Hi - Hope someone can help...
recently had an overheating problem - car would not start after this - a couple of mechanincs diagnosed the problem as blown head gasket, 2 cracked pistons,cracked block and slightly worn tappets. - the car now runs OK (ish) but is a little noisy.
The mechanics changed everything except the tappets (ran out of money at this point) - the car has one final problem to get sorted. - when idling at traffic lights etc the engine is revving at about 2500 - 3000 rpm - a quick blip on the accelerator can reduce this to about 500 for a few seconds but then it rises again.
Also if i hit the aircon button the revs will drop and the engine will cut out.
Not sure where to start on this one - any one got any ideas.
