620 Sdi gear lever? - MG-Rover.org Forums
Go Back   MG-Rover.org Forums > Model Specific Forums > Rover 600
Old 04-07-2012, 08:48   #1
tomz
Car: Rover 600 SDi
620 Sdi gear lever?
Hi all, have recently taken the gear lever apart because of the annoying rattling noise around 2000 rpm. There is a plastic kind of cup in which the ball of the stick goes into. Seems like that cup has partly worn away during the years causing the dreadful rattle. Do you know if I can find the item new or do I look second hand? Also, will it fit from a 600 Honda? Thanks!
tomz is offline   Reply With Quote
Old 04-07-2012, 08:56   #2
the chauffer
Car: 25 Turbo Diesel
Im not to sure which part you are talking about, but have a look on this page and see if its there. If its not available at rimmers, just google the part number and it may pull something up.
the chauffer is offline   Reply With Quote
Old 04-07-2012, 09:03   #3
tomz
Car: Rover 600 SDi
Cheers, looks like it's no12 from the diagram(bearing ball) Hope that cures the problem.
Old 04-07-2012, 18:18   #4
MGJohn
MGJohn's Avatar
Car: MG Montego Turbo; Rover 25; R620ti x2 & MGZS 120+ x2
This may be of interest :~
Two Rover 600 ti and SDi Gear lever options :~
Rover 620ti and SDi Gear Levers including Quickshift Modification
PM me if anyone interested.
So, now you wanna buy a BMW .... Huh! No natural class ...
Normally aspirated engines suck. They really do. Good job turbocharged engines blow and suck. That's better.
MGJohn is offline   Reply With Quote
Rover 620 Sdi Gear box linkage rod. HELP!!! Mines broken JimboCabby Wanted 0 09-02-2009 18:39
420 SDi gear lever - upgrade Rack Diesel Forum! 6 14-04-2007 21:18
620 SDI Gear stick, excess play Tabs Rover 600 8 19-04-2005 22:13
gear change is stiff on my 620 sdi ?? off the couch Rover 600 6 02-10-2004 07:59
Rover 620 SDI gear problem BLIZZARD Rover 600 6 15-04-2004 12:36
