Old 16-05-2006, 18:37   #1
Mark.L
Car: Honda S2000
Mark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant futureMark.L has a brilliant future
Roof/window leaks...
Another job done on the new TF today!.
In heavy rain water would drip down the inside of the passenger window!.
As you can see from the first pic below its easy to see why!!!..
Had a similar leak on the old `F` and same cure applied to the TF if its any help to anyone!.
In the first pic it looks like the window is out of line as its not pushing against the screen seal as it should, but instead going over the side creating the gap!.
The problem is caused by the seal on the corner of the screen/roof bending in and down as the seal locating peg loosens and bends, so not pushing the seal against the window.... hence the gap!.
The cure is to remove the hood clamp bracket (screen), then pull away this seal....... its then a case of lifting the seal and re-locating the peg fully in its hole, this should bring the seal `out and up` to meet the top of the window!........ a small adjustment of the hood clamps was also needed to eliminate a tiny remaining gap!
You can see the difference it makes in the second pic!!
Mark.L is offline   Reply With Quote
Old 16-05-2006, 18:53   #2
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
*pete runs off to the garage with spanners*
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 16-05-2006, 19:19   #3
James C
Sports Tractor
James C's Avatar
Car: MG ZT CDTI 135+ & MG ZS 180
James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1James C has reached their true position at number 1
Send a message via MSN to James C
Wait for me! It's better than my insulation tape fix!!
__________________
MGF Register (Yes I'm aware I own a ZT) Webmaster & Resident Loon
james.curgenven@mgfregister.org
Custom MJS Straight Through Exhaust, Decat, 20PSI Boost, MKIII Air Intake (Ducted to Front Bumper), Synergy 2, EGR Bypass, K&N Filter, 190 Brakes with Redstuff pads & Earl's Custom Stainless Braided Brake Hoses.
James C is offline   Reply With Quote
Old 16-05-2006, 20:22   #4
mgfjackson
Car: MGF
mgfjackson is up and running. Hey we all have to start somewhere.
ah cool i just leave the window down a bit and push it into the rubber, but im gonna have a go at it
mgfjackson is offline   Reply With Quote
Old 16-05-2006, 21:52   #5
Petevick
regained interest
Petevick's Avatar
I think I'm going to spend some time and put all these great little 'fixes' into a 'how to' web site, wadda think ???
__________________
Old 16-05-2006, 21:55   #6
M77XNE
Car: Audi TTR 225 :)
M77XNE is a splendid one to beholdM77XNE is a splendid one to beholdM77XNE is a splendid one to beholdM77XNE is a splendid one to beholdM77XNE is a splendid one to beholdM77XNE is a splendid one to beholdM77XNE is a splendid one to behold
Send a message via MSN to M77XNE
I'm going to get my dad on the case at the weekend to sort my leaks out for me. My dad is great - after all, what are dads for!?!?!
and Pete, I think you have a fab idea there!! Do you fancy your own personal PA???
M77XNE is offline   Reply With Quote
Old 16-05-2006, 22:05   #7
Mark.L
Car: Honda S2000
Sounds good Pete!.
Am fitting a new interior either over this weekend or next week depending on work!..
Changing most of the interior stuff so will take some piccies if you wish for a `how to` type thing if that helps!.
Old 17-05-2006, 05:44   #8
Petevick
regained interest
Petevick's Avatar
yeah, anything Mark. There was 'talk' of such a section on here, but no sign of it ever happening . I'm don't intend to cover existing stuff, I'll just get permission from the orginator to supply a link.
__________________
Old 17-05-2006, 06:31   #9
Sambo.
Car: MGF VVC & MR2 GT-i16
Sambo. is up and running. Hey we all have to start somewhere.
Send a message via MSN to Sambo. Send a message via Skype™ to Sambo.
http://mr2oc.co.uk/index.php?name=Knowledge_Base
That's my bible when I'm trying to fox my MR2. If a new fix is posted on the forums, anyone can submit that post to the "Know your 2" section for a modrator to edit and pubish.
I'm shocked that this website doesn't have one.
Sambo. is offline   Reply With Quote
Old 17-05-2006, 06:57   #10
Andie B
Guest
Posts: n/a
Clicking the link came up as 'access denied' I'm afraid....guess they can sense us F/TFrs who don't also have an MR2 at 100 cyber-paces!
Old 17-05-2006, 07:20   #11
DAVIDT6DCM
Car: MGTF160
DAVIDT6DCM has a spectacular aura aboutDAVIDT6DCM has a spectacular aura about
That's good bit of info Mark, mine not leaking but the fit is awfiul,will have a wiggle about with it this weekend.
Sambo i couldn't open either,link just froze my page , Dave
DAVIDT6DCM is offline   Reply With Quote
Old 19-05-2006, 20:08   #12
Sambo.
Oops, sorry, you need to be a member to see it, but I've taken a few sneaky screen-grabs...
http://simon-cooper.net/temp/3.jpg
http://simon-cooper.net/temp/2.jpg
http://simon-cooper.net/temp/1.jpg
Old 28-11-2006, 13:54   #13
Herbie
Werder Supporter
Herbie's Avatar
Car: MGF 1.8i & MGTF 1:18
Herbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these partsHerbie is becoming God like round these parts
Send a message via MSN to Herbie Send a message via Skype™ to Herbie
Sorry for pulling up, but:
Thanks Mark !!!
What a useful tip, almost repositioned the hole seal and worked a treat, makes my F so less noisier and I have a good feeling in general now. Did the cheater and windows adjustment a few months back, so this was the "i-dapple" (i-tüpfelchen, maybe not translatable) ......
Worth every minute to do that, also Curgy's tip ref. the cantrail seals (loosen little nut, pulling seal toward a-frame, closing nut) was great !!!
Danke Mark and James
__________________
Stephan Hebert
MGF 1.8i / 1998 MK 1 / HB-SH 718 / CAQ
Daytona - 52mm TB - TF Steering Rack - Compliance Washers - Clear Indicators - Assorted Bling
Herbie is offline   Reply With Quote
Old 07-03-2007, 15:03   #14
AlexF
Car: MGF
AlexF is up and running. Hey we all have to start somewhere.
Send a message via MSN to AlexF
oh no!
the 1st picture has gone.... any chance of uplaoding it again?!
I think I have the exact same problem - so before I go chasing my tail this weekend taking the door apart I'd love to see if my MGF is doing the same as yours!
ALex
AlexF is offline   Reply With Quote
Old 07-03-2007, 18:31   #15
jonrice81
Car: Classic Rover
jonrice81 is up and running. Hey we all have to start somewhere.
yes mine is also doing this. just the passanger side window. it just doesnt fit snuggly into the seel.
can anybody put up an easy step guide to fixining this?
cheers
jonrice81 is offline   Reply With Quote
Old 29-06-2007, 00:30   #16
Jut
Car: MG TF 160 :D
Jut is up and running. Hey we all have to start somewhere.
sorry for the thread necrophillia, but anyone got a step by step guide preferably with pics to do this?
Jut is offline   Reply With Quote
Old 29-06-2007, 07:03   #17
Herbie
Werder Supporter
Herbie's Avatar
G'morning Jut, this may help you (Cantrail seal):
http://www.mgfcar.de/adjust/Adjust01.PDF
__________________
Stephan Hebert
Old 02-02-2009, 16:32   #18
gavnorton
Car: MG TF
gavnorton is up and running. Hey we all have to start somewhere.
Thank god
How glad am I that this thread is on here, just bought an older TF and cannot get good seal on passenger side with hood up. Its as if Cantrail seal forces window out at top.
I have done all the window adjustment and cheater adjustment
any chance of a link to curby's thread ref cantrail adjustment with little nut.........
Obviously I am well behind the drag curve, glad I am not alone though, this forum is a godsend.
gavnorton is offline   Reply With Quote
You may not post replies
roof down window up on mgf nk8 MGF and MGTF (Sponsored by MG Rover Parts Ltd) 41 01-10-2007 05:33
roof leaks thru interior light on zs 120 jules 123 MG ZS / Rover 45 & 400 1 25-08-2007 22:02
glass window and electric roof kizzy MGF and MGTF (Sponsored by MG Rover Parts Ltd) 41 09-03-2007 18:34
Split in window/roof seal ZoSo MGF and MGTF (Sponsored by MG Rover Parts Ltd) 3 26-09-2006 17:45
rear window and roof Deano MGF and MGTF (Sponsored by MG Rover Parts Ltd) 21 19-08-2003 17:49
Terms and conditions of use
