Hi , I have a 98 Rover 400 1.4 .The heater is not working . I have topped up the coolant 50/50 but there is a small leak that appears to be coming from under the car. Is there a thermostat and how serious is this problem Can someone advise
Regards
Tony
Thanks to you bobdope (love the handle) .So the heater is not working as I said and currently the water/antifreeze is leaking when I start up the car. You say this is an air lock. Would it be safe to drive the car to a garage or do the process you suggest in my driveway.Thanks tony
I had the head gasket replaced 12 months back . Could the fact my heater is not working and there is a leak be a HGF again. Espensive problem I know Fan is working just produces cold air
Is it also possible the thermostat needs to be replaced.
WOULD A LEAK BE THE CAUSE OF AN AIR LOCK
AS it has been suggested I might have an air lock .
One more thing ,Would I be advised not to drive the car to a mechanic or try to solve the problem in my driveway.
Any help would be appreciated. Tony (a musician)
im really not sure take it to a garage mate to have it checked unless some else knows how to sort it
Related Threads
MG-Rover.org Forums
5.9M posts
138.9K members
Since 2001
