Here goes :- Since my car wasn`t put together in the best possible way ie sunroof drain pipes not connected I`ve become slightly paranoid about ingress of water.Hope this helps for anyone who does not know where the middle drain hole is on there Rover 75 /MG ZT etc.
Engine bay drivers side with leaf grill removed.
Closer picture of pollen/air filter (thick red cable is my added amp!)
Oh look a drain right by the ecu (no worry 6 inch of water trapped may kill it !)
Found a wooden pole that fitted drain hole ,pushed out mushy old leaves through car on to drive.
Passenger side has a blank grommet so more water can travel to middle drain (Mk feature on mgzt)White arrow at extra cost.
Found a carrot fingered person with small terminal driver to help unblock drivers side open grommet.
Hope this helps anyone with water ingress at the front of the car.
Sunroof problem after connecting the drain pipes & using tie wraps to hold them on, took me 6weeks to dry the car out (32k list price car, not bitter - not half)
