Rover 25 GTi - Change engine coolant - MG-Rover.org Forums
Old 30-10-2006, 14:51   #1
Silverscreen
Car: Rover 416 SLi 1.6 Petrol (1999)
i just bought a second hand rover 25 gti and have been adviced it is time to change the coolant. i have a copy of haynes workshop for rover 25s and it is very helpful. but i'm not sure where i'm supposed to open to drain the coolant. can anyone point me in the right direction? pictures would be even more helpful
thank you so much!
Silverscreen is offline   Reply With Quote Quick reply to this message
Old 30-10-2006, 15:25   #2
Xionz
Car: 200 Vi
Send a message via MSN to Xionz Send a message via Yahoo to Xionz
I belive its the bottom radiator hose via a small little molegrip style clip...
Im sure somone will know for sure...
Xionz is offline   Reply With Quote Quick reply to this message
Old 30-10-2006, 15:27   #3
carnumpty
Car: Rover 400 (95-99)
you drain it by taking the bottom radiator hose off , it would be useful to catch the coolant as it drains, and measure how much comes out (this will help with the maths later on)
Flush the system, I do this by connecting a garden hose into the hose that come out the bottom of the expantion tank and letting it run.
Now there should be only water in the system
It should be a 50/50 mix therefore if 2 1/2 litres came out originally there should still be 2 1/2 litres of clean water in the system after flushing, so to get a 50/50 mix I would add 2 1/2 literes of pure anti freeze
Then bleed the system (lots of posts on how to do that)
carnumpty is offline   Reply With Quote Quick reply to this message
Old 30-10-2006, 15:39   #4
carnumpty
Forget that bit, to do it this way is complicated (reconnect bottom hose jiggle valve etc)
do it this way, remove top radiator hose from radiator end stick a garden hose into the radiator hose and let it flow out from the bottom radiator hose
Old 01-11-2006, 12:54   #5
Silverscreen
sorry, I'm a bit of a virgin, where exactly is the opening of the pipe where i'm supposed to drain the coolant out from? do i have to jack up the car a lot?
Old 01-11-2006, 21:27   #6
smiddlewood
Car: Other Manufacturer
look downwards at the front of the engine bay, you have the radiator. at the bottom on the left is the bottom hose. on the top right is the top hose.
remove the cap on the expansion tank (clear tank, right of engine bay)
remove the bottom hose, this will let the coolant run out. catch it if you want, or your handbook might specify how much fluid should be in there. or halfords can tell you, if your haynes doesnt.
...... hang on ill find the guide i rote............
smiddlewood is offline   Reply With Quote Quick reply to this message
Old 01-11-2006, 21:31   #7
smiddlewood
i recommend changing coolant at least once a year, helps to stop build of crud in the system , therefore helping prevent or delay the growing problem of head gasket failure....
THIS GUIDE WAS ORIGINALLY WRITTEN FOR A ROVER 200. SOME POINTS MAY NOT BE AS ACCURATE ON THE 25.
YOU WILL NEED:
Elthol glycogen based antifreeze (most are now)(halfords advanced is fairly cheap and meets the bill)
Tools (8mm spanner, screwdrrive, 6mm spanner (for clips) Pliers or mole grips
5 liter tray
mixing pot
1.5 litres SOft water.
2 new Jubilee clips (29mm-46mm)
1. remove the filler cap
2. take a large container to catch the antifreeze, there will be just less than 3 litres in there.
3 remove the bottom hose from the radiator, let it drain.
4 remove the top hose of the radiator once it is empty.
5 garden hose in th stop radiator hose hole to flush it out, on extremely LOW PRESSURE.
6 after i while you should see the water running clear from the bottom hose hole of the radiator.
7 secure all clips and hoses back in place, i would advise replacing the top and bottom radiator hose clips with new jubilee clips. 29-46 mm ones.
8 remove the top half only of the air filter box (just unclips) and the airfilter.
9 there should be a bleed screw, with an 8 mm fixin on the top. undo it fully with 8 mm spanner, do not loose it. (it is located diagonally under the diszzy cap, its gold on a black metal coolant pipe.)
10 mix up 1.5 litres of soft water ( i used battery water from halfords) and 1.5 litres of antifreeze (ethol glycogen type) ( i used a 1.5 litre water bottle, and filled it once with each, then mixed in a brand new clean bucket, and used a funnel to pour into the system)
11. SLOWLY pour the mixture into the coolant resorvoir, a very slow trickle, so it doent glug or you will get more air into the system.
12. keep filling you will see seom start to come out of the whole where you took the bleed screw from, wait until this is a contstant flow of the same colour (indicating no air bubbles).
13. replace the screw
14. keep filling SLOWLY until you reach the MAX mark on the plastic filler tank.
( if you over fill, remove the bleed screw to take some of the antifreeze out. but not too much)
15. turn on car DO NOT REV. just leave at idle until the fan kiks in for one cycle.
(this took 5 mins on mine, wasnt overly hot day)
WHILST DOING THIS WATCH THE TEMP GAUGE LIKE A HAWK
(it should not rise above alf way, if it does TURN OFF ENGINE IMMEDIATLY, further air bleeding using bleed screw maybe required.
Also leave the header tank cap open to let air escape.
(the remainder of the antifreeze mixed up (you wont use all of it) maybe required for topping up after the cars first run)
cheers
Old 02-11-2006, 10:20   #8
Silverscreen
thanks so much. really helpful!
what are jubilee clips and how do you see if the fan kiks in for one cycle?
Old 02-11-2006, 10:25   #9
empsburna
heaters set to hot!
empsburna is offline   Reply With Quote Quick reply to this message
Old 02-11-2006, 10:33   #10
Silverscreen
ive looked around for jubilee hose clips, but not sure what size i should get as in the guide it says 29mm-46mm, but cant find any that fits that description?
Old 02-11-2006, 11:31   #11
troy.mclure
Car: Peugeot 206 GTi
Send a message via MSN to troy.mclure
Why are you getting new jubilee clips? The old ones should be fine to use again
troy.mclure is offline   Reply With Quote Quick reply to this message
Old 02-11-2006, 14:36   #12
Silverscreen
ok, didn't really want to get new ones (low on money as it is), just the guide said so. me=real car noob
Old 02-11-2006, 17:57   #13
smiddlewood
halfords sell them. but not desperatly needed. i changed them just as i dont like the old spring type clips.
before you start do set the heater controls to hot, sorry forgot to mention that. cheers empsburna!
jubilee clips only 2 pair ish. but dont worry about changing them.
Or enter your choice here:
Your Country
Your Postcode (UK Only)
Insurance
Date of Birth
Month Day Year
Privacy
Rover 25 GTI Engine Info simon26 MG ZR / Rover 25, 200 & Streetwise 11 24-11-2007 17:20
Change engine rover 216 GTi to 220 GTi ? craxz MG ZR / Rover 25, 200 & Streetwise 2 23-03-2007 15:59
rover 25 1.8 gti engine probles HELP Scillmotte MG / Rover Related Chat - up to 2005 0 13-06-2006 21:26
Rover 25 gti vvc head gasket change kingspade MG ZR / Rover 25, 200 & Streetwise 1 08-02-2006 17:00
Change engine, Rover 216 GTi.. craxz 'R8' Rovers (aka Wedges!!) 3 06-01-2006 05:42
