Before you go the route of a new clutch, you need to consider flushing the clutch hydraulic system. If you need to put pedal to the floor to engage gear you could have any of the following.
1) leaking slave cylinder
2) leaking master cylinder
3) Low hydraulic fluid in clutch system
4) knackered clutch.
Regards
Had my 2002 75 diesel clutch replaced last week. 80k miles. Symptoms were pedal getting closer and closer to floor before disengage. Used my local and trusted garage who found that slave and master were leaking - apparently a problem on this model. Big job to replace as box needs to come out so had clutch plate assembly done at same time. Total cost inc vat was £750 so your quote is not far off. Do make sure that if you have cruise control that they adjust contact switch on clutch pedal otherwise might not work. My own garage missed this but since sorted. Seems sensible to do slave master and plates all at same time.
Not into auctions Mike, just merely informing the price of parts this time last year. Only trying to be helpful, I dont give 2 hoots if I dont have to touch another one. And yes it has been a bad day lol.......
Related Threads
MG-Rover.org Forums
5.9M posts
138.9K members
Since 2001
