Go Back   MG-Rover.org Forums > Model Specific Forums > MG ZT / Rover 75
Old 21-11-2009, 18:13   #1
danztt
Car: MG ZT-T 190 +
danztt is up and running. Hey we all have to start somewhere.
Horrible Vibration
Got a rally horrible vibration, i think its up front, gets worse when turning left and really bad above 80mph (private road obviously). Any thoughts. I hope its only wheel bearing but open to suggestions. Inc labour what am i looking at fir bearing?
danztt is offline   Reply With Quote
Old 21-11-2009, 18:33   #2
robdrinkwater
Poacher turned Gamekeeper
robdrinkwater's Avatar
Car: MG ZT-T CDTi.
robdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant futurerobdrinkwater has a brilliant future
Could be as simple as a wheel out of balance, could be a wheel bearing or a track rod end, really needs to be looked at underneath to see what has got play.
Therefore cost wise, impossible to tell.
Regards, Rob.
MG ZT-T CDTi, mild tune remap, with 185Ps and 390Nm Torque, EGR bypass, Vortex S/S Exhaust system, modified air intake. Full Mk4 DVD Sat Nav, Widescreen, BM24 Radio, BMW Digital TV, DVD player, DAB Radio, Ipod interface conversion. 190 front brakes. Xenon lighting conversion.
robdrinkwater is offline   Reply With Quote
Old 21-11-2009, 18:52   #3
marley
Car: 75 Conn. S.E. CDTI
marley is just really nice. Awwmarley is just really nice. Awwmarley is just really nice. Awwmarley is just really nice. Awwmarley is just really nice. Aww
Thumbs up
As Rob says! Although, I had a rear whel bearing fitted a few weeks ago, it cost me £126. (he also re-attached the cruise control switch, on the clutch pedal the same time too!).
Mine was more of a "droning" noise though? Which gradually got worse. At first I put it down to worn tyre noise.
marley is offline   Reply With Quote
Old 21-11-2009, 22:06   #4
danztt
Car: MG ZT-T 190 +
wheels have been balanced and tracked recently. track rod ends, wishbone rubbers, and anti roll bars look good and are very solid (no excesive play)
Old 22-11-2009, 01:26   #5
lewisr
Car: connie se cdt
lewisr is up and running. Hey we all have to start somewhere.
Did you get all 4 wheels balanced, I had a vibration a few years ago as soon as I hit 70 MPH and could not find it, again had wheels balanced to no effect at first. Then went to another garage and told them the problem and they suggested it could be rear wheel balance, as all the standard places tend to just do the front wheels. Sure enough cured the problem , has never happened again.
So might be worth getting rear wheels checked.
Ray
lewisr is offline   Reply With Quote
Old 22-11-2009, 10:50   #6
wuzerk
Car: 2003 75 CDT SE Conn.Auto and '57 Minor Convertible
wuzerk is a glorious beacon of lightwuzerk is a glorious beacon of lightwuzerk is a glorious beacon of lightwuzerk is a glorious beacon of lightwuzerk is a glorious beacon of light
Vibration
DANZTT, is it only at speed or does it occur when pulling away? i.e. 'think simple' have you checked the lower engine mount yet?
wuzerk is offline   Reply With Quote
Old 22-11-2009, 12:15   #7
danztt
Car: MG ZT-T 190 +
Havent checked that one yet. however vibration is always there just gets worse turning left.
Lewisr. Had all for wheels off, balanced and 4 wheel laser tracking carried out by Kwik Fit.
Old 22-11-2009, 12:47   #8
pernix
Car: Rover 75
pernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these partspernix is becoming God like round these parts
Could be worn /bent drive shaft or failing cv joint.
pernix is offline   Reply With Quote
Old 22-11-2009, 15:53   #9
robdrinkwater
Car: MG ZT-T CDTi.
OK, did the vibration occur before the wheels were balanced? If not, then get it back to whomever did the balancing and get them to do it right this time, they do make mistakes.
If it was there before, the vibration can only come from an imbalance, so drive train, wheels & steering components are favourite.
MAybe even a distorted tyre.
Regards, Rob.
Old 23-11-2009, 19:37   #10
danztt
Car: MG ZT-T 190 +
The vibration was present before the balance and tracking was done. I did have quite badly pitted/corroded brake disc on the front but i changed all discs and pads. Vibratio still present, when i changed the brakes I checked all bushes that i could see for play. carried out the usuall shake and rotation of wheels to check for play in bearing but couldnt find anything out of the blue, all cv boots look good with no seepage of grease, also no noticable grinding or knocking from cv joints. Starting to run out of ideas. I have somebody putting the car up on ramps on wednesday to check lower engine mount, anything else i should have checked/looked at whilst the car is on the ramp? I a really stumped now. and its bugging the crap out of me. if ti is the engine mount why does the vibration only get worse when turning left?
Old 24-11-2009, 08:32   #11
wuzerk
Turning left? No idea but,since the lower mount is quite easy to check it is worth a look before you get suicidal!
Old 24-11-2009, 15:03   #12
ts autos
Trader Supporter
Car: MG Express (Van)
ts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these partsts autos is becoming God like round these parts
Check the lower arm back bush bolted on to the subframe the rubber perishes causing fore and aft movement
ts autos is online now   Reply With Quote
Old 24-11-2009, 17:15   #13
newcybrown
Car: MG ZT 190+ (KaTy) 2001 ROVER 800, CLASSIC MINI
newcybrown has a spectacular aura aboutnewcybrown has a spectacular aura about
similar symptoms
I have had very similar symptoms of late, but I have a slight vibration when moving off and if I turn RIGHT then it seems to get slightly worse this only occurs at low speed once the car is up to around 20mph then the vibration disappears.
All the wheels are balanced and tracking is spot on, track rods, drop links, bearings, bottom ball joints, all seem to be ok. Have replaced lower engine mount recently
Pernix post about worn or bent driveshaft seems feasible and also ts autos for the lower arm bushes, will be checking these 2 areas asap.
Thanks to ALL for posting possible solutions to this problem
newcybrown is online now   Reply With Quote
Old 25-11-2009, 13:50   #14
danztt
Car: MG ZT-T 190 +
Have justbeen to a garage and the guy there rekons it could be the Differential Bearing, how likely do any of you rekon this is? He would like to car for 2-3 hours at £50 per hour to confirm his diagnosis.
Item 4 is what he rekons is fubar'd and rimmer want £29.22 each including VAT
How many hours for labor should i rekon on if it is this causing the problem, apparently its a gearbox out job? can anybody confirm this?
Lower engine mount was fine, both wheel bearings are good, wishbones & rubbers fine, and no distortion on the drive shafts just excess play by the diff.
Dont want to get fleaced this close to crimbo.
Any advice welcome
Old 25-11-2009, 23:12   #15
marley
Thumbs up
Personally, Id be mega reluctant to give some guy 3 hours work @£150.00 for something which may or may not need replacing?
Cant you go to another garage/garages for their opinions also?
Old 25-11-2009, 23:19   #16
RitchyP
Car: MG ZS
RitchyP is up and running. Hey we all have to start somewhere.
3 hours labour to remove and strip the gearbox is xheap, and if it doesnt sort it ya dont have to pay if he has diagnosed it wrong
RitchyP is offline   Reply With Quote
Old 26-11-2009, 00:00   #17
harrybozing
Car: Rover 75 Tourer
harrybozing is up and running. Hey we all have to start somewhere.
vibration
A similar thing happened to me a while back, had the front wheel bearings replaced, only to have the fault recur a few weeks later, found out to be excess runout in the front hub, worth checking. Hope you are sorted soon, regards, Harry.
harrybozing is offline   Reply With Quote
Old 26-11-2009, 10:04   #18
marley
Talking
I wish I knew of a garage (come to think of it! even a plumber/builder/electrician etc!) who will do 3 hours work for nothing!!!!!!
Old 26-11-2009, 10:18   #19
Douglas evans
Car: Classic Rover
Douglas evans is up and running. Hey we all have to start somewhere.
Funny old world !
Can I just confirm that I am the said technician that has had a breif look at dan's zt-t at may I state NO COST I have advised Dan that I would like the vehicle for a maximum of 2 hours to confirm the fault , As it could be any number of possible faults usual labour rate is £55 ph plus vat as stated by Dan I have offered the services at £50 ph.
Regards Doug .
Douglas evans is offline   Reply With Quote
Old 26-11-2009, 18:03   #20
danztt
Car: MG ZT-T 190 +
Thumbs up
Originally Posted by Douglas evans View Post
Funny old world !
Regards Doug .
Yes Doug you are the said Technician.
As you can see from the thread you can see where most of the suggestions came from that I mentioned to you. Her who must be obeyed has decree'd that the car must wait until after crimbo. will pop in to the garage in the New Year to arrange for proper diagnosis. Had the car up on the ramp in the motor club today to try and see where the play was you mentioned. if it is that diff then it's got to be a garage job as i dont have the time to do it myself.
Cheers for taking a look yesterday. And Marley, Doug gave up time working on somebody elses car to take mine out and give a provisional diagnosis for nothing. He could have billed me for 30 Mins labour to carry out this work and didnt, so once again Doug Cheers, probably one of the reasons you get so much work from the Station.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Horrible Rattle northwest4u MGF and MGTF (Sponsored by MG Rover Parts Ltd) 9 10-02-2006 16:13
Powered by vBulletin® Version 3.8.0 Beta 2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Site designed, operated, funded and not least owned by Online Enthusiasts Ltd. Steve Childs and or Online Enthusiasts Ltd are in no way endorsed by or affiliated with MG-Rover Group Limited. This site is run by MG-Rover enthusiasts for MG-Rover enthusiasts. Any content of the forums should in no way be taken as official statement or views of either MG Rover Group Ltd, Online Enthusiasts Ltd, their suppliers, their employees or their advertisers, unless otherwise indicated. Please do not take any content from this site without prior written permission from Steve Childs. Any reference to speed or driving styles either actual or inferred on the pages within this website should not be taken as encouragement to drive irresponsibly either within the speed limit or in excess of. Please drive responsibly.
Terms and conditions of use
