#1 |
Car: Rover 200 Coupe
head gasket help please
i have just brought a 1991 220 coupe (honda engine i think) it was leaking oil from nearside front of head. i have stripped and cleaned and am ready to reasemble but dont know the torque settings for the head. my torque wrench is only in ft lbs but i do have an angle guage. also i cant find the adjustment point for the fan belt. can anyone help please chris
| Sponsored Links | |||
Advertisement | |||
#2 |
hi,go to page 3 of this forum check the help i got with my 420 its a t-series engine and the haynes manual for the 820 gives you the settings hope this is some help,mike
#3 |
Its not a Honda engine it is a Rover T series engine. Prone to leaking there. Are you replacing the gasket?
#4 |
hi there, yes got new standard gasket. also intend to change cambelt but cant find fan belt adjuster. motor has two plastic dowels for locating head is this right. also should there be an o ring on the oil feed from block to head. gratefull for any advice you can give. especially torque settings
chris |
#5 |
The o ring has to come out ...(actually it's an oil restrictor)...if you fit the later type gasket ..
the later type gasket can be id'd by multiple layers. I've heard that a screw lightly driven into the oil galery of the block on the head mating face ...can be used to remove the restrictor. engine has to be suported under the sump ...then right hand mount removed ...you should then be able to undo bottom cover on the cambelt ...and see adjuster. I say dont go any further without a manual of some sorts........or you're going to end up in big trouble . pistons have to be in the right place ...pin put in flywheeel etc ... All the best..mark Last edited by aboard_epsilon; 26-10-2006 at 20:24. |
#6 |
h/g 220
i used a payen h/g and i also removed that restricter with ascrew believe me these guys no what there talking about my cars running sweet,and i knew nothing about engines,mike
#7 |
All I know is that you don't remove the restrictor if the gasket is not multi layered one.
what guys are you talking about ? |
#8 |
i take it dr daves a guy and kevin or do you know something we dont.
#9 |
sorry mike
was answering, as if the original poster was posting... not you ... never noticed i was answering to you ...had favorates in my exploror down the left hand side of my monitor . |
| Bookmarks |
| Thread Tools | |
| Head Gasket Failure after Land Rover Gasket Fitted? | PERRY-MGTF | MGF and MGTF (Sponsored by MGF Mania) | 152 | 03-11-2012 11:41 |
| Inlet Manifold Gasket or Head Gasket Failure? | will-rover | MG ZR / Rover 25, 200 & Streetwise | 15 | 05-11-2010 16:42 |
| head gasket change advice, rover 45, HEAD GASKET NOT YET GONE, BUT OBV ON IT WAY OUT | rovermatt | MG ZS / Rover 45 & 400 | 8 | 24-08-2008 16:19 |
| How do i prevent Head Gasket and cylinder head damage | Quintin | MG ZR / Rover 25, 200 & Streetwise | 9 | 04-01-2008 18:42 |
| rover 620 honda head gasket v rover head gasket ? | jasonc46 | Rover 600 | 0 | 25-05-2006 19:44 |
