#1 |
Administrator
Car: Rover 75 2.0 CDTi Connoisseur Auto, Ford Kuga Titanium 2.0TDCi 2WD, Honda Accord Type S, Mercedes C
MG ZT / Rover 75 - Common questions, problems and how to's .....
With the many thousands of threads in the 75 and ZT Technical Help area, it is often difficult to find an answer to the problem that you have, or you may want an answer to a burning question. Here you will find links to pages on MG-Rover.org that will help you in answering your question.
Over time, these will be built up, and more links will be added. Summary of Problems/Questions: Safety Related Posts Post No 61 - Spring Protectors for Front Springs on all 75 / ZTs. Post No. 2 - Part Numbers for commonly requested items Post No. 3 - Factsheet: MG ZT & Rover 75 Fully Integrated Audio Systems Post No. 4 - How to fit a CD Autochanger to your Philips Harmony Head Unit equipped 75 or ZT Post No. 5 - Resetting Your Service Indicator Post No. 6 - What colour is my MG ZT? Post No. 7 - How to fit the Trafficmaster Alert System into a 75 equipped with High-line Instrumentation Post No. 8 - How to unblock your washer jets Post No. 9 - What are the specifications for the Rover 75 built at Cowley from 1999 until 2000? Post No. 10 - What are the specifications for the facelift Rover 75 Saloon & Tourer built from 2004 Onwards? Post No. 11 - What are the specifications for the facelift MG ZT & MG ZT-T built from 2004 Onwards? Post No. 12 - What are the specifications for the MG ZT & MG ZT-T built from 2001 until 2004? Post No. 13 - How do I replace the gearbox mounting? Post No. 14 - How do I replace a front wishbone and rear bush? Post No. 15 - How do I replace the Reversing Lamp switch? Post No. 16 - Can I fit Front Fog Lamps to a Rover 75 Diesel Automatic? Post No. 17 - How do I sort out a faulty VIS Valve Motor? Post No. 18 - How do I sort out problems with the Diesel Tank & Pump? Post No. 19 - How do I sort out problems with my cooling fan? Post No. 20 - How do I still use my Steering Wheel controls when I change the Head Unit in my MG ZT? Post No. 21 - How do I change the speakers in my MG ZT or Rover 75? Post No. 22 - How to find a way of getting a wire through the bulkhead into the boot? Post No. 23 - How to run the Instrument Cluster Diagnostic System Check. Post No. 24 - How to retro fit a Webasto Diesel Heater Timer Switch. Post No. 25 - How to bleed the clutch. Post No. 26 - How to test your Camshaft Sensor. Post No. 27 - How do I tell whether I have a 116PS or 131PS Diesel engine? Post No. 28 - I've bought some torpedo badges for the front doors of my Rover 75 - where do they go? Post No. 29 - How do I get the rear parcel shelf out in order to access the Electric Rear Sunblind? Post No. 30 - What options can I get configured at my local dealer for my MG ZT or Rover 75? Post No. 31 - How many MG ZT and Rover 75īs were produced? How many of them were built at Cowley and how many at Longbridge? Post No. 32 - What are the specifications for the Rover 75 Saloon built at Longbridge from 2000 until 2004? Post No. 33 - How do I know whether my 75/ZT CDT/i has the 116PS or 131PS engine? Post No. 34 - What are the differences between the MG ZT 190 and MG ZT 180 Sports Auto? Post No. 35 - How do I know which style door mirrors are fitted to my 75/ZT? Post No. 36 - What is the paint code for my MG ZT or Rover 75? Post No. 37 - What are the specifications for the Rover 75 Tourer built at Longbridge from 2001 until 2004? Post No. 38 - How to unblock your windscreen washer jets. Post No. 39 - What is the colour of the paint used on MG Alloy Wheels? Post No. 40 - What colour is my Cowley Built Rover 75? Post No. 41 - The sound quality on my Alpine Symphony Head Unit is poor - what can I do to improve it? Post No. 42 - What items did MG Rover delete from the MG ZT and Rover 75 as a result of Project Drive? Post No. 43 - How to find out when your Rover 75 or MG ZT was built. Post No. 44 - My bonnet is stuck and won't open - how can I get it open? Post No. 45 - The area near the ECU seems to be waterlogged - what can I do? Post No. 46 - How to refurbish your Alloy Wheels. Post No. 47 - How do I tell what factory my Rover 75 or MG ZT was built in? Cowley or Longbridge? Post No. 48 - How do I know which model year my Rover 75 or MG ZT is? Post No. 49 - What are the differences between the MG ZT 160 2.5 V6 and MG ZT 190 2.5 V6? Post No. 50 - Where can I buy new CD's for my Highline Satellite Navigation? Post No. 51 - What do I need to do to upgrade to the Message Centre and Hi-Line instrumentation? Post No. 52 - How do I get the Steering Wheel controls working on an MG ZT if I change the stereo? Post No. 53 - How does the Trafficmaster Alert System work? Post No. 54 - What Alloy Wheels do I have fitted to my MG ZT or Rover 75, and what are they called? Post No. 55 - What colour is my Longbridge built pre-facelift Rover 75? Post No. 56 - How can I retrofit the Hi-Line Sat Nav to my Rover 75 / ZT? Post No. 57 - Buying a Rover 75 or MG ZT? Make sure you get two working keys otherwise you'll be spending out alot of money! Post No. 58 - How To Reset the Radio Module in a HiLine Nav Setup Post No. 59 - How to safely power-down and disconnect the vehicle battery on Hi-Line Sat Nav equipped R75 platform vehicles. Post No. 60 - How do I replace the alternator on my Rover 75 or MG ZT Diesel? Post No. 61 - Spring Protectors for Front Springs on Rover 75 / MG ZT Post No. 62 - How do I remove the front bumper? Post No. 63 - How do I change a Xenon bulb? Post No. 64 - What does my VIN number mean? Post No. 65 - How to replace the Shannon tube (Air intake duct) Post No. 66 - How to replace the O rings on the intercooler pipe, without removing the front bumper. Removed at OP's request, sorry for that! See post 71 below!! Post No. 67 - How to replace the clutch without removing the subframe Post No. 68 - How To remove the PCV on the BMW Diesel Engined 75/ZT. Post No. 69 - How To fit an EGR valve bypass on the BMW diesel engined 75/ZT. Post no. 70 - How To Clean The Idle Control Solenoid on a V6 engine. Post no. 71 - How To Fit New Intercooler 'O' Rings on CDT/CDTi Models. WITHOUT REMOVING THE FRONT BUMPER! Last edited by robdrinkwater; 28-07-2010 at 16:31. |
#2 |
Administrator
Part Number for commonly requested items: (To be updated as new part numbers are found)
Accessories ESK100430 - Luggage Net Set (Saloon Only) KCC100050 - Warning Triangle - Boot Lid Fit (Saloon Only) Badges DAB101610 - Rover Badge - Front (Pre-Facelift) DAB000230 - Rover Badge - Front (Facelift) DAB101431 - Rover Badge - Rear - Bootlid DAB101180 - Rover Badge - Side - D Post DAH100800MMM - Chrome 75 Badge - Rear - Bootlid DAH000200MMM - Chrome 75 Shield Badge - Rear - Bootlid (Facelift) DAQ100040MMM - 1.8 LITRE Oval Badge - Front Door DAQ100060MMM - 2.0 LITRE Oval Badge - Front Door DAQ100080MMM - 2.5 LITRE Oval Badge - Front Door DAQ100100MMM - 2.0 CDT Oval Badge - Front Door DAM000380MMM - CDTi Badge - Bright Finish DAM000390MVR - CDTi Badge - Satin Finish DAM000400MVU - CDTi Badge - Satin Finish With Red 'i' DAM000410PMA - CDTi Badge - Black Finish DAM000420PBH - CDTi Badge - Black Finish With Red 'i' DAM000341MMM - 1.8T - Bright Finish DAM000342MVR - 1.8T - Satin Finish (MG) DAM000343PMA - 1.8T - Black Finish (MG) DAM000440MMM - SE Badge - Bright Finish DAL103750MMM - V6 Badge - Bright Finish DAG000080MMM - Union Flag - Rear - Bootlid DAH000040MMM - MG Badge - Front Grille DAT000220MVR - ZT 260 Rear Badge DAT000190MVR - ZT-T 260 Rear Badge DAL000080MVR - V8 Badge - Satin Silver DAL000080MMM - V8 Badge - Bright DAG000070MMM - Union Flag / Chequered Flag Chrome Door Mirrors Left Hand - CRC100210MMM (To VIN Number 255986) - MG ZT / Rover 75 (Up To Build Date 6th May 2002) Right Hand - CRC100200MMM (To VIN Number 255986) - MG ZT / Rover 75 (Up To Build Date 6th May 2002) Pair Of Mirrors - CRC100190MMM (To VIN Number 255986) - MG ZT / Rover 75 (Up To Build Date 6th May 2002) Left Hand - CRC100250MMM (From VIN Number 255987) - MG ZT / Rover 75 (Built After 6th May 2002) Right Hand - CRC100240MMM (From VIN Number 255987) - MG ZT / Rover 75 (Built After 6th May 2002) Pair Of Mirrors - CRC100960MMM (From VIN Number 255987) - MG ZT / Rover 75 (Built After 6th May 2002) Exterior Trim Exhaust Finisher - 1.8 - DUB100640MMM (1 Required) Exhaust Finishers - V6 - DUB100640MMM (2 Required) Exhaust Finishers - CDT/i - DUB100650MMM (2 Required) XGB100310 - Smoked Side Indicator Repeater (Pre-Facelift Models) XGB000100 - Clear Jewelled Side Indicator Repeater (Facelift Models) KZM000050 - Engine Undertray - Quick Release Fastener In Car Entertainment VUX100030 - Head Unit - Alpine Symphony XQZ100050 - Magazine - CD Autochanger VUB102140 - CD Autochanger - Fits Philips Harmony & Alpine Symphony VUB105400 - CD Autochanger - Fits Philips Harmony & Alpine Symphony XQE100430 - CD Autochanger - Fits Philips Harmony & Alpine Symphony XQE105560 - CD Autochanger - Fits Philips Harmony & Alpine Symphony VUL100330 - Wiring Loom For CD Autochanger - Alpine Symphony VUL100310 - Wiring Loom For CD Autochanger - Philips Harmony XQU100910 - Bracket For Mounting CD Autochanger In Glovebox - Left Hand Side XQU100900 - Bracket For Mounting CD Autochanger In Glovebox - Right Hand Side ESR1560A - Nut & Washer Set (Pack Of 4) To Use In Left & Right Brackets XQN100280 - Tweeter Audio System Upgrade Kit XQM101270 - Harmon Kardon Speakers - Front & Rear Single Cone (Pre-Facelift) XQM000770 - Harmon Kardon Speakers - Front & Rear Single Cone (Facelift) XQN100210 - Harmon Kardon Speakers - Front Tweeter XQN100230 - Harmon Kardon Speakers - Rear Tweeter XQA100000 - Harmon Kardon Sub Woofer Assembly - Saloon XQA100050 - Harmon Kardon Sub Woofer Assembly - Tourer XQU100870 - Harmon Kardon Amplifier Mounting Bracket - Tourer ADU6552 - Harmon Kardon Sub Woofer Nut (4 nuts Required) Interior Trim EYC000380 - Door Trim Kickplate retaining clips (Interior front door sill) UKJ000390AGC - Gear Knob - Light Oak - Manual UKJ000390ANV - Gear Knob - Burr Walnut - Manual UKJ000390PWI - Gear Knob - Dark Oak - Manual VUB112220 - Handbrake Grip Wooden Mats - MG ZT/ZT-T EAH000230PMA - Front - Black Rubber Mats - RHD EAH000200PMA - Front - Black Rubber Mats - LHD EAH000520PMA - Rear - Black Rubber Mats - RHD/LHD EAH000190LNF - Front & Rear - Ash Grey - LHD EAH000180LNF - Front & Rear - Ash Grey - RHD EAK100040 - Floor Clips (4 in a pack) Mats - Rover 75 EAH104070PMA - Front - Black Rubber Mats - RHD EAH104120PMA - Front - Black Rubber Mats - LHD EAH104410PMA - Rear - Black Rubber Mats - RHD/LHD EAH104400LNF - Front & Rear - Ash Grey - Standard - LHD EAH104390LNF - Front & Rear - Ash Grey - Standard - RHD EAH001120LNF - Front & Rear - Ash Grey - Standard With Rover Logo - LHD EAH001110LNF - Front & Rear - Ash Grey - Standard With Rover Logo - RHD EAH104400SCD - Front & Rear - Sandstone Beige - Standard - LHD EAH104390SCD - Front & Rear - Sandstone Beige - Standard - RHD EAH001120SCD - Front & Rear - Sandstone Beige - Standard With Rover Logo - LHD EAH001110SCD - Front & Rear - Sandstone Beige - Standard With Rover Logo - RHD EAH104110LNF - Front & Rear - Ash Grey - Premium - LHD EAH104100LNF - Front & Rear - Ash Grey - Premium - RHD EAH001140LNF - Front & Rear - Ash Grey - Premium With Rover Logo - LHD EAH001130LNF - Front & Rear - Ash Grey - Premium With Rover Logo - RHD EAH104110SCD - Front & Rear - Sandstone Beige - Premium - LHD EAH104100SCD - Front & Rear - Sandstone Beige - Premium - RHD EAH001140SCD - Front & Rear - Sandstone Beige - Premium With Rover Logo - LHD EAH001130SCD - Front & Rear - Sandstone Beige - Premium With Rover Logo - RHD EAH000930LNF - Front & Rear - Ash Grey - Limousine Only - LHD EAH000980LNF - Front & Rear - Ash Grey - Limousine Only - RHD EAH000930SCD - Front & Rear - Sandstone Beige - Limousine Only - LHD EAH000980SCD - Front & Rear - Sandstone Beige - Limousine Only - RHD EAK100040 - Floor Clips (4 in a pack) Mirrors Original Bullet Style: CRB110720 - Right Hand Mirror Assembly - Power Folding CRB110760 - Left Hand Mirror Assembly - Power Folding CRB110700 - Right Hand Mirror Assembly - Non Power Folding CRB110740 - Left Hand Mirror Assembly - Non Power Folding Later Style: CRB002140 - Right Hand Mirror Assembly - Power Folding CRB002100 - Left Hand Mirror Assembly - Power Folding CRB002120 - Right Hand Mirror Assembly - Non Power Folding CRB002180 - Left Hand Mirror Assembly - Non Power Folding Premium Grille (Rover 75 V8 Style) DPC001280LML - Bumper DQY000370LFG - Grille Assembly - Upper DQY000380LFG - Grille Assembly - Lower DQY000390LFG - Grille Assembly - Right Hand Side DQY000400LGF - Grille Assembly - Left Hand Side DXJ000060 - Air Deflector DPG000160 - Bracket For Upper In Fill Mounting DPR000160MMM - Grille Surround Finisher - Polished DPJ000200 - Foam Front Bumper In Fill DPJ000210 - Foam Front Bumper In Fill DPC000990LML - Front Bumper Towing Eye Access Cover (Primer) Sensors ZUA000050SLP - MAF Sensor - 2.0 CDT/CDTi (Replacement for MHK101130 and is said to be more reliable) Service Items PHE100460 - Air Filter - 1.8 & 1.8T & 2.0 V6 & 2.5 V6 PHE100500 - Air Filter - 2.0 CDT/CDTi JKR100180 - Air Filter - 4.6 V8 JKR100193 - Odour Filter - Air Intake (To VIN Number 346999) JKR000040 - Odour Filter - Air Intake (From VIN Number 347000) JKR100183 - Pollen Filter - Air Intake (To VIN Number 346999) JKR000030 - Pollen Filter - Air Intake (From VIN Number 347000) CDU1268 - Oil Filter - 1.8 LPW100180 - Oil Filter - 1.8T LPW100160 - Oil Filter - 2.0 V6 & 2.5 V6 LPW000070 - Oil Filter - 4.6 V8 LRF100150 - Oil Filter - 2.0 CDT/CDTi ALU1403 - Sump Plug Washer (Recommended to replace each oil change) NCC100120 - Glow Plugs - 2.0 CDT/CDTi NLP100290 - Spark Plugs - 1.8 & 1.8T & 2.0 V6 & 2.5 V6 (Except LPG Models) NLP000090 - Spark Plugs - LPG Models DKC100940 - Windscreen Wiper Blade - Front Drivers Side (RHD) DKC100950 - Windscreen Wiper Blade - Front Passengers Side (RHD) DKC000120 - Rear Window Wiper Blade - Tourer Wheels DTB101593MNH - 15" Wheel Trim - Silver Sparkle - 5.5J x 15" (Pre-Facelift 75) (To Chassis Number 321637) DTB101593MBP - 15" Wheel Trim - Silver Sparkle - 6.0J x 15" (Facelift 75) (From Chassis Number 321638) RRC003300MNH - 15" Comet - Silver Sparkle - 6.5J x 15" (To Chassis Number 313957) RRC005140MNH - 15" Comet - Silver Sparkle - 6.5J x 15" (From Chassis Number 313958) RRC116021MNH - 15" Contour - Silver Sparkle - 6.5J x 15" (To Chassis Number 157058) RRC117040MNH - 15" Contour - Silver Sparkle - 6.5J x 15" (From Chassis Number 157059) RRC110714MNH - 15" Crown - Silver Sparkle - 6.5J x 15" (To Chassis Number 149626) RRC116750MNH - 15" Crown - Silver Sparkle - 6.5J x 15" (From Chassis Number 256247) RRC004610MNH - 16" 7 Spoke - Silver Sparkle - 6.5J x 16" RRC005400MBS - 16" Forked - Liquid Silver - 6.5J x 16" RRC005380MNH - 16" Multispoke - Silver Sparkle - 6.5J x 16" RRC110722MNH - 16" Union - Silver Sparkle - 6.5J x 16" (To Chassis Number 153365) RRC117050MNH - 16" Union - Silver Sparkle - 6.5J x 16" (From Chassis Number 153366) RRC112191MBS - 17" Meteor - Liquid Silver - 7.0J x 17" RRC112190MNH - 17" Meteor - Silver Sparkle - 7.0J x 17" (To Chassis Number 274574) RRC112191MNH - 17" Meteor - Silver Sparkle - 7.0J x 17" (From Chassis Number 274575 to 321637) RRC005290MNH - 17" Mirage - Silver Sparkle - 7.5J x 17" RRC110132MBS - 17" Serpent - Liquid Silver - 7.0J x 17" RRC110132MNH - 17" Serpent - Silver Sparkle - 7.0J x 17" RRC005420MBS - 17" Star Spoke - Liquid Silver - 7.0J x 17" RRC005660MBS - 17" Viking - Liquid Silver - 7.5J x 17" RRC005010MNH - 18" 11 Spoke - Silver Sparkle - 7.5J x 18" RRC005340MVV - 18" Apex - Platinum Silver - 7.5J x 18" RRC005440MNH - 18" Grid Spoke - Silver Sparkle - 7.5J x 18" RRC002250MNH - 18" Hairpin - Silver Sparkle - 7.5J x 18" (To Chassis Number 317275) RRC005120MNH - 18" Hairpin - Silver Sparkle - 7.5J x 18" (From Chassis Number 317276) RRC002260MNH - 18" Straights - Silver Sparkle - 7.5J x 18" (To Chassis Number 317275) RRC005130MNH - 18" Straights - Silver Sparkle - 7.5J x 18" (From Chassis Number 31276 to 321637) RRC005530MWR - 18" Vortex - Liquid Silver - 7.5J x 18" RRC113750PMN - 16" Space Saver - 4.0 x 16" DTC10054MNH - Centre Cap (Old Rover Logo) DTC100170MNH - Centre Cap (New Rover Logo) RRJ100150MNH - 17" Centre Cap (New Rover Logo) - Silver Sparkle RRJ100110MNH - 17" Centre Cap (New Rover Logo) - Silver Sparkle - Octopussy RRJ100150MBS - 17" Meteor - Centre Cap (New Rover Logo) - Liquid Silver RRJ100110MBS - 17" Serpent - Centre Cap (New Rover Logo) - Liquid Silver DTC000090MVY - 18" Apex - Centre Cap (MG Logo) DTC000090MNH - 18" Grid Spoke - Centre Cap (MG Logo) DTC000150MNH - 18" Hairpins - Centre Cap (MG Logo) DTC000150MBP - 18" Hairpins - Centre Cap (MG Logo) - Silver Sparkle RRJ000050MNH - 18" Straights - Centre Cap (MG Logo) - Silver Sparkle RRJ000051MNH - 18" Straights - Centre Cap (MG Logo) - Silver Sparkle - Plastic DTC000150MBS - 18" Vortex - Centre Cap (New Rover Logo) Last edited by Ian; 23-06-2007 at 17:54. |
#3 |
Administrator
Click here to find out all about them. http://forums.mg-rover.org/showthread.php?t=159186 |
#4 |
Administrator
How to fit a CD Changer to your Harmony equipped 75 or ZT.
http://forums.mg-rover.org/showthread.php?t=121547 Please note, this "How To", is only available to MG-Rover.org supporters. Last edited by Ian; 17-02-2007 at 13:46. |
#5 |
Administrator
Following on from that Ian - 75 & ZT Service indicator reset, using a piece of wire
It's the method I now use, no problems so far, on cars 1999-2004, both petrol & diesel. http://forums.mg-rover.org/showthread.php?t=76910
__________________
![]() '06 330d M Sport Auto || Evolve Switch 300PS 500ft/lb || BMW Performance Brakes || Paddleshift Retrofit || Alpine HiFi Upgrade || 6CD retrofit || BMWP Gloss Grilles || oh and a Witter detachable hidden towbar LOL |
#6 |
Administrator
http://forums.mg-rover.org/showthread.php?t=162168
Here you will find pictures in order for you to decide what colour your MG ZT is. |
#7 |
Administrator
http://forums.mg-rover.org/showthread.php?t=165355
Here you will find out how to fit the Trafficmaster Alert System on a 75 or ZT that is equipped with the High Line Instrumentation. This is Dr Dave's fantastic picture by picture easy to do guide. |
#8 |
Administrator
#9 |
Administrator
http://forums.mg-rover.org/showthread.php?t=135389
(MG-Rover.org Supporters only) What was the specification of the Cowley built Rover 75? In this PDF Document, you will find the following: * Technical Specifications * Performance Figures * Fuel Consumption Figures * Standard and Optional Equipment Listings * Exterior Colours |
#10 |
Administrator
http://forums.mg-rover.org/showthread.php?t=146462
http://forums.mg-rover.org/showthread.php?t=147802 (MG-Rover.org Supporters only) What was the specification of the facelifted Rover 75 models built from 2004 onwards? In this PDF Document, you will find the following for both Saloon and Tourer models: * Technical Specifications * Performance Figures * Fuel Consumption Figures * Standard and Optional Equipment Listings * Exterior Colours |
#11 |
Administrator
http://forums.mg-rover.org/showthread.php?t=138277
http://forums.mg-rover.org/showthread.php?t=138278 (MG-Rover.org Supporters only) What was the specification of the facelifted MG ZT and MG ZT-T models built from 2004 onwards? In this PDF Document, you will find the following for both Saloon and Tourer models: * Technical Specifications * Performance Figures * Fuel Consumption Figures * Standard and Optional Equipment Listings * Exterior Colours |
#12 |
Administrator
http://forums.mg-rover.org/showthread.php?t=154068
http://forums.mg-rover.org/showthread.php?t=155265 (MG-Rover.org Supporters only) What was the specification of the MG ZT and MG ZT-T models built from 2001 until they were facelifted in 2004? In this PDF Document, you will find the following for both Saloon and Tourer models: * Technical Specifications * Performance Figures * Fuel Consumption Figures * Standard and Optional Equipment Listings * Exterior Colours |
#13 |
Administrator
http://forums.mg-rover.org/showthread.php?t=165911
How do I replace the Gearbox mounting on a Rover 75 or MG ZT? |
#14 |
Administrator
http://forums.mg-rover.org/showthread.php?t=165753
How do I replace the Front Wishbone and Rear Bush on a Rover 75 and MG ZT? |
#15 |
Administrator
http://forums.mg-rover.org/showthread.php?t=99125
How do I replace the Reverse Lamp switch on a Rover 75 or MG ZT? |
#16 |
Administrator
http://forums.mg-rover.org/showthrea...91#post1776391
Can I fit Front Fog Lamps to a Rover 75 Diesel Automatic? |
#17 |
Administrator
#18 |
Administrator
http://forums.mg-rover.org/showthread.php?t=123849
How do I sort out problems with the Diesel tank and pump? |
#19 |
Administrator
#20 |
Administrator
http://forums.mg-rover.org/showthread.php?t=107914
How do I still use my Steering Wheel controls if I change the ICE in my MG ZT? |
| Bookmarks |
| Thread Tools | |
| Rover 75 con 99 v6 heater problems again! Common fault? | Razorab | MG ZT / Rover 75 | 22 | 20-08-2010 08:47 |
| MG ZT / Rover 75 - Common questions and problems | simon.h | MG ZT / Rover 75 | 1 | 24-04-2009 21:14 |
| MG ZR common problems | holdswot | MG ZR / Rover 25, 200 & Streetwise | 17 | 17-10-2008 22:26 |
| MG ZT / Rover 75 - Frequently Asked Questions | Keith Alexander | MG ZT / Rover 75 | 23 | 16-11-2006 19:03 |
| Common problems on Aussie 75s/ZT | Rowland Ward | Australia and New Zealand | 24 | 03-09-2006 04:50 |
