Rover 200 (R3) - 1998 - Gearbox oil - MG-Rover.org Forums
Old 06-11-2006, 11:23   #1
danicalifornia
Hiya i have a 98 rover 200 and i was wondering how much gear box oil it holds and how hard is this to fill or top up?
danicalifornia is offline   Reply With Quote Quick reply to this message
Old 06-11-2006, 11:26   #2
Cirian75
Cirian75's Avatar
Car: "Swifty" the Gun metal Gray Suzuki Swift 1.3 vvt
Send a message via MSN to Cirian75
Dont know and Dont know.
what do know is that the engines 1.1 to 1.6 use the R65 gearbox that uses the normal EP75/80 gearbox oil 99% on other manual gearboxes in the world use.
1.8 to 2.0 use the PG1 gearbox which uese MTF94 oil.
Cirian75 is offline   Reply With Quote Quick reply to this message
Old 06-11-2006, 17:45   #3
ashy
Car: Silver Stormer ZR turbo.
As long as you empty the box first you'll be safe to put 2 litres in. Usually 2 one litre bottles.
If it's an R65 which it will be if it's a 214 or a 216 the easiest way to fill is via the black breather cap on top of the box.
ashy is offline   Reply With Quote Quick reply to this message
Old 06-11-2006, 20:50   #4
danicalifornia
its a 220 ds is this the same type of gear box
Old 07-11-2006, 04:50   #5
Cirian75
Cirian75's Avatar
that should be a PG1 gearbox.
the oil for that is MTF94.
Old 07-11-2006, 11:44   #6
danicalifornia
i had bought ep 80w-90 gear oil is that of no use now
Old 07-11-2006, 11:57   #7
Cirian75
Cirian75's Avatar
on a PG1 gearbox yes, that oil can not be used in it, MTF94 oil must be used.
local motorfactor should stock it.
failing the B*W mini uses the same gearbox oil, I think, not 100% on that.
Just done my yearly oil change Rover 200 (R3) but..... cr4igp4lmer MG ZR / Rover 25, 200 & Streetwise 5 20-11-2006 16:05
Rover 200 (R3) - 1998 - Yellow relay npd1962 MG ZR / Rover 25, 200 & Streetwise 7 15-11-2006 05:31
Rover 200 (R3) - 1998 - Camshaft gasket dimension?? r0uter MG ZR / Rover 25, 200 & Streetwise 2 14-11-2006 12:43
Rover 200 (R3) - 1998 - Cambelt Mike L MG ZR / Rover 25, 200 & Streetwise 6 14-11-2006 08:16
Rover 200 (R3) - Tesco engine oil jay27 MG ZR / Rover 25, 200 & Streetwise 17 09-11-2006 21:41
