Go Back   MG-Rover.org Forums > Model Specific Forums > MG ZT / Rover 75
Old 20-01-2006, 11:31   #1
Rincewind
Homologation Engineer
Rincewind's Avatar
Car: MINI Cooper S Works
Rincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant futureRincewind has a brilliant future
Send a message via MSN to Rincewind
R75 & MG ZT/ZT-T Diesel Identification Codes
As some people appear to be interested and I've been requested to do it, I've put together a document that lists all of the variant and version codes used for the Rover 75 and MG ZT/ZT-T diesel engines. Sorry it's taken a bit of time to get sorted and on the forum.
In the document you will find the codes used to determine what engine tune you have in your vehicle (either 116 or 131ps). One document looks after Rover 75 Saloon and Tourer and the other one looks after MG ZT & ZT-T (sorry that they are not very pretty to look at. If someone wants to make them look pretty, please carry on, just let me know what you've done before you "publish it" so to speak).
You need to look at your V5 document and at the top there should be 2 lines, one saying Variant and the other saying Version. Match these codes to the document and you should find out if you have what you think you have!
Any problems, drop me a line. I think that I have captured all of the codes, but having gone through documents from 1998, there are quite a few and I may have got a bit number blind!
Hopefully this will help you identifiy what your car was at the time it left MGR at Longbridge and if it's been "fiddled" with since. I hope that it is of use to you all.
Nic
File Type: doc MG ZT & ZT-T Diesel Variant & Version.doc (35.5 KB, 932 views)
__________________
Rincewind had been told that death was just like going into another room.
The difference is, when you shout, "Where's my clean socks?", no-one answers
MGR stories, MGR help and advice all available at no extra cost !
The Two Sixties - it's a V8 thing ... Honorary Member and Puddle of V8 Knowledge et al.
Rincewind is offline   Reply With Quote
Old 20-01-2006, 18:57   #2
Keith Alexander
Search first, ask later
Keith Alexander's Avatar
Car: ZT 400 and a T4
Keith Alexander is a splendid one to beholdKeith Alexander is a splendid one to beholdKeith Alexander is a splendid one to beholdKeith Alexander is a splendid one to beholdKeith Alexander is a splendid one to beholdKeith Alexander is a splendid one to beholdKeith Alexander is a splendid one to behold
Coo thanks
from your table it is now blindingly clear, mine is a Blue one.......
__________________
Keith Alexander is offline   Reply With Quote
Old 20-01-2006, 21:21   #3
fmfanuk
Car: MG ZT-T+ CDTi 135
fmfanuk is up and running. Hey we all have to start somewhere.
Rincewind thanks for doing this, had a bit of a worry with my ZTT 135 CDTi, the V5 checkes out as 03C which is the 116 version, however after checking my VIN plate and seeing the white XPower sticker, it appears that the XPower upgrade was fitted at some point in the car's life.
fmfanuk is offline   Reply With Quote
Old 24-01-2006, 11:58   #4
Rincewind
Rincewind's Avatar
Not a problem, that's why I did it so people could check their cars. At least yours has been done properly and maked up correctly.
__________________
Old 24-01-2006, 15:29   #5
Vinny
Car: MG ZT
Vinny is up and running. Hey we all have to start somewhere.
Hmmm ... how else can I tell what version I have, as our documentation in Ireland is different?
Vinny is offline   Reply With Quote
Old 24-01-2006, 15:31   #6
Rincewind
Rincewind's Avatar
Give me as much information as you can about the car. do you have any kind of V5 information that you could give me?
__________________
Old 24-01-2006, 18:22   #7
Grendel
Car: MG ZT
Grendel is up and running. Hey we all have to start somewhere.
Anything similar for 160/190 ZTs Rince?
Grendel is offline   Reply With Quote
Old 24-01-2006, 18:32   #8
Rincewind
Rincewind's Avatar
I'll have a crack, that could take even longer to sort out, but yes, I should be able to sort something out for the petrol version cars. It's getting a bit busy again at work, so it make take a little longer to sort than it did with the squiesel versions (and that was a while!) but I'll try and sort it out for everyone.
Nic
__________________
Old 07-02-2006, 05:31   #9
johnnysvoid
Car: rover 75 con se cdt
johnnysvoid will become famous soon enoughjohnnysvoid will become famous soon enough
Wink
rincewind thanks for the variant codes. i checked my car out last night but there was no variant code on the log book! there were other details missing as well. it is the new type of log book.
i also checked out the wifes and that was a 116.(all ok there)
could anyone check there taxation class and let me know what a diesel saloon should be? we have 2 identical cars with 2 taxation classes!!
cheers ... john
johnnysvoid is offline   Reply With Quote
Old 07-02-2006, 09:13   #10
johnnysvoid
Smile
with ref to the above request about the taxation class - it is because the 1st car was registered in 2000 and the wifes was registered in 2001. something to do with emissions testing. two identical cars but two levels of road tax!
john
Old 07-02-2006, 11:48   #11
Keith Alexander
john
Yep a crazy situation my 75 CDT costs less to tax than my slightly older Picasso even though the Picasso produces less emisions Silly or what!
__________________
Old 07-02-2006, 18:03   #12
Rincewind
Rincewind's Avatar
In a nutshell, yes it's all to do with emissions levels and what not and also the introduction of the different taxation rules by the govt!. All very confusing and far too lengthy to go into here as the emissions directive when printed out is 1" thick and depending on when it was registered, different taxation classes were banded about.
__________________
Old 08-02-2006, 11:22   #13
Vinny
Car: MG ZT
Sorry about the delay - all I have is the chassis number, believe it or not. Can't see anything on the registration certs that give this level of detail. Is there anything on the car itself that might help here?
Old 26-01-2007, 13:53   #14
MARTIN1973
Car: MGZT cdti+ 160 upsolute chip & TU3B
MARTIN1973 is up and running. Hey we all have to start somewhere.
Dragging up an ancient post was trying to find out if my ZT was a 131 or a 116. No x power sticker on the car and V5 says its a 03C version which makes it a 116, however if the dealer did the bhp upgrade would this not show up on the V5? The dealer has closed and is now a caravan dealer so cant check with their records. Any other way of telling, except for a rolling road?
MARTIN1973 is offline   Reply With Quote
Old 26-01-2007, 14:03   #15
Ian
Administrator
Ian's Avatar
Car: Rover 75 2.0 CDTi Connoisseur Auto, Ford Kuga Titanium 2.0TDCi 2WD, Honda Accord Type S, Mercedes C
Ian is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on hereIan is one of our most respected members on here
No, if the dealer has upgraded the car retrospectively, it wouldn't show up anywhere, or on the V5.
I am led to believe that dealers were supposed to add the X Power sticker if they did the upgrade, but I would imagine that some forgot.
Ian is offline   Reply With Quote
Old 26-01-2007, 14:12   #16
MARTIN1973
When i can find a rolling road fairly local I may put the car on just to see what the true remap figures are. Knowing main stealers the sticker was probably £15 plus £33.98 + VAT in labour for application
Old 26-01-2007, 14:13   #17
Ian
Administrator
Ian's Avatar
Cor thats cheap - where do I sign
Old 29-01-2007, 15:07   #18
pondweed
Car: Roverless and fancy free
pondweed is up and running. Hey we all have to start somewhere.
it will show up on testbook as to whether the tune is 116 or 131. I checked mine (had xpower upgrade after delivery... wanted to know it was still there!)
Tune is component of the ZCS coding.
pondweed is offline   Reply With Quote
Old 29-01-2007, 15:17   #19
Isis
Car: Moonstone Green Rover 75 CDT Tourer Conn SE with Upsolute remap and Synergy 2
Isis is up and running. Hey we all have to start somewhere.
Would testbook show a remap like Upsolute?
Isis is offline   Reply With Quote
Old 29-01-2007, 16:03   #20
Ian
Administrator
Ian's Avatar
I was thinking more paper based and visual vehicle checks. Thanks for the info pondweed about testbook though, its good to have these things confirmed
You may not post replies
MG ZT / Rover 75 - Diesel Tank & Pump Info Rover_ron MG ZT / Rover 75 344 25-04-2010 16:25
R75 & ZT ATC Diagnostics JCBZT160+ How Do I - Answers To Common Problems. 1 17-01-2006 18:02
What's the differance between the R75 Diesel and the MG ZT Diesel? PaulMGZR MG ZT / Rover 75 4 13-10-2004 16:44
MG ZT & ZTT Diesel Parking Heater Option Dr Dave MG ZT / Rover 75 2 02-11-2002 07:23
XPower Diesel Upgrade available for the R75, R75 Tourer, ZT & ZT-T Wed andy MG ZT / Rover 75 18 22-08-2002 06:38
Terms and conditions of use
