Old 09-10-2006, 23:21   #1
TToP
Car: MGF
TToP is up and running. Hey we all have to start somewhere.
MGF - Wet drivers side carpet!
Well, i've suspected there to be a leak on the drivers side of my car somewhere for a while now but today i got in and the floor was drenched!
Pulled up the carpet in the drivers side footwell (had to removed the foot rest to do this properly) and pulled out the sound proofing, squeased about a pint of water out of it!!! not good!
After hanging the sound proofing out to dry i got on with cleaning up the floor and then onto finding he source of the leak. pouring water over the air intake (scuttle panel) did not produce any water but when i poured it over the bonnet i managed to spot water leaking down from behind here:
Heres a pic i took with the camera pointing up there, you can clearly see where the water has been running down.
further inspection and bottles of water revealed that only when i poured water over the hinge/gap between the wing (see pic below) did i get water coming in.
I have filled the back of this area with silicone sealant to hopefully block the area a bit, i think it must be leaking though a hole in the bodywork where some wealding has not quite been done properly. If anyone has experienced this or has some pointers for getting to the area better for a closer inpection let me know. Has anybody else had this same problem?
James
TToP is offline   Reply With Quote
Old 10-10-2006, 06:00   #2
Petevick
regained interest
Petevick's Avatar
Petevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on herePetevick is one of our most respected members on here
Send a message via MSN to Petevick
I think you may have a new one there James, can't remember seeing this before. Do you mind if I use your pics/text on my web site?, may be useful for other owners.
__________________
Pete Vickerstaff - Proud to drive an MG TF 160 in Trophy Yellow
MG F/TF Central - your one stop shop for MGF/TF tips, tricks, faq's, how to's and links
Soft Resin Badges for sale
Petevick is online now   Reply With Quote
Old 10-10-2006, 10:15   #3
TToP
Car: MGF
Go ahead mate! will check to dayto see if I've fixed the leak as its been raining all night! (really hope its fixed! )
You will need an 8mm Socket and a small extension bar to get all 3 nuts off of the foot rest (2 infront and 1 behind), also dont forget to remove the carpet retaining thingies!
James
Old 10-10-2006, 10:34   #4
Petevick
regained interest
Petevick's Avatar
Cheers matey
__________________
Old 10-10-2006, 15:49   #5
TToP
Car: MGF
Well, got in the car..and its soaking again!! will ahve another looksy tomorrow, anyone know how easy it is to take scuttle panel and wing off?
James
Old 10-10-2006, 16:04   #6
Chris T
Moderator
Chris T's Avatar
Car: MG TF 135 Platinum Silver
Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1Chris T has reached their true position at number 1
I would start by taking off the plastic inner wheel arch protector off and clean any rubbish off that have built up and possibly stopping any water getting away.
__________________
Proud Member of the HD-HU-CGAF Club.
North Leicester MG Club: www.northleicester-mg.org.uk
Chris T is online now   Reply With Quote
Old 10-10-2006, 18:04   #7
TToP
Car: MGF
Yeah, was planning on cleaning those out after seeing stampy's post yesterday, wonder what 10 years worth looks like! :s
James
Old 11-10-2006, 12:17   #8
TToP
Car: MGF
AARRGGHHH! Typical! i try and find/fix a leak and is ****es down all day! somebody give me a garage!!
starting to really get to me now, one leak after another, now i also find that my seats get wet when it rains since fittting the hard top too! Goddamn rover and their crappy workmanship!
James
Old 11-10-2006, 12:56   #9
Sprinter
Sprinter's Avatar
Car: MG TF135 184 g/km
Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.Sprinter has a reputation beyond repute. Respect.
Send a message via MSN to Sprinter
James
T A D T S.
Tear an old towel in to smallish sections. Put a piece of towel on the front corner of the seat squab with a tail hanging down towards the floor. Won't stop water getting in but will stop it running in to the seat cushion. keep the wet towel to clean your hands after changing the punctured wheel.
Sprinter is offline   Reply With Quote
Old 11-10-2006, 17:39   #10
TToP
Car: MGF
OK....i can see exactly where the water is getting from the inside but cannot for the life of me locate the position from under the bonnet, taken the scuttle panel off etc so have decided i need to plug it from inside but even aying on my back i still cant reach it. Its behind the fusebox and loads of wires which isn't a great thing in itself! is it easy to remove the fusebox etc to get to the hole?
James
Old 11-10-2006, 18:01   #11
Petevick
regained interest
Petevick's Avatar
fusebox is held in by 2 10mm nuts at the top, easy peasy
__________________
Old 12-10-2006, 15:04   #12
TToP
Car: MGF
My god, what an absolute pain in the backside of a job, though once i had loosend off the fusebox (cheers pete) I was just able to get behind it with some silicone sealant on my thumb and plug it up.....It's Fixed!! wasn't the most comfortable job laying in the footwell with my legs hanging out the car but got there in the end...now to sort the hard top leaks out..
James
Old 12-10-2006, 18:25   #13
Sprinter
Sprinter's Avatar
James
james
remember that position - you'll need it when the brake lights start sticking on and you need to change the switch behind the brake pedal.
Old 12-10-2006, 23:29   #14
TToP
Car: MGF
Originally Posted by Sprinter View Post
james
That's encouraging.... ahh well, hopefully all sorted now will see how it goes, in the mean time i need to arrange for some help with changing my coolant pipes (yet another leak on my car).
James
Old 08-11-2006, 16:18   #15
Mutley
Car: MGF
Mutley is up and running. Hey we all have to start somewhere.
Unhappy Same Problem
I seem to have exactly the same problem on my F. Could you shed any light on exactly where behind the fuse box the leak was coming from or was it plainly obvious once you got underneath and had a look.
Mutley is offline   Reply With Quote
Old 14-11-2008, 16:43   #16
larkottery
Car: MGF
larkottery is up and running. Hey we all have to start somewhere.
Mgf drivers side leak into cabin
If this is of any use to anyone, I traced a waterleak into my 2000 X MGF to the gasket around the base of the clutch master cylinder - dripping onto the clutch pedal mechanism & then into the carpet. Sealant around the base cured that problem although I have discovered it is still coming in from somewhere else - only discovered this site today so will try some of the other fixes listed here.
larkottery is offline   Reply With Quote
You may not post replies
Help Please - Wet Carpet Under Drivers Seat MARTIN1973 MG ZT / Rover 75 21 16-12-2009 22:15
Wet passenger side carpet pfig MGF and MGTF (Sponsored by MG Rover Parts Ltd) 5 30-10-2007 17:19
Wet Carpet Behind Drivers Seat MARTIN1973 MG ZT / Rover 75 2 06-03-2007 20:07
Wet driver's side carpet Les Middleton Rover 600 5 04-02-2007 17:46
Wet drivers side foot well TToP MGF and MGTF (Sponsored by MG Rover Parts Ltd) 6 16-06-2006 21:59
Terms and conditions of use
