Discovery TD5 (Storm) injector wiring - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > Land Rover
Old 21-08-2005, 19:25   #1
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
Post Discovery TD5 (Storm) injector wiring
Just out of interest, here's some pics of the inside of the TD5 Turbo Diesel engine fitted to the Discovery. It's interesting as the fuel injectors are cam operated (to attain the pressure) and fired/modulated by electronic solenoids.
There is electrical wiring actually INSIDE the engine, running in oil!
It gives trouble eventually as the wiring degrades and oil seeps back out of the connector and down the loom eventually finding its way into the ECU - bad news!
The days of a simple diesel engine are sadly over.
The red arrow shows the injector solenoid, the yellow arrows denotes the rocker operated unit pump. The green arrow shows the electrical connection from the injectors; this is where the oil emanates from when the loom gets old, then it drop down towards the ECU.
The green arrow shows the camshaft, see the roller-rocker for the unit fuel injector? You can also see the wiring and the camchain.
Finally, here's a good view of the whole lot....
Dr Dave is offline   Reply With Quote
Old 21-08-2005, 19:27   #2
geeza76
Car: Other Manufacturer
why arent you fixing Steve's coop?
nah, shhh, no excuses
get cracking
geeza76 is offline   Reply With Quote
Old 21-08-2005, 19:38   #3
Dr Dave
Administrator
Dr Dave's Avatar
I would do if I had the parts and the tools to hand!
Hopefully they'll be dropping through my letterbox Tuesday-ish
Old 21-08-2005, 19:52   #4
Stu
Administrator
Stu's Avatar
Car: Saab 93 Vert + Alfa Mito Turbo
Send a message via MSN to Stu Send a message via Skype™ to Stu
Well packed then I hope
Interesting thread though.
Stu is offline   Reply With Quote
Old 21-08-2005, 20:31   #5
Dr Dave
Administrator
Dr Dave's Avatar
...and hopefully via recorded delivery too!
That's the only reason I took the pics, I found the setup there kinda interesting if not a little odd!
Old 23-08-2005, 12:37   #6
Vitessesqauddie
Car: Rover 800
thats why i love my old 200 tdi disco so much.
yes its basic, but its easy to fix and serviced regularly will run forever.
Vitessesqauddie is offline   Reply With Quote
Old 23-08-2005, 14:44   #7
Dr Dave
Administrator
Dr Dave's Avatar
Gotta say it, the old ones are the best.....
Old 23-08-2005, 14:53   #8
Rover_ron
Who makes this engine?
Seems a bit poor taking cables out of the bottom like that.
Why not out of the top of the rocker cover I wonder?
Rover_ron is offline   Reply With Quote
Old 23-08-2005, 16:13   #9
Vitessesqauddie
Car: Rover 800
BMW engine, need i say more.
i find the germans are very good at reinventing the wheel.
Old 23-08-2005, 16:38   #10
Dr Dave
Administrator
Dr Dave's Avatar
Nope....it's a Rover engine from start to finish....allowed to complete by the then owners, BMW.
Old 23-08-2005, 16:42   #11
MattL
Car: MG ZT 180 SE in XPG.
Still built by Land Rover in Solihull. Only goes in Defenders now though. Stripped a few of them down myself. Interesting design isnt it. BMW did finish it off lots of very expensive German parts in it. One thing BMW did do was look after other German suppliers! Our own design though.
MattL is offline   Reply With Quote
Old 23-08-2005, 16:51   #12
Dr Dave
Administrator
Dr Dave's Avatar
Definately a nice engine, a bit different, especially with the centrifugal oil filter.
Better suited to an automatic transmission really...bit easy to stall otherwise.
Old 23-08-2005, 19:21   #13
Vitessesqauddie
Car: Rover 800
i stand corrected.
i thought it was a development of one of BMWs engines.
Old 23-08-2005, 20:56   #14
CAM4V
CAM4V's Avatar
Car: Jaguar XK, Honda CRV iVTEC, Rover 75 CDT Auto
allegedly a cracking engine, quite how/what the centrifugal oil filter is and how it operates is as yet unknown to me.
As for the wiring, one presumes a regular 'clean' with a rag and some WD40 would keep the wiring clean and prevent ingress into the ecu, or alternatively deliberately fit a 'tie' (a deliberate low point in the loom) such that the wayward lubricant goes down there and not into the 'brain'
Interesting piccy's though....and a cam chain...eh?
CAM
CAM4V is offline   Reply With Quote
Old 23-08-2005, 22:11   #15
X70WER
Car: MG ZT-T 260 V8
The S Series was one of the first Austin Rover engines that had electrical connectors running in oil, but on the outside of the engine.....
X70WER is offline   Reply With Quote
Old 23-08-2005, 23:40   #16
technozen
Mmmm....Rover..
technozen's Avatar
Car: 200vi & Freelander XEDi
Send a message via MSN to technozen
I've seen this one before Dave, I was amazed to see engine oil in an ECU, especially as (IIRC) it's mounted under the drivers seat!!
I was asked to try and repair the ecu, it was obvious that a resistor and a transistor had burnt out....unfortunately I had no way of figuring out the component values/type.
technozen is offline   Reply With Quote
Old 24-08-2005, 06:11   #17
Dr Dave
Administrator
Dr Dave's Avatar
Yeah....that's it, the ECU under the drivers seat, full of oil.
This one hadn't got this far, thankfully.
td5 turbo for ZR T.Morris Diesel Forum! 2 24-01-2008 20:37
Land Rover TD5 fevsisere MG / Rover Related Chat - up to 2005 7 08-01-2007 21:07
discovery philips R770 WIRING PROBLEM softwoodsawmill In-Car Audio, Entertainment, Sat Nav etc... 5 09-12-2005 17:55
TD5 diesel Freelander MG / Rover Related Chat - up to 2005 11 14-01-2005 12:16
