Anyone know where I can source one of these? Ebay seems to only have thermostats for the K-series.. I can't find any for the L-Series.
I've got a Rover 45 2001 (Y reg) 2.0iL TD model.
No major rush, but I'm going to service the engine shortly and would like to swap out the thermostat at the same time as my heaters are pretty luke warm and fairly sure the thermostat is to blame!
Hmmm i would be interested in doing this aswell as mine is warm but i feel its not as warm as it should be. I assume it would be the same part as the 45, being the same engine and all?
Engine model is down as 2.0i .. is that the TD engine? I wasn't sure if they did a 2.0 petrol model or if the 2.0i is the diesel model.. I saw this listing earlier lol
Mine is a 2001 year so that'd do the job!
I should imagine the one you've found for the 25 will fit if it's for the 25 as the ZR is basically the same car, but I don't know enough about which engine model is in which car to be sure .. as the above shows :lol:
My air is luke warm and it takes around 15-20 miles for the temp gauge to reach the halfway point.. and in really cold weather (-5 or below) it never reaches halfway unless I get the car up to high speeds on a dual.. and even then it struggles.
im having to do this job on my 25 td when i either get money to get a garage to do it of do it myself .
theres loads of talk on that some are sealed units some not .
mines takes ages to warm up when really cold like -5 after like 15 miles its just reaching where its ment to be and when i restart the car the temp is down again so i think its defo thermostat.
Yeah.. need the whole sealed unit .. not sure if Rimmer Bros supply it?
If I can get a Land Rover part for less and it'll do the trick then I'll go for that.. but again, not sure which part it is.
Related Threads
MG-Rover.org Forums
5.9M posts
138.9K members
Since 2001
