Mg Zr - Loss Of Drive When In Gear - MG-Rover.org Forums
Old 24-11-2005, 21:45   #1
reggi
Car: MG ZR
Hi all
I am desperate for some help. I have a MG ZR 105 2002 with 30,000 miles on the clock.
I was driving back from work the other day when suddenly my car stopped driving. It was still in gear and the engine was running, but just rolled to a stop. I tried selecting another gear but yet nothing was happening. The engine was still running the revs were still working as normal and the speedometre was moving up the more I accelerated, and yet i was stood still. I could hear a faint clanking noise until i put my foot on the clutch.
Anyways i got towed home and was told the gearbox was gone.
The following morning i started the car up and it seemed to have healed it self over night. But i didnt want to risk taking it any where incase I broke down again.
Any ideas on what the problem is before i get conned into buying a reconditioned gearbox and getting it fitted.
Also there are no suspicious noises, it still sounds the same as it did a year ago.
All suggestions are welcome
Thxs
reggi is offline   Reply With Quote Quick reply to this message
Old 24-11-2005, 21:47   #2
M4RTIN
Car: streetwise again.. :)
Send a message via MSN to M4RTIN Send a message via Skype™ to M4RTIN
hmm must be something to do with loose diffs.. i'd say a new gearbox would be safest
M4RTIN is offline   Reply With Quote Quick reply to this message
Old 24-11-2005, 21:50   #3
Rapid Silver
Car: '97 Rover 200vi
Send a message via MSN to Rapid Silver
You might want to get your clutch checked out? Have you had a cable snap or something?
Could be a lot cheaper to repair a clutch than a blown box.
Rapid Silver is offline   Reply With Quote Quick reply to this message
Old 24-11-2005, 21:50   #4
Respot
Car: Other Manufacturer
Hi Reggy,
I think I would check the driveshafts first.
DaveH
Respot is offline   Reply With Quote Quick reply to this message
Old 24-11-2005, 21:51   #5
MGJohn
MGJohn's Avatar
Car: MG Montego Turbo; 620ti x3; MGZS; MGF and MG ZT 1.8t x2
Originally Posted by reggi
Hi all
..... It was still in gear and the engine was running, but just rolled to a stop. I tried selecting another gear but yet nothing was happening. .....
Thxs
That's a clue...
Can you select gears without using the clutch whilst engine running?
If so, maybe Broken, Snapped or dislocated driveshaft?
__________________
Apparently ... in a parallel universe MGJohn drives .........A.......
B>>M>>W ....
Arrrrrggghhhhh......... ......
MGJohn is offline   Reply With Quote Quick reply to this message
Old 24-11-2005, 21:59   #6
reggi
Car: MG ZR
Hey thxs for the replys
The thing is i dont understand why it runs fine now
The guy who rescued me said he checked the driveshafts and said they were fine, as they were not hanging out, which lead him to beleive it was the gearbox.
Old 24-11-2005, 22:00   #7
M4RTIN
how were you driving at the time? ..was it just normal driving and it just stopped working all of a sudden
Old 24-11-2005, 22:02   #8
reggi
Car: MG ZR
I was going about 30 to 40 mph and it just stopped - I can't rember if i changed gear when it happened
Old 24-11-2005, 22:06   #9
reggi
Car: MG ZR
The other thing is surely I shouldn't be getting gearbox problems when the car has only done 30,000 miles
Maybe I'm just one of the unlucky few
Old 24-11-2005, 23:03   #10
MGJohn
MGJohn's Avatar
When you say it runs fine now - do you mean it's now driving OK?
If not, can you select any gears easily with the engine running without using the clutch?
>>as they were not hanging out<<The driveshafts could be broken or dislocated INSIDE the CV-joints or rubber boots. I've even known them break under that dynamic balancer thing where permanently damp unseen corrosion eats away at the shaft until it snaps under power.
Difficult to give an accurate diagnosis remotely without a comprehensive description with facts.
__________________
B>>M>>W ....
Old 28-11-2005, 12:32   #11
reggi
Car: MG ZR
Thanks for the replys,
I now know why I have no drive. This is because the gearbox keeps pushing the drive shaft out. I have had a new one put in, but the gearbox still rejects it.
So looks like i'm goner need the gearbox looked at. I'm told it is probably to do with the planetry gears. So I will have to face the expense and get a gear speacialist to look at it.
Is this a common problem in MG ZR's does any one know? or does any one know a likely cause for the gears to fail in a low mileage gearbox?
Reggi
Old 28-11-2005, 12:35   #12
Dr Dave
Administrator
Dr Dave's Avatar
Car: 2006 330d M Sport
Common problem on the PG1 box - but not seen this happen on the R65 MA based gearbox.
The good news is that they aren't expensive. Shop around but don't go for the cheapest box!
Dr Dave is offline   Reply With Quote Quick reply to this message
Old 28-11-2005, 12:56   #13
reggi
Car: MG ZR
Thanks for the advice Major
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
MG ZR Random Power Loss batty1cat MG ZR / Rover 25, 200 & Streetwise 0 03-08-2008 19:10
MG ZR Water loss Wellie MG ZR / Rover 25, 200 & Streetwise 4 01-08-2008 17:43
MG ZR loss of acceleration jamsterscot Diesel Forum! 4 01-04-2008 15:16
ZR Power Loss on 5th Gear bm_eu MG ZR / Rover 25, 200 & Streetwise 16 26-12-2006 23:25
mg zr tdi coolant loss Lee Rob MG ZR / Rover 25, 200 & Streetwise 7 07-07-2005 17:01
