Rover 400 dipped beams - MG-Rover.org Forums
Old 12-01-2006, 18:20   #1
doublekite
Car: 2002 '52' Rover 75 CDT Connoisseur and '02' CDT Classic SE
My father in law has a 1996 Rover 400 SLi.
Tonight, after stopping for petrol he could only get side lights and main beam at the front when restarting his journey. I have checked the fuses and this is not the problem. Its very unlikely that both bulbs would go together, so what may it be?
doublekite is offline   Reply With Quote
Old 12-01-2006, 23:21   #2
E_T_V
Car: Maestros, 200, 600, ZTT
Could be the dim/dip unit (vile pink relay), or it could be that he's had a headlamp out for a long time and not noticed till the other one went.
E_T_V is offline   Reply With Quote
Old 13-01-2006, 05:23   #3
rqt
Car: Rover 45
CHECK THE BULBS FIRST.
I have had both bubls blow simultaneously in similar circumstances, & using the same logic spent hours investigating, only to eventually find 2 blown bulbs!!
rqt is offline   Reply With Quote
Old 13-01-2006, 18:34   #4
doublekite
Thanks for the advice. Where is the pink relay?
Why should both bulbs go together?
Old 13-01-2006, 20:22   #5
santa20
Car: Volvo S60 R, Rover 25 1.8Auto, VW Passat TDi Estate (Until I get rid of it)
Send a message via MSN to santa20
Ive had both bulbs go at the same time, in theory it should always happens, you generally fit 2 bulbs of the same type at the same time and use them the same amount
santa20 is offline   Reply With Quote
You may not post replies
axle beams cdti_88 MG ZR / Rover 25, 200 & Streetwise 5 19-12-2007 17:35
Rover 214 SLi dipped beam talusmore 'R8' Rovers (aka Wedges!!) 2 19-09-2006 16:25
Dipped beam - not dipped dazultra2000 Others 8 13-02-2006 22:22
400 Dipped beam doesn't work zzzmej Others 2 22-12-2004 21:52
Replacemnt Dipped beams Talion MG/R Modification & Tuning 18 28-09-2003 14:11
