#1 |
rover 75 cdti . the clutch pedal is very stiff to push down .it pulls well ,no slip its just very stiff .
| Sponsored Links | |||
Advertisement | |||
#3 |
The 75 clutch is naturally heavier in operation than others. If it is not slipping nor the pedal seeming loose or floppy then there shouldn't be any need to worry. A week's subscription to a gym with concentrated focus on your left leg muscles should see you OK
![]() hth Mike |
#4 |
Location: Erdington, Birmingham Car: Wood, leather and a touch of chrome marry beautifully...
Had my clutch, master and slave cylinders changed last week, The clutch is now super light, it feels like driving a petrol again in fact its taking some getting used to.
Almost worth the £600 for that alone.I did need to bleed the clutch again when I got it home though (biting point was near the floor) |
#5 |
That interesting, did they put an OEM or pattern clutch in?
Both mine are unpleasantly heavy I can only assume it is down to the springs on the pressure plate It is the only thing I really don't like about the cars as I really don't think there was ever a need for them to be like that |
#6 |
Mine has had a heavy clutch since I bought it. I had the slave cylinder bled yesterday as I couldn't get it in gear. The clutch is now much, much lighter than it ever has been
#7 |
Well how does that happen then
You would think the opposite a clutch needing bleeding would be all spongy unless there is greater leverage on the master cylinder when the pedal is at full height Still doesn't really add up though does it! unless the fluid itself is getting contaminated but then to increase the foot pressure needed the fluid would have to be thickening up or something similar can it do that? Perhaps we need a lesson in Hydraulics |
#8 |
Keith, I am 99% they used a LUK clutch, which from when I was on the spanners is a very trusted make.
They did bleed the clutch as described on the fitting instructions that came with the Rover master cylinder , I believe it was connect everything up, pump the clutch twice then open nipple and pump twice only and to there credit it was very light and didn't feel bad at all. But having drove round for a couple of days the biting point seemed very close to the floor than it was before. But as they hadn't drove it before they weren't to know. Anyway, bled the clutch as described elesewhere (used a syringe from an ink refill kit, Perfect for the job) Topped up pot, pumped twice slowly by hand with the nipple open, shut nipple and the biting point was perfect again. Pedal is like a petrol car again ie, very very light slightly unnerving in fact till I got used to it, made me realise how poorly the old slave must have been!!!! |
#9 |
Unless the sliding action of the slave is binding or the seals are trying to turn over, my clutch was actually working fine (no slip or drag) but pedal stayed on floor one day and it lasted 2 days before complete failure, It had always been heavy for the 7-8 months I had had the car but presumed that was normal, It was something I could have lived with.
But like you say hydraulically speaking it doesn't make sense. Still I ain't complaining.
#10 |
I suppose you didn't keep the old cylinders to pull them apart and see if the had seized partly as that would obviously lead to a stiffer thingy..........
#11 |
I was going to ask, but the guy who did the job was arguing with someone who thought a clutch job on a transit should be about £40 (because the everywhere)
#12 |
Location: Peterborough Car: Rover 75 CDT CONN SE & 2.0 V6
Yesterday I got caught in a major gridlock incident and spend 50 minutes travelling 5 miles, 1st time in the CDT and my left knee was aching.
Stubs |
#13 |
Location: England Car: Rover 75 tourer 2.5 auto. Chromactive Spectre.
My clutch is heavyish, I wouldn't say excessively so. Try steel toe cap boots, it'll seem fine then!
#14 |
Thanks guys its a bit 50/50 with the answers ,i.got 6 months warranty with the car ,i'll see how it goes.going away next week see how it goes.
thanks again derek |
#15 |
You will get used to it!
#16 | |
Location: Cheshire UK Car: ZT-T CDTi + Suzuki DL1000 GT
Jamie |
#17 |
Car: Rover 75 Tourer
Heavy Clutch
I've only had my 1.8T Tourer for a couple of days and the clutch is driving me mad. It seems to be a common problem listening to all the comments, but I will be taking it back to the dealer I bought it from who is an ex official Rover dealer.
#18 |
The clutches are heavy but it is not neccessarily a problem. The dealer will probably say they are all like that.
#19 |
Car: Rover 75
Hope this is not something that comes on with use, my 1.8T is very light and easy not much pressure needed at all
Mel75 |
#20 |
For what its worth, I had a 416 gti (G reg) a 420 gsi (R reg) and now a 75 conn se cdt (51 reg) and they all seemed a bit heavy on the clutch, but you get used to it.
maxi_crawf |
| Bookmarks |
| Thread Tools | |
| Heavy clutch + noise when clutch pedal is depressed | ztforever | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 5 | 05-11-2007 22:33 |
| Stiff \ Heavy Clutch Pedal .... | D6 VYJ | MGF and MGTF (Sponsored by MGF Mania) | 1 | 06-02-2007 11:00 |
| Heavy Clutch pedal and slow release | David Mills | MGF and MGTF (Sponsored by MGF Mania) | 4 | 11-12-2006 17:15 |
| 220 sdi very heavy clutch pedal | jlawson | Diesel Forum! | 11 | 19-09-2006 19:57 |
| rover 75 cdt heavy clutch pedal | heron8888 | MG ZT / Rover 75 (Sponsored by Rimmer Bros) | 1 | 27-10-2004 21:39 |
