| Sponsored Insurance Links: | Car Insurance | | | Van | | | Home | | | Bike | | | Travel | | | Breakdown | | | Convicted Driver Insurance |
Thread Tools | Rate Thread | Display Modes |
#1 |
Front suspension arms
These are hardy cast units, unlike the pressed steel c*** on other cars such as Ford etc.
That said, mine are knocking very bad all of a sudden. On jacking each side up this morning there's a lot of side movement, 3-5mm in fact. Track rod ends are absolutely fine & free of movement. Re-bush arm or a complete new unit is my question??? Budget is low as just re-located 300 miles south. Ta |
| Sponsored Links | |||
Advertisement | |||
#2 |
Bottom arms for 1.8 litre + engine size are horrendously expensive if available OEM, & were not available as pattern parts when I wanted one 3 years ago (1.6 & 1.4 litre engine size have different bottom arms as ball joints have smaller tapers). So probable re-bush.
#3 |
Is it the lower arm or upper control arms? If it is the upper arms - these are readily available, and not that expensive. If it is the lower arms, then I completely agree with the post above me. Be very carefull as any cheaper ones tend to be for the smaller engined ones. I diddn't know this, and purchased a lower arm for my 45 from GSF car parts for about £60......turned out that the tapered hole in which the lower ball joint fits, was to small. There are two sizes - 15.5mm and 17.5mm.
#4 |
They are described as cast parts. So not the upper arms then.
#5 |
Aye, indeed they are the lower arms giving trouble.
Right, be looking at re-bush then no doubt. My 400 went nearly 100,000 further on front arms, but then again the ZS is such a stiff ride in comparison it's bound to get more stress. Thanks all |
#6 | |
#7 |
Location: Aberdeenshire / Edinburgh Car: Rover 414IS, Volvo V70 2.4DSE, SEAT Leon Cupra
Rimmers have the same lower arms listed for ZS 1.8, TD and 2.5. And as mentioned above not cheap - £284 EACH, but that's inc VAT.... lol....
#8 |
http://www.ebay.co.uk/itm/Front-Trac...item45fde9cb93
lists only the 120 and 180 engines so you may be in luck ,but still double check . |
#9 |
did you notice any knocking noise driving over small bumps (cobble streets etc) ?
ive got this multiple knocking from the footwell / behind dash area that im struggling to locate without fully removing the arms to see. Visually all the bushes look ok and using a pry bar it all feels solid damn these potholed roads, ive never had knocking on any car with only 74k on the clock
#10 | |
Octo to the pus!
Discount MG Rover Spares - www.dmgrs.co.uk ![]() Heater speeds 1&2 not working? Click Here 400/45/ZS high clutch pedal? Click Here Rover 25/45 ZR/ZS oil cooler pipes Click Here K & L Series Cambelt Kits Click Here |
#11 |
I think they will be the 1.4/1.6 arms complete with incorrect listings.
When I tried to get a pattern part for a diesel, which I was assured was available I was first sent the wrong side arm. Sent it back but didn't check the ball joint size. Was replaced with correct side arm - got it onto car - oops ball joint doesn't fit - "thats the only left hand arm there is". Got an arm from a breakers off a 1.8 Zs to fit my 45 diesel - it fitted. |
#12 |
Octo to the pus!
I've bought an arm for my ZS diesel off eBay and it was correct. You can get them.
#13 | |
Actually, I purchased a lower arm for my Rover 45 1.8 from GSF car parts Ebay store, turned out to be INCORRECT. When I spoke to them on the phone, after they done some research they came back and told me that they only stock that one type - with the smaller hole for the ball joint. Why they have not updated their website I do not know - they specificly told me that their lower arms are for the smaller engined models. |
#14 |
#15 |
Looks like that was too hard a question!
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | Rate This Thread |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Trophy front lower suspension arms | Captain Slow | MGF and MGTF (Sponsored by MGF Mania) | 2 | 03-03-2012 17:39 |
| MOT failure: Rear suspension arms and front chassis steering component welding | mmm....beer | MGF and MGTF (Sponsored by MGF Mania) | 14 | 14-04-2010 17:11 |
| Lower Suspension arms | Jazz | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 0 | 30-04-2007 08:16 |
| suspension arms | muzza | MG ZR / Rover 25, 200 & Streetwise | 1 | 29-03-2006 15:41 |
| Upper suspension arms | Vsport | Wanted | 0 | 26-02-2004 23:43 |
