#1 |
Dave,
I'd like to pick your brain on a few issues regarding my 200Vi... Firstly, regarding the Idle Control Valve. I have read that when its electrical connector is removed, the engine revs should rise (due to the solenoid being withdrawn). Is this correct or am I talking a load of twaddle? When I remove the connector on mine, nothing happens. Secondly, I have recently performed a compression test on the engine with the following results; No#1 cylinder @ 200psi, No#2 cylinder @200psi, No#3 cylinder @185psi & No#4 cylinder at 180psi. Should I be worried about the 20psi difference between cylinders & is the 200 mark about right for the compression on this engine. Cheers, Richard. [Edited by RichyF on 23-05-2002 at 08:06 PM GMT] |
| Sponsored Links | |||
Advertisement | |||
#2 |
Administrator
Hi Rich
I wouldn't take too much to heart about the apparent non-operation of the IACV Do you have an idle speed problem? If not, then I wouldn't worry Aslong as the compression pressures are within 10% of each other (20PSI) then there's nothing to worry about [Edited by Dr Dave on 23-05-2002 at 09:05 PM GMT]
__________________
#3 |
...Do you have an idle speed problem? If not, then I wouldn't worry
No so much an idle speed problem, more of a lumpy idle. Could a faulty IACV cause this? |
#4 |
I changed mine a couple of months back, reset the mems with the pedal trick, and the car ran better for a while, but like everything i do to my car, the results are short lived and it goes back to running exactly the same>=( Got mine from the scrappies, £2 for that and a temp sensor, both were off a Rover 100! Same fitment
| Bookmarks |
| Thread Tools | |
| Idle Air Control Valve | Gentlman | MG ZR / Rover 25, 200 & Streetwise | 4 | 22-04-2008 19:07 |
| Idle Control Valve Problem?? | Dave1979 | MG ZS / Rover 45 & 400 | 4 | 21-11-2007 14:47 |
| idle speed control valve? | badman_liam | MG ZS / Rover 45 & 400 | 2 | 22-09-2006 12:55 |
| Idle Control Valve | neilwalls | Others | 7 | 12-07-2005 19:17 |
| idle control valve | neilwalls | Others | 2 | 05-04-2005 08:05 |
