#1 |
PG 1 Gearbox Oil
Hi
I need gearbox oil for my 160 gearbox. I know that it is mtf94. But my local factors don't stock it. They have contacted miller oils for me. and millers say that it is the same as 10w40 engine oil? Is this true?????? |
| Sponsored Links | |||
Advertisement | |||
#2 |
"and millers say that it is the same as 10w40 engine oil?"
If that is so, rover would have put synthetic oil in it would they have not. tell you what .Ive just opened my can of it ...and it smells like nothing Ive ever smelt before..slight strawberry smell to it..so it cant be normal engine mineral oil ....maybe it is something synthetic. all the best..mark |
#3 |
No it's not. www.75andztclub.com click Dealer Locator.
#4 |
The PG1 box fitted to maestros and montegos are 10w40 however they have an oilchange interval of 40k miles. MT95 is very similar and infact for top up purposes many manuals say 10w40 is the stuff to use. I'd try getting the right stuff if you can, but if you are just topping it up then good quality 10w40 should be fine.
#5 |
Thank you all
I'm changing it so i'll try and hunt some mtf94 down. unless many of you think different? |
#6 |
Guest
Posts: n/a
I used SAE80 gear oil in my 820- it's been fine.
#7 | |
No problems with stiff shifting on a cold morning. Seen some ridiculous prices of over £20/litre, but it is £11 for 946ml here: http://www.fluke-motorsport.co.uk/pr...roducts_id=137 If someone is running a 220 Turbo or chipped diesel (I know you're not), might be worth using, due to the high torque |
#8 |
my gearbox has semi-sythetic engine oil in it, works fine.
| Bookmarks |
| Thread Tools | |
| PG! gearbox and castrol smx s | touche | MG ZR / Rover 25, 200 & Streetwise | 12 | 05-09-2008 00:19 |
| 214si 16v Engine Oil, Gearbox Oil | SplateKseries | MG ZR / Rover 25, 200 & Streetwise | 4 | 05-06-2007 17:39 |
| 200 Vi's PG-1 gear box... | redVi | MG ZR / Rover 25, 200 & Streetwise | 7 | 27-01-2007 07:34 |
| PG 1 gearbox bearings and bits | theskrebs | Others | 0 | 06-05-2005 19:08 |
| Gearbox 620DI topped up with gearbox oil | *Victor* | Rover 600 | 4 | 13-08-2004 18:58 |
