08
Rover 45 Turbo diesel overheating John Eaton MG ZS / Rover 45 & 400 2 30-12-2009 22:37
Rover 75 diesel cut out on motorway Dave1980 MG ZT / Rover 75 (Sponsored by Rimmer Bros) 2 03-06-2008 16:19
rover 45 diesel 2001 overheating help please!! pkhoopsa MG ZS / Rover 45 & 400 6 29-02-2008 23:43
418SLD - Overheating on Motorway yorky 'R8' Rovers (aka Wedges!!) 2 14-07-2003 09:50
