#1 |
Car: Rover 200 (-95)
Rover 220 Turbo Coupe - Timing problem
i just changed the head on my 220 turbo coupe all i need now is to do the timming the engine is in the tdc position and i need to know wich way the cam pullys go iv been told that the sides that say exhaust > points to the exhaust and the sides that say < inlet points to the inlet is this correct? thanks
| Sponsored Links | |||
Advertisement | |||
#2 | |
it should be at 9 oclock on the pulley pointer ...its marked then 6.5MM drill bit should be inserted into the back of the flywheel into a hiole that is drilled in the flywheel then you should have your pulleys like this . pics and text curtacy of mg john First picture: The above illustration shows the crankshaft pulley index in the 9 O'Clock position. Then, pistons Nos. 1 and 4 will be at 90 degrees BEFORE TOP DEAD CENTRE and pistons Nos. 2 and 3 at 90 degrees AFTER TOP DEAD CENTRE. All four pistons will be at the same level in the cylinder bores. When 'timing' the engine prior to fitting the timing belt, that crankshaft index must be set like this. Picture 2: The INLET CAMSHAFT PULLEY (on the left) and EXHAUST CAMSHAFT PULLEY (right) need to be in this position. However, it's not as simple as that because there are TWO slots on the camshaft pulleys- see next pictures - and the correct slot must be selected.. Picture 3: LHB10028 - EXHAUST PULLEY with its locking bolt removed to show that the slot marked 'EX' must be located over the roll pin. Picture 4: Again with bolt removed, INLET PULLEY LHB10029 with the Roll Pin located in the slot marked 'IN'. The roll pin is difficult to see but is in the slot marked "IN" if you look closely. Picture 5: This is how they should look with the timing belt in place and the CRANKSHAFT PULLY INDEX still showing the 9 O'Clock position - see Picture 1. WARNING Before starting that engine, DOUBLE CHECK AGAIN that CRANKSHAFT pulley index is still in the 9 O'Clock position. Pictures taken of the engine in my 1993 TomCat Turbo. |
#3 |
cheers mate very helpful,
#4 |
also turbo puleys are not interchangeable, the one marked lhb10028 must go on the inlet cam and the lhb10029 must go on exhaust cam. in the correct roll pins slots aswellhth
#5 |
cheers all done thanks again
#6 |
hang on you both saying the oppasite thing?
#7 |
I would take MGJohns to be right
My copied version of Johns post has been a sticky in rovertech for a long time .. if it was the wrong info someone would have corrected him by now .. My engine is running and was built with the aid of johns info . |
#8 | |
well thats goodenough for me, thanks |
#9 |
sorry, i was confused lol
| Bookmarks |
| Thread Tools | |
| 220 coupe turbo gearbox problem | marc9584 | Coupe | 16 | 07-09-2008 08:59 |
| 220 coupe turbo problem | champ222 | 'R8' Rovers (aka Wedges!!) | 14 | 17-12-2007 09:34 |
| help! rover 220 coupe turbo timing Diagram | zuko_gti | MG / Rover Related Chat - up to 2005 | 0 | 20-04-2007 21:53 |
| Rover 220 Turbo Coupe - Cold start problem | 220tommy | Coupe | 5 | 29-12-2006 11:24 |
| 220 coupe turbo problem | ROSS SANDY | 'R8' Rovers (aka Wedges!!) | 5 | 25-10-2005 13:43 |
